Hallo Liebe Community, leider bekomme ich bei der Installation folgende Fehlermeldung:
pi@raspberrypi ~ $ sudo apt-get install symcon
Reading package lists… Done
Building dependency tree
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
symcon : Depends: php5-cli but it is not installable
Depends: php5-curl but it is not installable
Depends: php5-gd but it is not installable
Depends: php5-imap but it is not installable
E: Unable to correct problems, you have held broken packages.
Kann leider nicht upgraden… der Raspi bleibt stehen… habe IPV6 aktiviert
IDo you want to continue [Y/n]? y
(Reading database … 79344 files and directories currently installed.)
Preparing to replace symcon 0.1-184 (using …/symcon_0.1-186_armhf.deb) …
IP-Symcon is running.
Stopping…
