Hm was mach ich denn falsch?
Ich versuche mit
$plexjson = file_get_contents('php://input');
$data = json_decode($plexjson);
an den payload zu kommen, aber der Array ist leer.
Wenn ich das selber teste indem ich mal was an den Hook schicke mit
$connect = "https://myserverurl";
$plexhook = "hook/plex";
$data = '{
"event": "media.play",
"user": true,
"owner": true,
"Account": {
"id": 1,
"thumb": "https://plex.tv/users/1022b120ffbaa/avatar?c=1465525047",
"title": "elan"
"Server": {
"title": "Office",
"uuid": "54664a3d8acc39983675640ec9ce00b70af9cc36"
"Player": {
"local": true,
"publicAddress": "200.200.200.200",
"title": "Plex Web (Safari)",
"uuid": "r6yfkdnfggbh2bdnvkffwbms"
"Metadata": {
"librarySectionType": "artist",
"ratingKey": "1936545",
"key": "/library/metadata/1936545",
"parentRatingKey": "1936544",
"grandparentRatingKey": "1936543",
"guid": "com.plexapp.agents.plexmusic://gracenote/track/7572499-91016293BE6BF7F1AB2F848F736E74E5/7572500-3CBAE310D4F3E66C285E104A1458B272?lang=en",
"librarySectionID": 1224,
"type": "track",
"title": "Love The One You\'re With",
"grandparentKey": "/library/metadata/1936543",
"parentKey": "/library/metadata/1936544",
"grandparentTitle": "Stephen Stills",
"parentTitle": "Stephen Stills",
"summary": "",
"index": 1,
"parentIndex": 1,
"ratingCount": 6794,
"thumb": "/library/metadata/1936544/thumb/1432897518",
"art": "/library/metadata/1936543/art/1485951497",
"parentThumb": "/library/metadata/1936544/thumb/1432897518",
"grandparentThumb": "/library/metadata/1936543/thumb/1485951497",
"grandparentArt": "/library/metadata/1936543/art/1485951497",
"addedAt": 1000396126,
"updatedAt": 1432897518
//var_dump($data);
$result = SendTriggerPlex($connect, $plexhook, $data);
var_dump($result);
function SendTriggerPlex($connect, $plexhook, $data)
$plexuser = "plexwebhookuser";
$plexpassword = "plexwebhookpassword";
$URL = $connect."/".$plexhook;
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL,$URL);
curl_setopt($ch, CURLOPT_CUSTOMREQUEST, "POST");
curl_setopt($ch, CURLOPT_TIMEOUT, 5); //timeout after 5 seconds
curl_setopt($ch, CURLOPT_CONNECTTIMEOUT, 5);
curl_setopt($ch, CURLOPT_RETURNTRANSFER,1);
curl_setopt($ch, CURLOPT_POSTFIELDS, $data);
curl_setopt($ch, CURLOPT_HTTPAUTH, CURLAUTH_ANY);
curl_setopt($ch, CURLOPT_USERPWD, "$plexuser:$plexpassword");
curl_setopt($ch, CURLOPT_HTTPHEADER, array(
'Content-Type: application/json',
'Content-Length: ' . strlen($data))
$status_code = curl_getinfo($ch, CURLINFO_HTTP_CODE); //get status code
$result=curl_exec ($ch);
curl_close ($ch);
return $result;
Dann kommt auch was an. Hast Du eine Idee was ich falsch machen könnte?
