RPI Python Script start / stop über Switch IPS steuern
Moin zusammen,
ich brauche mal wieder eure Hilfe. Ich möchte bei mir eine Lichterwand per Homematic Switch an und aus schalten. Generell kein Problem :smiley: Aber … das ganze will ich über ein Python Script steuern, weil da halt ein kontinuierlicher Farbwechsel drin ist.
Starten kann ich das ganze mit
sudo python examples/script.py -c &
sollte also wie folgt aufrufbar sein
shell_exec("sudo python examples/script.py -c &");
Das Script ist das hier :
Script:
#!/usr/bin/env python3
# NeoPixel library strandtest example
# Author: Tony DiCola (tony@tonydicola.com)
# Direct port of the Arduino NeoPixel library strandtest example.  Showcases
# various animations on a strip of NeoPixels.
import time
from neopixel import *
import argparse
# LED strip configuration:
LED_COUNT      = 16      # Number of LED pixels.
LED_PIN        = 18      # GPIO pin connected to the pixels (18 uses PWM!).
#LED_PIN        = 10      # GPIO pin connected to the pixels (10 uses SPI /dev/spidev0.0).
LED_FREQ_HZ    = 800000  # LED signal frequency in hertz (usually 800khz)
LED_DMA        = 10      # DMA channel to use for generating signal (try 10)
LED_BRIGHTNESS = 255     # Set to 0 for darkest and 255 for brightest
LED_INVERT     = False   # True to invert the signal (when using NPN transistor level shift)
LED_CHANNEL    = 0       # set to '1' for GPIOs 13, 19, 41, 45 or 53
# Define functions which animate LEDs in various ways.
def colorWipe(strip, color, wait_ms=50):
    """Wipe color across display a pixel at a time."""
    for i in range(strip.numPixels()):
        strip.setPixelColor(i, color)
        strip.show()
        time.sleep(wait_ms/1000.0)
def theaterChase(strip, color, wait_ms=50, iterations=10):
    """Movie theater light style chaser animation."""
    for j in range(iterations):
        for q in range(3):
            for i in range(0, strip.numPixels(), 3):
                strip.setPixelColor(i+q, color)
            strip.show()
                strip.setPixelColor(i+q, 0)
def wheel(pos):
    """Generate rainbow colors across 0-255 positions."""
    if pos < 85:
        return Color(pos * 3, 255 - pos * 3, 0)
    elif pos < 170:
        pos -= 85
        return Color(255 - pos * 3, 0, pos * 3)
    else:
        pos -= 170
        return Color(0, pos * 3, 255 - pos * 3)
def rainbow(strip, wait_ms=20, iterations=1):
    """Draw rainbow that fades across all pixels at once."""
    for j in range(256*iterations):
            strip.setPixelColor(i, wheel((i+j) & 255))
        strip.show()
def rainbowCycle(strip, wait_ms=20, iterations=5):
    """Draw rainbow that uniformly distributes itself across all pixels."""
            strip.setPixelColor(i, wheel((int(i * 256 / strip.numPixels()) + j) & 255))
        strip.show()
def theaterChaseRainbow(strip, wait_ms=50):
    """Rainbow movie theater light style chaser animation."""
    for j in range(256):
        for q in range(3):
                strip.setPixelColor(i+q, wheel((i+j) % 255))
            strip.show()
# Main program logic follows:
if __name__ == '__main__':
    # Process arguments
    parser = argparse.ArgumentParser()
    parser.add_argument('-c', '--clear', action='store_true', help='clear the display on exit')
    args = parser.parse_args()
    # Create NeoPixel object with appropriate configuration.
    strip = Adafruit_NeoPixel(LED_COUNT, LED_PIN, LED_FREQ_HZ, LED_DMA, LED_INVERT, LED_BRIGHTNESS, LED_CHANNEL)
    # Intialize the library (must be called once before other functions).
    strip.begin()
    print ('Press Ctrl-C to quit.')
    if not args.clear:
        print('Use "-c" argument to clear LEDs on exit')
    try:
        while True:
            print ('Color wipe animations.')
            colorWipe(strip, Color(255, 0, 0))  # Red wipe
            colorWipe(strip, Color(0, 255, 0))  # Blue wipe
            colorWipe(strip, Color(0, 0, 255))  # Green wipe
            print ('Theater chase animations.')
            theaterChase(strip, Color(127, 127, 127))  # White theater chase
            theaterChase(strip, Color(127,   0,   0))  # Red theater chase
            theaterChase(strip, Color(  0,   0, 127))  # Blue theater chase
            print ('Rainbow animations.')
            rainbow(strip)
            rainbowCycle(strip)
            theaterChaseRainbow(strip)
    except KeyboardInterrupt:
        if args.clear:
            colorWipe(strip, Color(0,0,0), 10)
Somit läuft das Ding erst mal im Hintergrund. Das -C wäre wenn im zweifel dafür … wenn ich per SSH in der Console bleibe beim Raspberry um das Script dann zu stoppen und die Lampen wieder auszuschalten.
Jetzt meine Frage, die Lampen anschalten sollte kein Problem sein, aber wie kriege ich sie aus ?
Meine erste Überlegung war auch erst den Befehl zu senden, und dann den Prozess zu killen, aber leider erhält der ja immer eine neue Nummer :0/
Ich hoffe es ist so einigermaßen verständlich was für ein Problem ich habe :stuck_out_tongue:
Vg
Andreas
Hi!
Killen wäre so in der Richtung über einen Einzeiler möglich:
exec("kill $(ps aux | grep '[p]ython script.py' | awk '{print $2}')");
…ggf. noch ein wenig Anpassung notwendig.
Edit: Alternativ könntest du auch mit „pkill“ arbeiten…
Chris
Danke Chris !
Versuche ich heute Abend gleich mal :0)
Vg
Andreas
