Moin, ich krieg es nicht hin.
Die Auslesedatei wird erzeug und sieht auch so aus wie auf einem alten Windows-ips.
aber ich hab im Log nur das stehen
21.08.2018 21:55:25 | SMA_Gateway | Array
[0] => SBFspot V3.3.1
[1] => Yet another tool to read power production of SMA solar inverters
[2] => (c) 2012-2016, SBF (https://sbfspot.codeplex.com)
[3] => Compiled for Linux (LE) 32 bit
[4] => Commandline Args: -v -finq
[5] => Reading config './SBFspot.cfg'
[6] => Tue Aug 21 21:55:01 2018: INFO: Starting...
[7] => sunrise: 06:27
[8] => sunset : 20:40
[9] => Connecting to Local Network...
[10] => Initializing...
[11] => SUSyID: 125 - SessionID: 980757299 (0x3A752B33)
[12] => Inverter IP address: 192.168.6.12 from SBFspot.cfg
[13] => Logon OK
[14] => SUSyID: 289 - SN: 1261003327
[15] => Device Name: SN: 1261003327
[16] => Device Class: Batterie-Wechselrichter
[17] => Device Type: Sunny Island 6.0H
[18] => Software Version: 04.00.00.R
[19] => Serial number: 1261003327
[20] => SUSyID: 289 - SN: 1261003327
[21] => Batt. Charging Status: 55%
[22] => SUSyID: 289 - SN: 1261003327
[23] => Batt. Temperature: 24.0°C
[24] => Batt. Voltage : 54.20V
[25] => Batt. Current : 40.900A
[26] => SUSyID: 289 - SN: 1261003327
[27] => Device Status: Ok
[28] => SUSyID: 289 - SN: 1261003327
[29] => Device Temperature: 0.0°C
[30] => SUSyID: 289 - SN: 1261003327
[31] => Pac max phase 1: 0W
[32] => Pac max phase 2: 0W
[33] => Pac max phase 3: 0W
[34] => SUSyID: 289 - SN: 1261003327
[35] => Energy Production:
[36] => EToday: 0.000kWh
[37] => ETotal: 0.000kWh
[38] => Operation Time: 0.00h
[39] => Feed-In Time : 0.00h
[40] => SUSyID: 289 - SN: 1261003327
[41] => DC Spot Data:
[42] => String 1 Pdc: 0.000kW - Udc: 0.00V - Idc: 0.000A
[43] => String 2 Pdc: 0.000kW - Udc: 0.00V - Idc: 0.000A
[44] => SUSyID: 289 - SN: 1261003327
[45] => AC Spot Data:
[46] => Phase 1 Pac : 2.000kW - Uac: 233.40V - Iac: 9.000A
[47] => Phase 2 Pac : 0.000kW - Uac: 0.00V - Iac: 0.000A
[48] => Phase 3 Pac : 0.000kW - Uac: 0.00V - Iac: 0.000A
[49] => Total Pac : 2.090kW
[50] => SUSyID: 289 - SN: 1261003327
[51] => Grid Freq. : 50.00Hz
[52] => Terminating here... Dealing with Battery Inverter.
21.08.2018 21:55:25 | SMA_Gateway | Array size = 53
21.08.2018 21:55:25 | SMA_Gateway | Last row=Terminating here... Dealing with Battery Inverter.
21.08.2018 21:55:25 | SMA_Gateway | 'http://localhost/output.txt' incomplete!
Ich habe schon den „INFO : Done“ eingefügt, aber auch das hat nicht geholfen.
Wo liegt mein Fehler?
Bernd
