When I try the example above, it seems to work but Symcon ask me to fill out a password (password required). I have no clue what this password is…and how can I change it?
Thanks!
You may configure an Webhook (see WebHook Control — IP-Symcon :: Automatisierungssoftware) and write a script to be started by this webhook. Within this script you can parse the supplied url parameter and do the desired actions.
