Bei den Fibaro-Dimmern kann man durch setzen des Parameters 41 diese für „scene activation“ konfigurieren. Je nach dem welche Taste wie betätigt wird (einzel, doppel oder dreifach Klick) werden ID:s an den Controller (IP Symcon) übermittelt.
Meine Frage: Wie kann ich diese Szenen-ID:s im IP Symcon „auslesen“.
Ausschnitt aus der Fibaro Bedienungsanleitung der sich hierauf bezieht:
Parameter No. 41 - Scene activation functionality.
Default value: 0
Possible parameter settings:
0 – functionality deactivated
1 – functionality activated
The device offers the possibility of sending commands compatible
with Command class scene activation. Information is sent to devices
assigned to association group no. 3. Controllers such as Home
Center 2 are able to interpret such commands and based on these
commands they activate scenes, to which specific scene IDs have
been assigned. The user may expand the functionality of the button
connected to inputs S1 and S2 by distinguishing the actions of keys
connected to those inputs. For example: double click would activate
the scene “goodnight” and triple click would activate the scene
“morning”.
Scene ID is determined as follows:
Momentary switch
(parameter 14 set to 0):
Input S1:
holding down ID 12 (option inactive in case of roller blind switch)
releasing ID 13
double click ID 14 (depends on parameters 15 value - 1 = double
click active)
triple click ID 15
one click ID 16
