ich seh bei mir immer noch keine E-Mails. Liste leer, keine neuen Nachrichten, keine letzten Nachrichten
TXT: 15.02.2016 11:23:28.00 | TEXT | About to connect() to w00721fe.kasserver.com port 993 (#0)
TXT: 15.02.2016 11:23:28.00 | TEXT | Trying 85.13.135.16…
TXT: 15.02.2016 11:23:29.00 | TEXT | connected
TXT: 15.02.2016 11:23:29.00 | TEXT | Connected to w00721fe.kasserver.com (85.13.135.16) port 993 (#0)
TXT: 15.02.2016 11:23:29.00 | TEXT | successfully set certificate verify locations:
TXT: 15.02.2016 11:23:29.00 | TEXT | CAfile: none<LF> CApath: /etc/ssl/certs
TXT: 15.02.2016 11:23:29.00 | TEXT | SSLv3, TLS handshake, Client hello (1):
TXT: 15.02.2016 11:23:29.00 | TEXT | SSLv3, TLS handshake, Server hello (2):
TXT: 15.02.2016 11:23:29.00 | TEXT | SSLv3, TLS handshake, CERT (11):
TXT: 15.02.2016 11:23:29.00 | TEXT | SSLv3, TLS handshake, Server key exchange (12):
TXT: 15.02.2016 11:23:29.00 | TEXT | SSLv3, TLS handshake, Server finished (14):
TXT: 15.02.2016 11:23:29.00 | TEXT | SSLv3, TLS handshake, Client key exchange (16):
TXT: 15.02.2016 11:23:29.00 | TEXT | SSLv3, TLS change cipher, Client hello (1):
TXT: 15.02.2016 11:23:29.00 | TEXT | SSLv3, TLS handshake, Finished (20):
TXT: 15.02.2016 11:23:29.00 | TEXT | SSL connection using ECDHE-RSA-AES128-GCM-SHA256
TXT: 15.02.2016 11:23:29.00 | TEXT | Server certificate:
TXT: 15.02.2016 11:23:29.00 | TEXT | subject: C=DE; postalCode=02742; ST=Sachsen; L=Friedersdorf; street=Hauptstraße 68; O=kasserver.com; OU=kasserver.com; OU=Authorized by United SSL; OU=PremiumSSL Wildcard; CN=*.kasserver.com
TXT: 15.02.2016 11:23:29.00 | TEXT | start date: 2014-06-06 00:00:00 GMT
TXT: 15.02.2016 11:23:29.00 | TEXT | expire date: 2017-07-04 23:59:59 GMT
TXT: 15.02.2016 11:23:29.00 | TEXT | subjectAltName: w00721fe.kasserver.com matched
TXT: 15.02.2016 11:23:29.00 | TEXT | issuer: C=GB; ST=Greater Manchester; L=Salford; O=COMODO CA Limited; CN=COMODO RSA Organization Validation Secure Server CA
TXT: 15.02.2016 11:23:29.00 | TEXT | SSL certificate verify ok.
TXT: 15.02.2016 11:23:29.00 | TEXT | IMAP 0x29f8c80 state change from STOP to SERVERGREET
TXT: 15.02.2016 11:23:29.00 | HEADER IN | * OK [CAPABILITY IMAP4rev1 LITERAL+ SASL-IR LOGIN-REFERRALS ID ENABLE IDLE XLIST AUTH=PLAIN AUTH=LOGIN] kasserver.com mailserver ready.
TXT: 15.02.2016 11:23:29.00 | HEADER OUT | B LOGIN ******* *********
TXT: 15.02.2016 11:23:29.00 | TEXT | IMAP 0x29f8c80 state change from SERVERGREET to LOGIN
TXT: 15.02.2016 11:23:29.00 | HEADER IN | B OK [CAPABILITY IMAP4rev1 LITERAL+ SASL-IR LOGIN-REFERRALS ID ENABLE IDLE SORT SORT=DISPLAY THREAD=REFERENCES THREAD=REFS THREAD=ORDEREDSUBJECT MULTIAPPEND URL-PARTIAL CATENATE UNSELECT CHILDREN NAMESPACE UIDPLUS LIST-EXTENDED I18NLEVEL=1 CONDSTORE QRESYNC ESEARCH ESORT SEARCHRES WITHIN CONTEXT=SEARCH LIST-STATUS BINARY MOVE XLIST] Logged in
TXT: 15.02.2016 11:23:29.00 | TEXT | IMAP 0x29f8c80 state change from LOGIN to STOP
TXT: 15.02.2016 11:23:29.00 | TEXT | DO phase starts
TXT: 15.02.2016 11:23:29.00 | HEADER OUT | C SELECT INBOX
TXT: 15.02.2016 11:23:29.00 | TEXT | IMAP 0x29f8c80 state change from STOP to SELECT
TXT: 15.02.2016 11:23:29.00 | HEADER IN | * FLAGS (\Answered \Flagged \Deleted \Seen \Draft Junk NonJunk $MDNSent $Forwarded $label4 $Junk erledigt $NotJunk)
TXT: 15.02.2016 11:23:29.00 | HEADER IN | * OK [PERMANENTFLAGS (\Answered \Flagged \Deleted \Seen \Draft Junk NonJunk $MDNSent $Forwarded $label4 $Junk erledigt $NotJunk *)] Flags permitted.
TXT: 15.02.2016 11:23:29.00 | HEADER IN | * 1068 EXISTS
TXT: 15.02.2016 11:23:29.00 | HEADER IN | * 0 RECENT
TXT: 15.02.2016 11:23:29.00 | HEADER IN | * OK [UNSEEN 1068] First unseen.
TXT: 15.02.2016 11:23:29.00 | HEADER IN | * OK [UIDVALIDITY 1158657802] UIDs valid
TXT: 15.02.2016 11:23:29.00 | HEADER IN | * OK [UIDNEXT 19482] Predicted next UID
TXT: 15.02.2016 11:23:29.00 | HEADER IN | * OK [HIGHESTMODSEQ 35506] Highest
TXT: 15.02.2016 11:23:29.00 | HEADER IN | C OK [READ-WRITE] Select completed (0.001 secs).
TXT: 15.02.2016 11:23:29.00 | HEADER OUT | D FETCH 1 BODY[TEXT]
TXT: 15.02.2016 11:23:29.00 | TEXT | IMAP 0x29f8c80 state change from SELECT to FETCH
TXT: 15.02.2016 11:23:29.00 | HEADER IN | * 1 FETCH (BODY[TEXT] {241}
TXT: 15.02.2016 11:23:29.00 | TEXT | Found 241 bytes to download
TXT: 15.02.2016 11:23:29.00 | TEXT | Filesize left: 0
TXT: 15.02.2016 11:23:29.00 | TEXT | IMAP 0x29f8c80 state change from FETCH to STOP
TXT: 15.02.2016 11:23:29.00 | TEXT | DO phase is complete
TXT: 15.02.2016 11:23:29.00 | TEXT | Connection #0 to host w00721fe.kasserver.com left intact
TXT: 15.02.2016 11:23:29.00 | EXISTS | 1068
TXT: 15.02.2016 11:23:29.00 | TEXT | Re-using existing connection! (#0) with host (nil)
TXT: 15.02.2016 11:23:29.00 | TEXT | Connected to (nil) (85.13.135.16) port 993 (#0)
TXT: 15.02.2016 11:23:29.00 | HEADER OUT | A SELECT INBOX
TXT: 15.02.2016 11:23:29.00 | HEADER IN | )
TXT: 15.02.2016 11:23:29.00 | HEADER IN | D OK Fetch completed (0.001 secs).
TXT: 15.02.2016 11:23:29.00 | HEADER IN | * OK [CLOSED] Previous mailbox closed.
TXT: 15.02.2016 11:23:29.00 | HEADER IN | A OK [READ-WRITE] Select completed (0.000 secs).
TXT: 15.02.2016 11:23:29.00 | HEADER OUT | B FETCH 1 BODY[TEXT]
TXT: 15.02.2016 11:23:29.00 | TEXT | Connection #0 to host (nil) left intact
TXT: 15.02.2016 11:23:29.00 | HEADER OUT | C LOGOUT
TXT: 15.02.2016 11:23:29.00 | TEXT | IMAP 0x29f8c80 state change from STOP to LOGOUT
TXT: 15.02.2016 11:23:29.00 | HEADER IN | B OK Fetch completed (0.001 secs).
TXT: 15.02.2016 11:23:29.00 | HEADER IN | * BYE Logging out
TXT: 15.02.2016 11:23:29.00 | HEADER IN | C OK Logout completed.
TXT: 15.02.2016 11:23:29.00 | TEXT | IMAP 0x29f8c80 state change from LOGOUT to STOP
TXT: 15.02.2016 11:23:29.00 | TEXT | Closing connection #0
TXT: 15.02.2016 11:23:29.00 | TEXT | SSLv3, TLS alert, Client hello (1):
