Versuche gerade die Installation auf einem Guitar-Board unter Lemuntu (Debian-Jessie). Hat auch alles geklappt, leider startet Symcon nicht.
Komme über das nicht hinaus
11:27:52 | 00000 | MESSAGE | Kernel | Creating...
11:27:52 | 00000 | MESSAGE | Kernel | IP-Symcon Kernel Version: 4.00
11:27:52 | 00000 | MESSAGE | Kernel | IP-Symcon Kernel WorkingDir: /usr/share/symcon/
11:27:52 | 00000 | MESSAGE | Kernel | IP-Symcon Kernel SystemDir: /etc/symcon/
11:27:52 | 00000 | MESSAGE | Kernel | IP-Symcon Kernel LogDir: /var/log/symcon/
11:27:52 | 00000 | MESSAGE | Kernel | IP-Symcon System: linux
11:27:52 | 00000 | MESSAGE | Kernel | Boost Version: 1_60
11:27:52 | 00000 | MESSAGE | Kernel | cURL Version: libcurl/7.38.0 OpenSSL/1.0.1k zlib/1.2.8 libidn/1.29 libssh2/1.4.3 librtmp/2.3
11:27:52 | 00000 | MESSAGE | Kernel | Git2 Version: 0.23.0
11:27:52 | 00000 | MESSAGE | Kernel | SSH2 Version: 1.4.2
11:27:52 | 00000 | MESSAGE | Kernel | ZLIB Version: 1.2.7
11:27:52 | 00000 | MESSAGE | Kernel | RapidJSON Version: 1.0.2
11:27:52 | 00000 | MESSAGE | Kernel | OpenSSL Version: OpenSSL 1.0.1k 8 Jan 2015
11:27:52 | 00000 | MESSAGE | Kernel | OpenSSL CertDir: /usr/lib/ssl/certs
11:27:52 | 00000 | MESSAGE | Kernel | PHP Version: 5.5.30
11:27:52 | 00000 | MESSAGE | Kernel | Initializing...
11:27:52 | 00000 | MESSAGE | LocalePool | Creating...
11:27:52 | 00000 | MESSAGE | LocalePool | Detected locale: en_US
11:27:52 | 00000 | MESSAGE | LocalePool | No translation files found
11:27:52 | 00000 | MESSAGE | LicensePool | Creating...
11:27:52 | 00000 | MESSAGE | LicensePool | LiveUpdate: 07.01.2016, 07c32b193299
11:27:52 | 00000 | MESSAGE | LicensePool | Cannot verify license. Running in Demo mode.
11:27:52 | 00000 | MESSAGE | Settings | Creating...
11:27:52 | 00000 | MESSAGE | Settings | Loading settings...
11:27:52 | 00000 | MESSAGE | Settings | Creating settings thread...
11:27:52 | 00000 | MESSAGE | Settings | Cleaning up Backup Folder...
Habe Symcon neu installiert, später auch die Daten vom Odroid rüberkopiert, bleibt immer fast gleich stehen. Mal mit der letzten Zeile, mal ohne diese. Was kann ich tun ?
PS: Bin mir nicht sicher, ob das hier das gleiche ist, deswegen neu
IPS Dienst läuft nach Installation von UPS Pico nicht mehr
Bruno
9. Januar 2016 um 16:10
2
Im Zweifelsfall mal über GDB starten… Dann bekommst du meistens mehr Infos warum es abstürzt
Danke, jetzt weiss ich mal, für was das ist
Sieht jetzt so aus
#0 0xb6e75da8 in ?? () from /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.0.0
#1 0xb6e73924 in OPENSSL_cpuid_setup ()
#2 0xb6fe225e in ?? () from /lib/ld-linux-armhf.so.3
Cannot access memory at address 0x4d52454c
Wenn ich jetzt mehr Ahnung hätte …
Mit ‚continue‘ kannst du die Ausführung fortsetzen; so lange bis gdb dir sagt das der Prozess nicht mehr existiert.
Vielleicht läuft es aber auch erstmal etwas weiter
Oh, da geht ja noch was
Continuing.
*** IP-Symcon starting
16:39:53 | 00000 | Kernel | Creating...
16:39:53 | 00000 | Kernel | IP-Symcon Kernel Version: 4.00
16:39:53 | 00000 | Kernel | IP-Symcon Kernel WorkingDir: /usr/share/symcon/
16:39:53 | 00000 | Kernel | IP-Symcon Kernel SystemDir: /etc/symcon/
16:39:53 | 00000 | Kernel | IP-Symcon Kernel LogDir: /var/log/symcon/
16:39:53 | 00000 | Kernel | IP-Symcon System: linux
16:39:53 | 00000 | Kernel | Boost Version: 1_60
16:39:53 | 00000 | Kernel | cURL Version: libcurl/7.38.0 OpenSSL/1.0.1k zlib/1.2 .8 libidn/1.29 libssh2/1.4.3 librtmp/2.3
16:39:53 | 00000 | Kernel | Git2 Version: 0.23.0
16:39:53 | 00000 | Kernel | SSH2 Version: 1.4.2
16:39:53 | 00000 | Kernel | ZLIB Version: 1.2.7
16:39:53 | 00000 | Kernel | RapidJSON Version: 1.0.2
16:39:53 | 00000 | Kernel | OpenSSL Version: OpenSSL 1.0.1k 8 Jan 2015
16:39:53 | 00000 | Kernel | OpenSSL CertDir: /usr/lib/ssl/certs
16:39:53 | 00000 | Kernel | PHP Version: 5.5.30
16:39:53 | 00000 | Kernel | Initializing...
16:39:53 | 00000 | LocalePool | Creating...
16:39:53 | 00000 | LocalePool | Detected locale: en_US
16:39:53 | 00000 | LocalePool | No translation files found
16:39:53 | 00000 | LicensePool | Creating...
16:39:53 | 00000 | LicensePool | LiveUpdate: 07.01.2016, 07c32b193299
16:39:53 | 00000 | LicensePool | Cannot verify license. Running in Demo mode.
16:39:53 | 00000 | Settings | Creating...
16:39:53 | 00000 | Settings | Loading settings...
16:39:53 | 00000 | Settings | Creating settings thread...
[New Thread 0xb5ac2430 (LWP 1692)]
16:39:53 | 00000 | Settings | Cleaning up Backup Folder...
16:39:54 | 00000 | ObjectManager | Creating...
16:39:54 | 00000 | ObjectManager | Creating root category...
16:39:54 | 00000 | CategoryManager | Creating...
16:39:54 | 00000 | VariableManager | Creating...
16:39:54 | 00000 | InstanceManager | Creating...
16:39:54 | 00000 | ScriptManager | Creating...
16:39:54 | 00000 | EventManager | Creating...
16:39:54 | 00000 | MediaManager | Creating...
16:39:54 | 00000 | LinkManager | Creating...
16:39:54 | 00000 | ModuleLoader | Creating...
16:39:54 | 00000 | FlowHandler | Creating...
16:39:54 | 00000 | ProfilePool | Creating...
16:39:54 | 00000 | ScriptEngine | Creating...
16:39:54 | 00000 | ScriptEngine | Starting 15 script threads...
[New Thread 0xb52c2430 (LWP 1693)]
pure virtual method called
terminate called without an active exception
[New Thread 0xb4ac2430 (LWP 1694)]
Program received signal SIGABRT, Aborted.
[Switching to Thread 0xb52c2430 (LWP 1693)]
0xb69d68e6 in ?? () from /lib/arm-linux-gnueabihf/libc.so.6
Und wie komme ich aus dem gdb wieder raus ? Stand das schon irgendwo ?
EDITH2: Gefunden, Strg + Z
EDITH: Habe gerade was gefunden
RaspberryPi / BananaPi: terminate called without an active exception
Leider unter Ubuntu 13.10 kein Erfolg
EDITH3: Ok, Rasbian ist Wheezy, Lemuntu -> Jessie, bedeutet, daß Symcon nicht vollständig auf Jessie läuft, oder zumindest irgendwelche Startschwierigkeiten hat. Habe gerade keinen freien Raspi um es mal nur mit Jessie zu probieren.
hab eine frische Jessie Installation mit einem jungfräulichen Symcon ohne Probleme zum Laufen bekommen.
Danach von meiner Wheezy Installation alles rüberkopiert… Ip-Adresse gleich… alte Installation runtergefahren, neue hochgefahren … es läuft alles ohne Probleme…
Danke für die Rückmeldung, bei meinem System hat schon der erste Start nicht funktioniert. Mal schauen, wo die Unterschiede sind.
