Is there any way to control the CHAZ-01/01? Using the xComfort configurator it shows up as „unknown (55)“. Tried to control it as a normal switching actuator, but that did not work.
According to my documentation you can either connect Channel 0 to send a SetPoint (which you did), or connect Channel1+2 to control a reduction/window contact. At the moment IP-Symcon supports only the second variant, where you can send ON/OFF to each of the datapoints.
