Hallo alle,
meine Abfrage des Enigma Receivers erzeugt seit kurzem folgende Fehlermeldung:
Warning: SimpleXMLElement::__construct(): Entity: line 1649: parser error : PCDATA invalid Char value 26 in E:\IP-Symcon\scripts\54515.ips.php on line 52
Warning: SimpleXMLElement::__construct(): Sean OBryan (Ron Donahue) in E:\IP-Symcon\scripts\54515.ips.php on line 52
Warning: SimpleXMLElement::__construct(): ^ in E:\IP-Symcon\scripts\54515.ips.php on line 52
Fatal error: Uncaught exception 'Exception' with message 'String could not be parsed as XML' in E:\IP-Symcon\scripts\54515.ips.php:52
Stack trace:
#0 E:\IP-Symcon\scripts\54515.ips.php(52): SimpleXMLElement->__construct('<?xml version="...')
#1 {main}
thrown in E:\IP-Symcon\scripts\54515.ips.php on line 52
hier im PHP-Code erste Zeile = Zeile 52:
$xmlResult2 = new SimpleXMLElement(file_get_contents("http://192.168.178.37:8037/web/epgservice?sRef=$reference"));
$title2 = utf8_decode($xmlResult2->e2event->e2eventtitle);
$description2 = utf8_decode($xmlResult2->e2event->e2eventdescriptionextended);
$startsec = $xmlResult2->e2event->e2eventstart;
$duration = $xmlResult2->e2event->e2eventduration;
$currenttime = time();
