ich habe mal ein Demo-Script gebaut, was rein über PHP an den T-10 angeschlossene Geräte im Preset-Modus steuern und Auslesen kann.
Für PHP-Anfänger sind vieleicht die Funktionen zur Nutzung von UDP-Sockets oder der C-Strukturen interessant.
Have Fun!
Tommi
EZConsole.php
PHP-demo functions to set and get status of EZcontrolT-10 controlled devices
(C) 2006 Thomas Dreßler
development has been guided by the following code :
(taken from http://www.ezcontrol.de)
* ezcontrol.c - UDP control program for EZcontrol T-10
* actorpoll.c - UDP actor poll program for EZcontrol T-10
* Copyright (c) 2005 Rose + Herleth GbR. All rights reserved.
* Conditions of Use:
* For free use in commercial and non-commercial software but only
* to communicate with Rose+Herleth GbR EZcontrol devices.
* Use in firmware of third-party hardware only with written approval
* of Rose+Herleth GbR.
structure definitions used:
struct config_pakets {
uint16_t teletype;
uint16_t type; // Aktor, Sensor, Script
uint16_t n; // Speicherplatznr.
char descr[32];
uint16_t reserved1[7];
uint16_t system;
uint16_t hc;
uint16_t hc2;
uint16_t address;
int16_t value1;
int16_t value2;
int16_t value3;
int16_t value4; // zustand des aktors
float fvalue1;
float fvalue2;
float fvalue3;
float fvalue4;
uint16_t astype; // art des sensors/aktors
uint16_t status;
uint16_t reserved2[3];
uint16_t reserved3[129];
typedef struct
u16_t crc;
u16_t type;
u16_t errortype;
} frame_error;
typedef struct
u16_t crc;
u16_t type;
u16_t switchno;
u16_t value;
} frame_use_preset;
function chksum($data)
$sum = 0;
foreach ($data as $d) {
$sum += $d;
if($sum < $d) {
$sum++;
return $sum;
function print_packet($text,$len) {
$tbuffer="";
for($i=0;$i<$len;$i++) {
$tbuffer.=" ".sprintf("%02x",ord($text[$i]));
return $tbuffer;
function set_status($host,$device,$status){
$value=$status?255:0; //on/off translate to 0/255
//defines
$error_format="v3val";//(crc),type,errortype
$preset_format="vvvv";//(crc),type,switch-1,value(0=aus oder 255=ein)
$preset=0xab01;
$port=7042;
$timeout=3;
$buffersize=1500;
//prepare buffer
$buffer=str_pad ('', $buffersize,chr(0));
// create the socket
$socket = socket_create(AF_INET, SOCK_DGRAM,SOL_UDP);
// set socket receive timeout to $timeout seconds
socket_set_option($socket, SOL_SOCKET, SO_RCVTIMEO, array("sec" => $timeout, "usec" => 0));
//prepare packet structure
$frame[0]=$preset;
$frame[1]=$device-1;
$frame[2]=$value;
$crc=chksum($frame);
$packet=pack($preset_format,$crc,$frame[0],$frame[1],$frame[2]);
$len=strlen($packet);
$x=print_packet($packet,$len);
//send the packet without connection
socket_sendto($socket,$packet,$len,0,$host,$port);
//prepare reading answer
$read=array($socket);
$i=0;
do {
$i++;
$r=socket_sendto($socket,$packet,$len,0,$host,$port);
if($r===false) {
printf("sendto error
socket_close($socket);
exit;
$r=socket_select($read, $write = NULL, $except = NULL, 0);
} while(($i<4)&&($r===false));
if($i<4) {
// get the UDPdata with the sender's IP/port
$len = socket_recvfrom($socket, $buffer, $buffersize, 0,$host, $port);
if($len<0) {
printf("recvfrom error
exit;
} else {
//unpack packet structur frame_error
$y= print_packet($buffer,strlen($buffer));
$frame=unpack($error_format,$buffer);
$crc=$frame['val1'];
array_shift($frame);
$type=$frame['val2'];
$errortype=$frame['val3'];
//echo "Send:$x
//echo "Receive:$y
if ( ($crc==chksum($frame)) && ($errortype==0)) {
echo "Ezcontrol accept Command!
}else {
echo "Command or checksum error!
} else {
printf("No answer, max tries exeeded...
exit;
function get_status($host,$device) {
//defines
$GET_PORT=7044;
$GET_KEY=0x6711;
$GET_SENSOR=0x1;
$GET_ACTOR=0x2;
$timeout=3;
$buffersize=1500;
//prepare packet structure config_pakets
$size=352; //packet size structure config_pakets
$tt=$GET_KEY;
$type=$GET_ACTOR;
$header=pack("vvv",$GET_KEY,$GET_ACTOR,$device-1);
$packet=str_pad($header,$size-6,chr(0)).pack("vvv",0xffff,0,0);
//echo "Send2:".print_packet($packet,$size)."
// set socket receive timeout to 3 second */
//4 trys to send and ask for answer packet
$i=0;
do {
$i++;
$r=socket_sendto($socket,$packet,$size,0,$host,$GET_PORT);
if($r===false) {
exit;
if($i<4) {
//answer packet avaiable, read it
$len=socket_recvfrom($socket, $buffer, $buffersize, 0,$host,$GET_PORT);
if($len<0) {
exit;
} else {
//packet received, now decoding structure config_packets
//echo "rec2:".print_packet($buffer,$size)."
$frame=unpack("v3sys/a32char/v15val",substr($buffer,0,68));
$desc=$frame['char'];
$system=$frame['val8'];
$hc1=$frame['val9'];
$hc2=$frame['val10'];
$addr=$frame['val11'];
$value1=$frame['val12'];
$value4=$frame['val15'];
$extra=unpack("f4fval/v2val",substr($buffer,68,20));
//print it
printf("Answer: TeleType %d, Type %d, Speicher %d
", $frame['sys1'],$frame['sys2'],$frame['sys3']);
printf("Description: %s System %d, hc1 %d, hc2 %d, adr %d, Status %d
", $desc, $system, $hc1, $hc2, $addr, $value4);
printf("fvalue1-4: %f, %f, %f, %f astype %d, Status %d
", $extra['fval1'],$extra['fval2'],$extra['fval3'],$extra['fval4'],$extra['val1'],$extra['val2']);
} else {
exit;
//main program (demo)
$host="ezcontrol"; //or ip-address
$device=7; //preset device number
$value=false; //on/off
set_status($host,$device,$value);
sleep(2);
get_status($host,$device);
