Habe folgendes Problem auf einem Raspberry Pi.
Installation und Einrichtung klappt wunderbar. Nachdem man dann den IP Symcon Dienst beendet und wieder starten will, wird Symcon nicht mehr gestartet. "IP-Symcon started with PID " ohne Prozess Nummer:
Reading symbols from /usr/bin/symcon...done.
(gdb) run
Starting program: /usr/bin/symcon
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
Program received signal SIGILL, Illegal instruction.
0xb6e3b600 in ?? () from /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.0.0
(gdb) bt
#0 0xb6e3b600 in ?? () from /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.0.0
Cannot access memory at address 0x0
#1 0xb6e37fe4 in OPENSSL_cpuid_setup () from /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.0.0
#2 0xb6fe8254 in ?? () from /lib/ld-linux-armhf.so.3
#3 0xbefff996 in ?? ()
#4 0xbefff996 in ?? ()
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
(gdb)
Das normale Log steigt hier aus:
12:30:08 | 00000 | MESSAGE | LinkManager | Creating…
12:30:08 | 00000 | MESSAGE | ModuleLoader | Creating…
12:30:08 | 00000 | MESSAGE | FlowHandler | Creating…
12:30:08 | 00000 | MESSAGE | ProfilePool | Creating…
12:30:08 | 00000 | MESSAGE | ScriptEngine | Creating…
12:30:08 | 00000 | MESSAGE | TimerPool | Creating…
12:30:08 | 00000 | MESSAGE | DataServer | Creating…
12:30:08 | 00000 | MESSAGE | DiscoveryServer | Creating…
12:30:08 | 00000 | MESSAGE | DebugServer | Creating…
12:30:08 | 00000 | MESSAGE | Settings | Loaded 0 profiles…
Jemand eine Idee?
Viele Grüße!
