ich möchte gerne IP Symcon unter Proxmox installieren und bekomme aber Fehlermeldungen.
Bin so vorgegangen:
- unter Proxmox das Template für Ubuntu 20.04 gezogen
- einen Container erstellt mit dem Template
- Container gestartet
- in der Konsole des Containers die Installation vorgenommen aus der Dokumentation/Installation/Linux → Befehle ohne sudo
Ubuntu 20.04 LTS Symcon tty1
Symcon login: root
Password:
Welcome to Ubuntu 20.04 LTS (GNU/Linux 5.13.19-3-pve x86_64)
* Documentation: https://help.ubuntu.com
* Management: https://landscape.canonical.com
* Support: https://ubuntu.com/advantage
The programs included with the Ubuntu system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by
applicable law.
root@Symcon:~# echo "deb [arch=amd64] http://apt.symcon.de/ stable ubuntu" | sudo tee /etc/apt/sources.list.d/symcon.list
sudo: setrlimit(RLIMIT_CORE): Operation not permitted
root@Symcon:~# wget -qO - https://apt.symcon.de/symcon.key | sudo apt-key add -
E: gnupg, gnupg2 and gnupg1 do not seem to be installed, but one of them is required for this operation
root@Symcon:~# echo "deb [arch=amd64] http://apt.symcon.de/ stable ubuntu" | tee /etc/apt/sources.list.d/symcon.list
root@Symcon:~# wget -qO - https://apt.symcon.de/symcon.key | apt-key add -
root@Symcon:~# apt-get update
Get:1 http://archive.ubuntu.com/ubuntu focal InRelease [265 kB]
Get:2 http://apt.symcon.de stable InRelease [1396 B]
Err:2 http://apt.symcon.de stable InRelease
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY F06C1468340D3A2A
Get:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
Get:4 http://archive.ubuntu.com/ubuntu focal-security InRelease [114 kB]
Get:5 http://archive.ubuntu.com/ubuntu focal/main Translation-en [506 kB]
Get:6 http://archive.ubuntu.com/ubuntu focal/main amd64 c-n-f Metadata [29.5 kB]
Get:7 http://archive.ubuntu.com/ubuntu focal/restricted Translation-en [6212 B]
Get:8 http://archive.ubuntu.com/ubuntu focal/restricted amd64 c-n-f Metadata [392 B]
Get:9 http://archive.ubuntu.com/ubuntu focal/universe Translation-en [5124 kB]
Get:10 http://archive.ubuntu.com/ubuntu focal/universe amd64 c-n-f Metadata [265 kB]
Get:11 http://archive.ubuntu.com/ubuntu focal/multiverse Translation-en [104 kB]
Get:12 http://archive.ubuntu.com/ubuntu focal/multiverse amd64 c-n-f Metadata [9136 B]
Get:13 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [1510 kB]
Get:14 http://archive.ubuntu.com/ubuntu focal-updates/main Translation-en [296 kB]
Get:15 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 c-n-f Metadata [14.7 kB]
Get:16 http://archive.ubuntu.com/ubuntu focal-updates/restricted amd64 Packages [736 kB]
Get:17 http://archive.ubuntu.com/ubuntu focal-updates/restricted Translation-en [105 kB]
Get:18 http://archive.ubuntu.com/ubuntu focal-updates/restricted amd64 c-n-f Metadata [532 B]
Get:19 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages [894 kB]
Get:20 http://archive.ubuntu.com/ubuntu focal-updates/universe Translation-en [196 kB]
Get:21 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 c-n-f Metadata [20.0 kB]
Get:22 http://archive.ubuntu.com/ubuntu focal-updates/multiverse amd64 Packages [24.8 kB]
Get:23 http://archive.ubuntu.com/ubuntu focal-updates/multiverse Translation-en [6928 B]
Get:24 http://archive.ubuntu.com/ubuntu focal-updates/multiverse amd64 c-n-f Metadata [620 B]
Get:25 http://archive.ubuntu.com/ubuntu focal-security/main amd64 Packages [1178 kB]
Get:26 http://archive.ubuntu.com/ubuntu focal-security/main Translation-en [210 kB]
Get:27 http://archive.ubuntu.com/ubuntu focal-security/main amd64 c-n-f Metadata [9132 B]
Get:28 http://archive.ubuntu.com/ubuntu focal-security/restricted amd64 Packages [686 kB]
Get:29 http://archive.ubuntu.com/ubuntu focal-security/restricted Translation-en [97.9 kB]
Get:30 http://archive.ubuntu.com/ubuntu focal-security/restricted amd64 c-n-f Metadata [536 B]
Get:31 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages [676 kB]
Get:32 http://archive.ubuntu.com/ubuntu focal-security/universe Translation-en [115 kB]
Get:33 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 c-n-f Metadata [13.0 kB]
Get:34 http://archive.ubuntu.com/ubuntu focal-security/multiverse amd64 Packages [21.8 kB]
Get:35 http://archive.ubuntu.com/ubuntu focal-security/multiverse Translation-en [4948 B]
Get:36 http://archive.ubuntu.com/ubuntu focal-security/multiverse amd64 c-n-f Metadata [536 B]
Reading package lists... Done
W: GPG error: http://apt.symcon.de stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY F06C1468340D3A2A
E: The repository 'http://apt.symcon.de stable InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
root@Symcon:~# apt-get install symcon
Building dependency tree... Done
E: Unable to locate package symcon
root@Symcon:~#
