IP-SYMCON Event Scripting
File : SET_FHT_CLOCK.ips.php
Trigger : Timer
Interval : call it once per hour , but not at the full hour, use a custom timer or call the it every 30 minutes :)
Purpose : Set clock of all FHT'S once every n days
Version : 2
- updates only minute value
- waits for timeslot to be ready to set time
- doesnt run between between 5 minutes beofre and after full hour
require_once("globals_functions.ips.php");
// define how often clock should be set, every N days
$NDAYS = 3;
// we need this variables, to be created if needed
if (IPS_VariableExists (20887 /*[Home\FHT_SET_MINUTE_FHTID]*/) == false)
// this is the ID of FHT that needs setting
IPS_CreateVariable (20887 /*[Home\FHT_SET_MINUTE_FHTID]*/,'Integer');
if (GetValueInteger (20887 /*[Home\FHT_SET_MINUTE_FHTID]*/) > 0 )
// there is a minute set command waiting, so we send it
$FHT_ID = GetValueInteger ('FHT_SET_MINUTE_FHTID');
// this is te FHT to send to
FHT_SetMinute ($FHT_ID, intval(date('i')));
SetValueInteger (20887 /*[Home\FHT_SET_MINUTE_FHTID]*/,0);
// switch off the timer
IPS_SetScriptTimer ('SET_FHT_CLOCK',0);
$LOGMSG = 'Command sent to ' . $FHT_ID . ' - Set Minute to ' . date('i') ;
IPS_LogMessage ('Update FHT Clock', $LOGMSG);
return;
// there is no minute set command waiting, so we can check for FTH'" that need an update
if (intval(date('i')) > 5 )
if (intval(date('i')) < 55 )
// setting the minute at the full hour may cause undesired results (set 10:59 to 10:00 for example)
// loop thourgh all IPS instances
//$INSTANCE_LIST=(IPS_GetInstanceIDs());
$INSTANCE_LIST=(IPS_GetInstanceList());
// find FHZ and check if enough free buffers
foreach($INSTANCE_LIST as $IPS_INSTANCE)
// Get the Module Instance
$MODULE_INSTANCE=IPS_GetModuleInstance($IPS_INSTANCE);
// check if this is the FHZ
if ($MODULE_INSTANCE['moduleguid'] =='{57040540-4432-4220-8D2D-4676B57E223D}')
// check if all 10 buffers free , otherwise our command maybe not the first in queue to the FHT we want to set and is then sent to late
$FREE_BUFFERS = FHZ_GetFreeFHTBuffer($MODULE_INSTANCE['instanceid']) ;
if ($FREE_BUFFERS == 10 )
// find the FHT's
$CONNECTED_INSTANCES=IPS_GetModuleInstanceConnections($IPS_INSTANCE);
foreach($CONNECTED_INSTANCES as $IPS_INSTANCE)
// Get the module instance
// check if this is a FHT
if ($MODULE_INSTANCE['moduleguid'] =='{A89F8DFA-A439-4BF1-B7CB-43D047208DDD}')
// this is the variable that remembers when FHT clock was last set
$LAST_CLOCK_VARNAME = 'FHT_LAST_CLOCK_SET_' . $MODULE_INSTANCE['instanceid'];
if (IPS_VariableExists ($LAST_CLOCK_VARNAME) == false )
// if the variable doesnt exist, then we create it
IPS_CreateVariable ($LAST_CLOCK_VARNAME,'Integer');
// set it to n days ago plus one second to trigger an immediate update
SetValueInteger ($LAST_CLOCK_VARNAME, (TIME() - ($NDAYS * 86400) - 1));
// read when clock was set
$LAST_CLOCK_SET =GetValueInteger ($LAST_CLOCK_VARNAME);
// if last update more than n days ago then send time to fht
if (TIME() - $LAST_CLOCK_SET > ($NDAYS * 86400))
$INSTANCE_DATA=IPS_GetInstanceSettings ($MODULE_INSTANCE['instanceid']);
// find the variable that tracks the position values
$STELL_VARIABLE_NAME = preg_match( '#PositionVar.*"(.*)"#', $INSTANCE_DATA, $m) ? $m[1] : '';
// check wehn it was last received
$LAST_STELL_UPDATE =IPS_GetUpdateTime ($STELL_VARIABLE_NAME);
// Positions come about every 116 seconds, this is the time left until the next pos comes.
// a tx timeslot is available just before, so we send our command 5 beofre the slot is open
// if the commands are sent to late , then change this value (111) a bit
$MINUTE_TO_SET = 111- (TIME() -$LAST_STELL_UPDATE );
if ($MINUTE_TO_SET < 15)
// to close to next timeslot, better take the next one
$MINUTE_TO_SET=$MINUTE_TO_SET + 116;
// we rememeber the FHT we need the miute to send to
SetValueInteger ('FHT_SET_MINUTE_FHTID',intval($MODULE_INSTANCE['instanceid']));
// we call ourselves just before the timeslot is ready
IPS_SetScriptTimer ('SET_FHT_CLOCK',intval( $MINUTE_TO_SET));
// update the Variable that remebers last time setting for this FHT
SetValueInteger ($LAST_CLOCK_VARNAME,TIME());
$LOGMSG = 'Set Minute Command queued to be sent to ' . $MODULE_INSTANCE['instanceid'] . ' in ' . $MINUTE_TO_SET . ' seconds';
// done
return;
warum so kompliziert? Ich lasse folgendes Script einmal pro Tag (irgendwann in der Nacht) durchlaufen. Damit werden die FHT einmal im Monat syncronisiert. Mir reicht das.
$day = (int) date("d");
$fht = array(12345,23456,34567,45678,56789);// hier die ID's der FHT's eintragen
if ($day <= count($fht))FHT_SetMinute($fht[$day-1],(int)date("i"));
