Moin…
… seit dem Update auf die 4.0 habe ich Probleme mit dem Logging meines Heizungsverbrauch bzw, mit den Daten.
Es ist eine Zählervariable die Nachts auf 0 gesetzt wird.
Ich hole mir die Daten mit:
$archiveID = 10690 /*[Archive Handler]*/; // Archive-Handler-ID angeben
$varID = 26213 /*[SMARTMETERING\HEIZUNG\Verbrauch Heute]*/; // Variablen-ID der Ns-Zähler-Variable
$rawData = AC_GetAggregatedValues($archiveID, $varID, 1, $ts, $te, 0);
print_r($rawData);
Die Ausgabe sieht so aus:
Array
[0] => Array
[TimeStamp] => 1469714400
[Avg] => 0
[MinTime] => 1469714447
[Min] => 0
[MaxTime] => 1469714447
[Max] => 0
[1] => Array
[TimeStamp] => 1469710800
[Avg] => 0
[MinTime] => 1469713398
[Min] => 0
[MaxTime] => 1469713398
[Max] => 0
[2] => Array
[TimeStamp] => 1469707200
[Avg] => 0
[MinTime] => 1469707200
[Min] => 0
[MaxTime] => 1469707200
[Max] => 0
[3] => Array
[TimeStamp] => 1469703600
[Avg] => 0
[MinTime] => 1469703600
[Min] => 0
[MaxTime] => 1469703600
[Max] => 0
[4] => Array
[TimeStamp] => 1469700000
[Avg] => 0
[MinTime] => 1469700000
[Min] => 0
[MaxTime] => 1469700000
[Max] => 0
[5] => Array
[TimeStamp] => 1469696400
[Avg] => 0
[MinTime] => 1469697189
[Min] => 0
[MaxTime] => 1469697189
[Max] => 0
[6] => Array
[TimeStamp] => 1469692800
[Avg] => 0
[MinTime] => 1469692800
[Min] => 0
[MaxTime] => 1469692800
[Max] => 0
[7] => Array
[TimeStamp] => 1469689200
[Avg] => 0
[MinTime] => 1469689200
[Min] => 0
[MaxTime] => 1469689200
[Max] => 0
[8] => Array
[TimeStamp] => 1469685600
[Avg] => 0
[MinTime] => 1469685600
[Min] => 0
[MaxTime] => 1469685600
[Max] => 0
[9] => Array
[TimeStamp] => 1469682000
[Avg] => 0
[MinTime] => 1469682000
[Min] => 0
[MaxTime] => 1469682000
[Max] => 0
[10] => Array
[TimeStamp] => 1469678400
[Avg] => 0
[MinTime] => 1469678400
[Min] => 0
[MaxTime] => 1469678400
[Max] => 0
[11] => Array
[TimeStamp] => 1469674800
[Avg] => 0
[MinTime] => 1469674800
[Min] => 0
[MaxTime] => 1469674800
[Max] => 0
[12] => Array
[TimeStamp] => 1469671200
[Avg] => 0
[MinTime] => 1469671200
[Min] => 0
[MaxTime] => 1469671200
[Max] => 0
[13] => Array
[TimeStamp] => 1469667600
[Avg] => 0
[MinTime] => 1469667600
[Min] => 0
[MaxTime] => 1469667600
[Max] => 0
[14] => Array
[TimeStamp] => 1469664000
[Avg] => 0
[MinTime] => 1469664000
[Min] => 0
[MaxTime] => 1469664000
[Max] => 0
[15] => Array
[TimeStamp] => 1469660400
[Avg] => 0
[MinTime] => 1469660400
[Min] => 0
[MaxTime] => 1469660400
[Max] => 0
[16] => Array
[TimeStamp] => 1469656800
[Avg] => 0
[MinTime] => 1469656800
[Min] => 0
[MaxTime] => 1469656800
[Max] => 0
Es sind jedoch Daten geschrieben. Vor dem Update auf die 4.0 habe ich die Daten angezeigt bekommen… auch wenn es kleine Werte waren.
Wo liegt das Problem?
Gruß,
Peter
EDIT: Der Max-Wert von Array „0“ müsste eigentlich eine 1 sein. Der MaxTime-Timestamp ist 11:13.09 / 28.07.2016 wie auf dem Screenshot!
