ich habe mir ein Skript gebaut, mit dem Skript spreche ich meine Überwachungskamera an.
Das Skript funktioniert auch soweit.
Ich steuere in Abhängigkeit von Tag und Nacht und oder Ab.- und Anwesenheit per Switch Anweisung die Kamera.
Ich nutz dazu CURL.
Da ich in einem switch(Case) mehrere Befehle senden will, nutz ich zwischen zwei Befehlen immer IPS(SLEEP).
Nun war es gestern so, als ich manuell das Skript gestartet hatte, lief es nicht mehr durch, die Bearbeitung dauerte Minuten. Ich musste es manuell schließen.
Kann es sein das hier die LAN Verbindung zur Kamera nicht vorhanden war und den Fehler verursachte?
Wenn ja, wie könnte ich diese Verbindung abfragen?
Ist das mit dem CURL und IPS(Sleep) richtig, oder sollte ich das anders machen??
Es ist das erste mal das ich mit CURL Befehle sende.
Hier mein Skript
// Befehle
// Alarmzeiträume alle Aus, also Planer deaktivieren
//$url="http://".$camIP."/param.cgi?cmd=setscheduleex&-ename=md&-week0=NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN&-week1=NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN&-week2=NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN&-week3=NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN&-week4=NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN&-week5=NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN&-week6=NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN&cmd=setbackupschedule&-ename=md&-week0=NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN&-week1=NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN&-week2=NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN&-week3=NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN&-week4=NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN&-week5=NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN&-week6=NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN&-usr={$camUser}&-pwd={$camPass}";
// Alarmzeiträume alle Ein, also Planer aktivieren
//$url="http://".$camIP."/param.cgi?cmd=setscheduleex&-ename=md&-week0=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week1=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week2=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week3=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week4=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week5=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week6=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&cmd=setbackupschedule&-ename=md&-week0=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPN&-week1=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week2=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week3=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week4=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week5=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week6=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-usr={$camUser}&-pwd={$camPass}";
// Alarmbereiche EIN
//$url="http://".$camIP."/param.cgi?cmd=setmdattr&-name=1&-enable=1&cmd=setmdattr&-name=2&-enable=1&cmd=setmdattr&-name=3&-enable=1&cmd=setmdattr&-name=4&-enable=1&-usr={$camUser}&-pwd={$camPass}";
//Alarmbereiche AUS
//$url="http://".$camIP."/param.cgi?cmd=setmdattr&-name=1&-enable=0&cmd=setmdattr&-name=2&-enable=0&cmd=setmdattr&-name=3&-enable=0&cmd=setmdattr&-name=4&-enable=0&-usr={$camUser}&-pwd={$camPass}";
//PIR EIN
//$url="http://".$camIP."/param.cgi?cmd=setpirattr&-pir_enable=1&-usr={$camUser}&-pwd={$camPass}";
//PIR AUS
//$url="http://".$camIP."/param.cgi?cmd=setpirattr&-pir_enable=0&-usr={$camUser}&-pwd={$camPass}";
// EIN Alarm
//$url="http://".$camIP."/param.cgi?cmd=setioattr&-io_enable=1&-usr={$camUser}&-pwd={$camPass}";
// AUS Alarm
//$url="http://".$camIP."/param.cgi?cmd=setioattr&-io_enable=0&-usr={$camUser}&-pwd={$camPass}";
//IRLicht EIN Dauerbetrieb
//$url="http://".$camIP."/param.cgi?cmd=setinfrared&-infraredstat=open&-usr={$camUser}&-pwd={$camPass}";
//IRLicht EIN Automatikbetrieb
//$url="http://".$camIP."/param.cgi?cmd=setinfrared&-infraredstat=auto&-usr={$camUser}&-pwd={$camPass}";
//IRLicht AUS
//$url="http://".$camIP."/param.cgi?cmd=setinfrared&-infraredstat=close&-usr={$camUser}&-pwd={$camPass}";
//Sensibilität Alarmbereich 1 (0-100)
//$url="http://".$camIP."/param.cgi?cmd=setmdattr&-name=1&-s=10&-usr={$camUser}&-pwd={$camPass}";
//Sensibilität Alarmbereich 2 (0-100)
//$url="http://".$camIP."/param.cgi?cmd=setmdattr&-name=2&-s=20&-usr={$camUser}&-pwd={$camPass}";
//Sensibilität Alarmbereich 3 (0-100)
//$url="http://".$camIP."/param.cgi?cmd=setmdattr&-name=3&-s=30&-usr={$camUser}&-pwd={$camPass}";
//Sensibilität Alarmbereich 4 (0-100)
//$url="http://".$camIP."/param.cgi?cmd=setmdattr&-name=4&-s=40&-usr={$camUser}&-pwd={$camPass}";
//IRLicht abfragen
//$url="http://".$camIP."/param.cgi?cmd=getinfrared&-usr={$camUser}&-pwd={$camPass}";
//Video auf SD Card speichern
//$url="http://".$camIP."/param.cgi?cmd=setmdalarm&-aname=record&-switch=on&-usr={$camUser}&-pwd={$camPass}";
//Video nicht auf SD Card speichern
//$url="http://".$camIP."/param.cgi?cmd=setmdalarm&-aname=record&-switch=off&-usr={$camUser}&-pwd={$camPass}";
// KONFIGURATION
$camIP = '192.168.111.111:880'; // IP deiner Webcam
$camUser = 'Xaver'; // Benutzername zum Anmelden an deiner Webcam
$camPass = 'hansguckindieluft'; // Passwort zum Anmelden an deiner Webcam
$Anwesenheit = GetValueBoolean(44682);
$Alarmanlage_Aktiv = GetValueBoolean (18045);
$Es_ist_Tag = GetValueBoolean(43578);
$state = 0;
// Tag oder Nacht ermitteln, sowie die Anwesenheit
if ($Es_ist_Tag == true)
$state = 1; //Es ist Tag
else
$state = 2; // Es ist Nacht
//In Tag oder Nacht springen
switch ($state) {
case 1: //Tagmodus
if (($Anwesenheit == true) and ($Alarmanlage_Aktiv == false ))
//Wenn Anwesend dann Alarmplaner der Kamera Einfahrt deaktivieren
$curl = curl_init($url);
curl_setopt($curl, CURLOPT_RETURNTRANSFER, TRUE);
curl_setopt($curl, CURLOPT_USERAGENT,'Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1.13) Gecko/20080311 Firefox/2.0.0.13');
$page = curl_exec($curl);
curl_close($curl);
IPS_Sleep(500);
$Response = $page;
// Video nicht auf SD speichern
curl_close($curl);
IPS_Sleep(500);
$Response = $page;
else
{ //Wenn nicht Anwesend dann Alarmplaner der Kamera Einfahrt aktivieren
curl_close($curl);
IPS_Sleep(500);
$Response = $page;
curl_close($curl);
IPS_Sleep(500);
$Response = $page;
// Video auf SD speichern
curl_close($curl);
IPS_Sleep(500);
$Response = $page;
$url="http://".$camIP."/param.cgi?cmd=setmdattr&-name=1&-s=60&-usr={$camUser}&-pwd={$camPass}";
curl_close($curl);
IPS_Sleep(500);
$Response = $page;
$url="http://".$camIP."/param.cgi?cmd=setmdattr&-name=2&-s=60&-usr={$camUser}&-pwd={$camPass}";
curl_close($curl);
IPS_Sleep(500);
$Response = $page;
$url="http://".$camIP."/param.cgi?cmd=setmdattr&-name=3&-s=60&-usr={$camUser}&-pwd={$camPass}";
curl_close($curl);
IPS_Sleep(500);
$Response = $page;
$url="http://".$camIP."/param.cgi?cmd=setmdattr&-name=4&-s=60&-usr={$camUser}&-pwd={$camPass}";
curl_close($curl);
IPS_Sleep(500);
$Response = $page;
break;
case 2: //Nachtmodus
//Wenn Anwesend dann Alarmplaner der Kamera Einfahrt aktivieren
curl_close($curl);
IPS_Sleep(500);
$Response = $page;
curl_close($curl);
IPS_Sleep(500);
$Response = $page;
curl_close($curl);
IPS_Sleep(500);
$Response = $page;
$url="http://".$camIP."/param.cgi?cmd=setmdattr&-name=1&-s=45&-usr={$camUser}&-pwd={$camPass}";
curl_close($curl);
IPS_Sleep(500);
$Response = $page;
$url="http://".$camIP."/param.cgi?cmd=setmdattr&-name=2&-s=45&-usr={$camUser}&-pwd={$camPass}";
curl_close($curl);
IPS_Sleep(500);
$Response = $page;
$url="http://".$camIP."/param.cgi?cmd=setmdattr&-name=3&-s=45&-usr={$camUser}&-pwd={$camPass}";
curl_close($curl);
IPS_Sleep(500);
$Response = $page;
$url="http://".$camIP."/param.cgi?cmd=setmdattr&-name=4&-s=45&-usr={$camUser}&-pwd={$camPass}";
curl_close($curl);
IPS_Sleep(500);
$Response = $page;
break;
print_r ($page);
var_dump($Alarmanlage_Aktiv);
var_dump($state);
Danke.
