Vielen Dank für die Informationen.
Sicher bin ich mir bei den Werten auch nicht, aber die Ausgabe von TPLHS_GetRealtimeCurrent scheint eher Watt als kW zu liefern. Ich habe weder jemals ein Modul geschrieben noch mit git gearbeitet, daher habe ich einige Änderungen bei mir lokal in der module.php getätigt:
class TPLinkHS110 extends IPSModule
public function Create()
//Never delete this line!
parent::Create();
$this->RegisterPropertyString("Host", "");
$this->RegisterPropertyInteger("modelselection", 1);
$this->RegisterPropertyInteger("stateinterval", 0);
$this->RegisterPropertyInteger("systeminfointerval", 0);
$this->RegisterPropertyBoolean("extendedinfo", false);
$this->RegisterPropertyString("softwareversion", "");
$this->RegisterPropertyFloat("hardwareversion", 0);
$this->RegisterPropertyString("type", "");
$this->RegisterPropertyString("model", "");
$this->RegisterPropertyString("mac", "");
$this->RegisterPropertyString("deviceid", "");
$this->RegisterPropertyString("hardwareid", "");
$this->RegisterPropertyString("firmwareid", "");
$this->RegisterPropertyString("oemid", "");
$this->RegisterPropertyString("alias", "");
$this->RegisterPropertyString("devicename", "");
$this->RegisterPropertyInteger("rssi", 0);
$this->RegisterPropertyBoolean("ledoff", false);
$this->RegisterPropertyFloat("latitude", 0);
$this->RegisterPropertyFloat("longitude", 0);
$this->RegisterTimer('StateUpdate', 0, 'TPLHS_StateTimer('.$this->InstanceID.');');
$this->RegisterTimer('SystemInfoUpdate', 0, 'TPLHS_SystemInfoTimer('.$this->InstanceID.');');
public function ApplyChanges()
parent::ApplyChanges();
$this->RegisterVariableBoolean("State", "Status", "~Switch", 1);
$this->EnableAction("State");
$model = $this->ReadPropertyInteger("modelselection");
if($model == 2)
$this->RegisterVariableFloat("Voltage", "Spannung", "~Volt.230", 2);
//$this->EnableAction("Voltage");
$this->RegisterVariableFloat("Power", "Leistung", "~Watt.14490", 3);
// ~Electricity
//$this->EnableAction("Power");
$this->RegisterVariableFloat("Current", "Strom", "~Milliampere.HM", 4);
//$this->EnableAction("Current");
$this->RegisterVariableFloat("Work", "Arbeit", "~Electricity.HM", 5);
$this->ValidateConfiguration();
private function ValidateConfiguration()
// Types HS100, HS105, HS110, HS200
$host = $this->ReadPropertyString('Host');
//IP TP Link check
if (!filter_var($host, FILTER_VALIDATE_IP) === false)
//IP ok
$ipcheck = true;
else
$ipcheck = false;
//Domain TP Link Device check
if(!$this->is_valid_localdomain($host) === false)
//Domain ok
$domaincheck = true;
else
$domaincheck = false;
if ($domaincheck === true || $ipcheck === true)
$hostcheck = true;
$this->SetStatus(102);
else
$hostcheck = false;
$this->SetStatus(203); //IP Adresse oder Host ist ungültig
$extendedinfo = $this->ReadPropertyBoolean("extendedinfo");
if($extendedinfo)
$this->SetStateInterval($hostcheck);
$this->SetSystemInfoInterval($hostcheck);
public function StateTimer()
$this->GetSystemInfo();
public function SystemInfoTimer()
$this->GetRealtimeCurrent();
protected function SetStateInterval($hostcheck)
if($hostcheck)
$devicetype = $this->ReadPropertyInteger("modelselection");
$stateinterval = $this->ReadPropertyInteger("stateinterval");
$interval = $stateinterval * 1000;
if($devicetype == 2)
$this->SetTimerInterval("StateUpdate", $interval);
else
protected function SetSystemInfoInterval($hostcheck)
if($hostcheck)
$infointerval = $this->ReadPropertyInteger("systeminfointerval");
$interval = $infointerval * 1000;
$this->SetTimerInterval("SystemInfoUpdate", $interval);
else
$this->SetTimerInterval("SystemInfoUpdate", 0);
protected function decrypt($cypher_text, $first_key = 0xAB)
$header = substr($cypher_text, 0, 4);
$header_length = unpack('N*', $header)[1];
$cypher_text = substr($cypher_text, 4);
$buf = unpack('c*', $cypher_text );
$key = $first_key;
//$nextKey = "";
for ($i = 1; $i < count($buf)+1; $i++)
$nextKey = $buf[$i];
$buf[$i] = $buf[$i] ^ $key;
$key = $nextKey;
$array_map = array_map('chr', $buf);
$clear_text = implode('', $array_map);
$cypher_length = strlen($clear_text);
if ($header_length !== $cypher_length)
trigger_error("Length in header ({$header_length}) doesn't match actual message length ({$cypher_length}).");
return $clear_text;
protected function encrypt ( $clear_text , $first_key = 0xAB )
$buf = unpack('c*', $clear_text );
$key = $first_key;
$key = $buf[$i];
$length = strlen($clear_text);
$header = pack('N*', $length);
return $header . $clear_text;
protected function connectToSocket()
if(!($sock1 = socket_create(AF_INET, SOCK_STREAM, SOL_TCP)))
$errorcode = socket_last_error();
$errormsg = socket_strerror($errorcode);
die("Couldn't create socket: [$errorcode] $errormsg
$this->SendDebug("TP Link:","Create Socket",0);
//Connect socket to remote server
if(!socket_connect($sock1 , $host ,9999))
die("Could not connect: [$errorcode] $errormsg
$this->SendDebug("TP Link:","Connection established",0);
return $sock1;
protected function sendToSocket($messageToSend, $sock)
$message = $this->encrypt($messageToSend);
//Send the message to the server
if(!socket_send ($sock , $message , strlen($message) , 0)){
die("Could not send data: [$errorcode] $errormsg
$this->SendDebug("TP Link:","Message send successfully",0);
protected function getResultFromSocket($sock)
//Now receive reply from server
$buf = "";
if(socket_recv ( $sock , $buf , 2048 , MSG_WAITALL ) === FALSE){
die("Could not receive data: [$errorcode] $errormsg
return $buf;
protected function SendToTPLink($command)
$sock = $this->connectToSocket();
$this->sendToSocket($command, $sock);
$buf = $this->getResultFromSocket($sock);
$result = json_decode($this->decrypt($buf));
socket_close($sock);
return $result;
//System Commands
// Get System Info (Software & Hardware Versions, MAC, deviceID, hwID etc.)
public function GetSystemInfo()
$command = '{"system":{"get_sysinfo":{}}}';
$result = $this->SendToTPLink($command);
$systeminfo = $result->system->get_sysinfo;
$err_code = intval($systeminfo->err_code);
$sw_ver = $systeminfo->sw_ver;
$hw_ver = floatval($systeminfo->hw_ver);
$type = $systeminfo->type;
$model = $systeminfo->model;
$mac = $systeminfo->mac;
$deviceId = $systeminfo->deviceId;
$hwId = $systeminfo->hwId;
$fwId = $systeminfo->fwId;
$oemId = $systeminfo->oemId;
$alias = $systeminfo->alias;
$dev_name = $systeminfo->dev_name;
$icon_hash = $systeminfo->icon_hash;
$relay_state = boolval($systeminfo->relay_state);
$on_time = intval($systeminfo->on_time);
$active_mode = $systeminfo->active_mode;
$feature = $systeminfo->feature;
$rssi = intval($systeminfo->rssi);
$led_off = boolval($systeminfo->led_off);
$latitude = floatval($systeminfo->latitude);
$longitude = floatval($systeminfo->longitude);
SetValueBoolean($this->GetIDForIdent("State"), $relay_state);
if($extendedinfo)
SetValueString($this->GetIDForIdent("alias"), $alias);
$systeminfo = array("state" => $relay_state, "errorcode" => $err_code, "softwareversion" => $sw_ver, "hardwareversion" => $hw_ver, "type" => $type, "model" => $model, "mac" => $mac, "deviceid" => $deviceId, "hardwareid" => $hwId,
"firmwareid" => $fwId, "oemid" => $oemId, "alias" => $alias, "devicename" => $dev_name, "iconhash" => $icon_hash, "ontime" => $on_time, "active_mode" => $active_mode, "feature" => $feature, "rssi" => $rssi, "ledoff" => $led_off, "latitude" => $latitude, "longitude" => $longitude);
return $systeminfo;
public function WriteSystemInfo()
$systeminfo = $this->GetSystemInfo();
IPS_SetProperty($this->InstanceID, "softwareversion", $systeminfo["softwareversion"]);
IPS_SetProperty($this->InstanceID, "hardwareversion", $systeminfo["hardwareversion"]);
IPS_SetProperty($this->InstanceID, "type", $systeminfo["type"]);
IPS_SetProperty($this->InstanceID, "model", $systeminfo["model"]);
IPS_SetProperty($this->InstanceID, "mac", $systeminfo["mac"]);
IPS_SetProperty($this->InstanceID, "deviceid", $systeminfo["deviceid"]);
IPS_SetProperty($this->InstanceID, "hardwareid", $systeminfo["hardwareid"]);
IPS_SetProperty($this->InstanceID, "firmwareid", $systeminfo["firmwareid"]);
IPS_SetProperty($this->InstanceID, "oemid", $systeminfo["oemid"]);
IPS_SetProperty($this->InstanceID, "alias", $systeminfo["alias"]);
IPS_SetProperty($this->InstanceID, "devicename", $systeminfo["devicename"]);
IPS_SetProperty($this->InstanceID, "rssi", $systeminfo["rssi"]);
IPS_SetProperty($this->InstanceID, "ledoff", $systeminfo["ledoff"]);
IPS_SetProperty($this->InstanceID, "latitude", $systeminfo["latitude"]);
IPS_SetProperty($this->InstanceID, "longitude", $systeminfo["longitude"]);
IPS_ApplyChanges($this->InstanceID);
// Reboot
public function Reboot()
$command = '{"system":{"reboot":{"delay":1}}}';
return $result;
// Power On
public function PowerOn()
$command = '{"system":{"set_relay_state":{"state":1}}}';
return $result;
// Power Off
public function PowerOff()
$command = '{"system":{"set_relay_state":{"state":0}}}';
return $result;
// Power Off
public function ResetWork()
$result = SetValueFloat($this->GetIDForIdent("Work"), 0.0);
return $result;
// Reset (To Factory Settings)
public function Reset()
$command = '{"system":{"reset":{"delay":1}}}';
return $result;
// Turn Off Device LED (Night mode)
public function NightMode()
$command = '{"system":{"set_led_off":{"off":1}}}';
return $result;
// Set Device Alias
public function SetDeviceAlias(string $alias)
$command = '{"system":{"set_dev_alias":{"alias":"'.$alias.'"}}}';
return $result;
// Set MAC Address
public function SetMACAddress(string $mac)
// {"system":{"set_mac_addr":{"mac":"50-C7-BF-01-02-03"}}}
$command = '{"system":{"set_mac_addr":{"mac":"'.$mac.'"}}}';
return $result;
// Set Device ID
public function SetDeviceID(string $deviceid)
$command = '{"system":{"set_device_id":{"deviceId":"'.$deviceid.'"}}}';
return $result;
// Set Hardware ID
public function SetHardwareID(string $hardwareid)
$command = '{"system":{"set_hw_id":{"hwId":"'.$hardwareid.'"}}}';
return $result;
// Set Location
public function SetLocation(float $longitude, float $latitude)
// {"system":{"set_dev_location":{"longitude":6.9582814,"latitude":50.9412784}}}
$command = '{"system":{"set_dev_location":{"longitude":'.$longitude.',"latitude":'.$latitude.'}}}';
return $result;
// Perform uBoot Bootloader Check
public function BootloaderCheck()
$command = '{"system":{"test_check_uboot":null}}';
return $result;
// Get Device Icon
public function GetDeviceIcon()
$command = '{"system":{"get_dev_icon":null}}';
return $result;
// Set Device Icon
public function SetDeviceIcon(string $icon, string $hash)
$command = '{"system":{"set_dev_icon":{"icon":"'.$icon.'","hash":"'.$hash.'"}}}';
return $result;
// Set Test Mode (command only accepted coming from IP 192.168.1.100)
public function SetTestMode()
$command = '{"system":{"set_test_mode":{"enable":1}}}';
return $result;
// Download Firmware from URL
public function DownloadFirmware(string $url)
$command = '{"system":{"download_firmware":{"url":"http://'.$url.'"}}}';
return $result;
// Get Download State
public function GetDownloadState()
$command = '{"system":{"get_download_state":{}}}';
return $result;
// Flash Downloaded Firmware
public function FlashDownloadedFirmware()
$command = '{"system":{"flash_firmware":{}}}';
return $result;
// Check Config
public function CheckConfig()
$command = '{"system":{"check_new_config":null}}';
return $result;
// WLAN Commands
// Scan for list of available APs
public function ScanAP()
$command = '{"netif":{"get_scaninfo":{"refresh":1}}}';
return $result;
// Connect to AP with given SSID and Password
public function ConnectAP(string $ssid, string $password)
$command = '{"netif":{"set_stainfo":{"ssid":"'.$ssid.'","password":"'.$password.'","key_type":3}}}';
return $result;
// Cloud Commands
// Get Cloud Info (Server, Username, Connection Status)
public function GetCloudInfo()
$command = '{"cnCloud":{"get_info":null}}';
return $result;
// Get Firmware List from Cloud Server
public function GetFirmwareList()
$command = '{"cnCloud":{"get_intl_fw_list":{}}}';
return $result;
// Set Server URL
public function SetServerURL(string $url)
// {"cnCloud":{"set_server_url":{"server":"devs.tplinkcloud.com"}}}
$command = '{"cnCloud":{"set_server_url":{"server":"'.$url.'"}}}';
return $result;
// Connect with Cloud username & Password
public function ConnectCloud(string $user, string $password)
// {"cnCloud":{"bind":{"username":"your@email.com", "password":"secret"}}}
$command = '{"cnCloud":{"bind":{"username":"'.$user.'", "password":"'.$password.'"}}}';
return $result;
// Unregister Device from Cloud Account
public function UnregisterFromCloud()
$command = '{"cnCloud":{"unbind":null}}';
return $result;
// Time Commands
// Get Time
public function GetTime()
$command = '{"time":{"get_time":null}}';
return $result;
// Get Timezone
public function GetTimezone()
$command = '{"time":{"get_timezone":null}}';
return $result;
// Set Timezone
public function SetTimezone()
$command = '{"time":{"set_timezone":{"year":2016,"month":1,"mday":1,"hour":10,"min":10,"sec":10,"index":42}}}';
return $result;
// EMeter Energy Usage Statistics Commands
// (for TP-Link HS110)
// Get Realtime Current and Voltage Reading
public function GetRealtimeCurrent()
$command = '{"emeter":{"get_realtime":{}}}';
SetValueFloat($this->GetIDForIdent("Voltage"), floatval($result->emeter->get_realtime->voltage));
SetValueFloat($this->GetIDForIdent("Current"), floatval($result->emeter->get_realtime->current*1000.0));
SetValueFloat($this->GetIDForIdent("Power"), floatval($result->emeter->get_realtime->power));
SetValueFloat($this->GetIDForIdent("Work"), GetValue($this->GetIDForIdent("Work")) + floatval($result->emeter->get_realtime->power*floatval($this->ReadPropertyInteger("systeminfointerval"))/3600.0));
return array("voltage" => floatval($result->emeter->get_realtime->voltage), "current" => floatval($result->emeter->get_realtime->current), "power" => floatval($result->emeter->get_realtime->power), "work" => floatval(GetValue($this->GetIDForIdent("Work"))));
// Get EMeter VGain and IGain Settings
public function GetEMeterVGain()
$command = '{"emeter":{"get_vgain_igain":{}}}';
return $result;
// Set EMeter VGain and Igain
public function SetEMeterVGain(int $vgain, int $igain)
// {"emeter":{"set_vgain_igain":{"vgain":13462,"igain":16835}}}
$command = '{"emeter":{"set_vgain_igain":{"vgain":'.$vgain.',"igain":'.$igain.'}}}';
return $result;
// Start EMeter Calibration
public function StartEMeterCalibration(int $vgain, int $igain)
// {"emeter":{"start_calibration":{"vtarget":13462,"itarget":16835}}}
$command = '{"emeter":{"start_calibration":{"vtarget":'.$vgain.',"itarget":'.$igain.'}}}';
return $result;
// Get Daily Statistic for given Month
public function GetDailyStatistic(int $year)
$command = '{"emeter":{"get_daystat":{"month":1,"year":'.$year.'}}}';
return $result;
// Get Montly Statistic for given Year
public function GetMontlyStatistic(int $year)
$command = '{"emeter":{""get_monthstat":{"year":'.$year.'}}}';
return $result;
// Erase All EMeter Statistics
public function EraseAllEMeterStatistics()
$command = '{"emeter":{"erase_emeter_stat":null}}';
return $result;
// Schedule Commands
// (action to perform regularly on given weekdays)
// Get Next Scheduled Action
public function GetNextScheduledAction()
$command = '{"schedule":{"get_next_action":null}}';
return $result;
// Get Schedule Rules List
public function GetScheduleRulesList()
$command = '{"schedule":{"get_rules":null}}';
return $result;
// Add New Schedule Rule
public function AddNewScheduleRule()
// {"schedule":{"add_rule":{"stime_opt":0,"wday":[1,0,0,1,1,0,0],"smin":1014,"enable":1,"repeat":1,"etime_opt":-1,"name":"lights on","eact":-1,"month":0,"sact":1,"year":0,"longitude":0,"day":0,"force":0,"latitude":0,"emin":0},"set_overall_enable":{"enable":1}}}
$command = '{"schedule":{"add_rule":{"stime_opt":0,"wday":[1,0,0,1,1,0,0],"smin":1014,"enable":1,"repeat":1,"etime_opt":-1,"name":"lights on","eact":-1,"month":0,"sact":1,"year":0,"longitude":0,"day":0,"force":0,"latitude":0,"emin":0},"set_overall_enable":{"enable":1}}}';
return $result;
// Edit Schedule Rule with given ID
public function EditScheduleRule(string $id)
// {"schedule":{"edit_rule":{"stime_opt":0,"wday":[1,0,0,1,1,0,0],"smin":1014,"enable":1,"repeat":1,"etime_opt":-1,"id":"4B44932DFC09780B554A740BC1798CBC","name":"lights on","eact":-1,"month":0,"sact":1,"year":0,"longitude":0,"day":0,"force":0,"latitude":0,"emin":0}}}
$command = '{"schedule":{"edit_rule":{"stime_opt":0,"wday":[1,0,0,1,1,0,0],"smin":1014,"enable":1,"repeat":1,"etime_opt":-1,"id":"'.$id.'","name":"lights on","eact":-1,"month":0,"sact":1,"year":0,"longitude":0,"day":0,"force":0,"latitude":0,"emin":0}}}';
return $result;
// Delete Schedule Rule with given ID
public function DeleteScheduleRule(string $id)
// {"schedule":{"delete_rule":{"id":"4B44932DFC09780B554A740BC1798CBC"}}}
$command = '{"schedule":{"delete_rule":{"id":"'.$id.'"}}}';
return $result;
// Delete All Schedule Rules and Erase Statistics
public function DeleteAllScheduleRules()
// {"schedule":{"delete_all_rules":null,"erase_runtime_stat":null}}
$command = '{"schedule":{"delete_all_rules":null,"erase_runtime_stat":null}}';
return $result;
// Countdown Rule Commands
// (action to perform after number of seconds)
// Get Rule (only one allowed)
public function GetRule()
$command = '{"count_down":{"get_rules":null}}';
return $result;
// Add New Countdown Rule
public function AddNewCountdownRule(int $delay, string $name)
// {"count_down":{"add_rule":{"enable":1,"delay":1800,"act":1,"name":"turn on"}}}
$command = '{"count_down":{"add_rule":{"enable":1,"delay":'.$delay.',"act":1,"name":"'.$name.'"}}}';
return $result;
// Edit Countdown Rule with given ID
public function EditCountdownRule(string $id, int $delay, string $name)
// {"count_down":{"edit_rule":{"enable":1,"id":"7C90311A1CD3227F25C6001D88F7FC13","delay":1800,"act":1,"name":"turn on"}}}
$command = '{"count_down":{"edit_rule":{"enable":1,"id":"'.$id.'","delay":'.$delay.',"act":1,"name":"'.$name.'"}}}';
return $result;
// Delete Countdown Rule with given ID
public function DeleteCountdownRule(string $id)
// {"count_down":{"delete_rule":{"id":"7C90311A1CD3227F25C6001D88F7FC13"}}}
$command = '{"count_down":{"delete_rule":{"id":"'.$id.'"}}}';
return $result;
// Delete All Coundown Rules
public function DeleteAll()
// {"count_down":{"delete_all_rules":null}}
$command = '{"count_down":{"delete_all_rules":null}}';
return $result;
// Anti-Theft Rule Commands (aka Away Mode)
// (period of time during which device will be randomly turned on and off to deter thieves)
// Get Anti-Theft Rules List
public function GetAntiTheftRules()
$command = '{"anti_theft":{"get_rules":null}}';
return $result;
// Delete All Anti-Theft Rules
public function DeleteAllAntiTheftRules()
$command = '{"anti_theft":{"delete_all_rules":null}}';
return $result;
// Add New Anti-Theft Rule
public function AddNewAntiTheftRule()
// {"anti_theft":{"add_rule":{"stime_opt":0,"wday":[0,0,0,1,0,1,0],"smin":987,"enable":1,"frequency":5,"repeat":1,"etime_opt":0,"duration":2,"name":"test","lastfor":1,"month":0,"year":0,"longitude":0,"day":0,"latitude":0,"force":0,"emin":1047},"set_overall_enable":1}}
$command = '{"anti_theft":{"add_rule":{"stime_opt":0,"wday":[0,0,0,1,0,1,0],"smin":987,"enable":1,"frequency":5,"repeat":1,"etime_opt":0,"duration":2,"name":"test","lastfor":1,"month":0,"year":0,"longitude":0,"day":0,"latitude":0,"force":0,"emin":1047},"set_overall_enable":1}}';
return $result;
// Edit Anti-Theft Rule with given ID
public function EditAntiTheftRule()
$command = '{"anti_theft":{"edit_rule":{"stime_opt":0,"wday":[0,0,0,1,0,1,0],"smin":987,"enable":1,"frequency":5,"repeat":1,"etime_opt":0,"id":"E36B1F4466B135C1FD481F0B4BFC9C30","duration":2,"name":"test","lastfor":1,"month":0,"year":0,"longitude":0,"day":0,"latitude":0,"force":0,"emin":1047},"set_overall_enable":1}}';
return $result;
// Delete Anti-Theft Rule with given ID
public function DeleteAntiTheftRule(string $id)
$command = '{"anti_theft":{"delete_rule":{"id":"'.$id.'"}}}';
return $result;
public function ReceiveData($JSONString)
$data = json_decode($JSONString);
$objectid = $data->Buffer->objectid;
$values = $data->Buffer->values;
$valuesjson = json_encode($values);
if (($this->InstanceID) == $objectid)
//Parse and write values to our variables
//$this->WriteValues($valuesjson);
protected function is_valid_localdomain($url)
$validation = FALSE;
/*Parse URL*/
$urlparts = parse_url(filter_var($url, FILTER_SANITIZE_URL));
/*Check host exist else path assign to host*/
if(!isset($urlparts['host'])){
$urlparts['host'] = $urlparts['path'];
if($urlparts['host']!=''){
/*Add scheme if not found*/
if (!isset($urlparts['scheme'])){
$urlparts['scheme'] = 'http';
/*Validation*/
if(checkdnsrr($urlparts['host'], 'A') && in_array($urlparts['scheme'],array('http','https')) && ip2long($urlparts['host']) === FALSE){
$urlparts['host'] = preg_replace('/^www\./', '', $urlparts['host']);
$url = $urlparts['scheme'].'://'.$urlparts['host']. "/";
if (filter_var($url, FILTER_VALIDATE_URL) !== false && @get_headers($url)) {
$validation = TRUE;
if(!$validation)
//echo $url." Its Invalid Domain Name.";
return $domaincheck;
else
//echo $url." is a Valid Domain Name.";
public function RequestAction($Ident, $Value)
switch($Ident) {
case "State":
$varid = $this->GetIDForIdent("State");
SetValue($varid, $Value);
if($Value)
$this->PowerOn();
else
$this->PowerOff();
break;
default:
throw new Exception("Invalid ident");
//Profile
protected function RegisterProfile($Name, $Icon, $Prefix, $Suffix, $MinValue, $MaxValue, $StepSize, $Digits, $Vartype)
if(!IPS_VariableProfileExists($Name))
IPS_CreateVariableProfile($Name, $Vartype); // 0 boolean, 1 int, 2 float, 3 string,
else
$profile = IPS_GetVariableProfile($Name);
if($profile['ProfileType'] != $Vartype)
throw new Exception("Variable profile type does not match for profile ".$Name);
IPS_SetVariableProfileIcon($Name, $Icon);
IPS_SetVariableProfileText($Name, $Prefix, $Suffix);
IPS_SetVariableProfileDigits($Name, $Digits); // Nachkommastellen
IPS_SetVariableProfileValues($Name, $MinValue, $MaxValue, $StepSize); // string $ProfilName, float $Minimalwert, float $Maximalwert, float $Schrittweite
protected function RegisterProfileAssociation($Name, $Icon, $Prefix, $Suffix, $MinValue, $MaxValue, $Stepsize, $Digits, $Vartype, $Associations)
if ( sizeof($Associations) === 0 ){
$MinValue = 0;
$MaxValue = 0;
else {
//undefiened offset
$MinValue = $Associations[0][0];
$MaxValue = $Associations[sizeof($Associations)-1][0];
$this->RegisterProfile($Name, $Icon, $Prefix, $Suffix, $MinValue, $MaxValue, $Stepsize, $Digits, $Vartype);
//boolean IPS_SetVariableProfileAssociation ( string $ProfilName, float $Wert, string $Name, string $Icon, integer $Farbe )
foreach($Associations as $Association) {
IPS_SetVariableProfileAssociation($Name, $Association[0], $Association[1], $Association[2], $Association[3]);
//Configuration Form
public function GetConfigurationForm()
$formhead = $this->FormHead();
$formactions = $this->FormActions();
$formelementsend = '{ "type": "Label", "label": "__________________________________________________________________________________________________" }';
$formstatus = $this->FormStatus();
return '{ '.$formhead.$formelementsend.'],'.$formactions.$formstatus.' }';
protected function FormHead()
$form = '"elements":
{ "type": "Label", "label": "TP Link HS type"},
{ "type": "Select", "name": "modelselection", "caption": "model",
"options": [
{ "label": "HS100", "value": 1 },
{ "label": "HS110", "value": 2 }
{ "type": "Label", "label": "TP Link HS device ip address"},
"name": "Host",
"type": "ValidationTextBox",
"caption": "IP adress"
{ "type": "Label", "label": "TP Link HS device state update interval"},
{ "type": "IntervalBox", "name": "stateinterval", "caption": "seconds" },';
if($model == 2)
$form .= '{ "type": "Label", "label": "TP Link HS device system info update interval"},
{ "type": "IntervalBox", "name": "systeminfointerval", "caption": "seconds" },';
$softwareversion = $this->ReadPropertyString("softwareversion");
if($softwareversion == "")
$form .='{ "type": "Label", "label": "TP Link HS get system information" },
{ "type": "Button", "label": "Get system info", "onClick": "TPLHS_WriteSystemInfo($id);" },';
else
$form .= '{ "type": "Label", "label": "Data is from the TP Link HS device do not edit only for information, change settings in the kasa app" },';
$form .= '{"name": "softwareversion", "type": "ValidationTextBox", "caption": "software version"},';
$form .= '{"name": "hardwareversion", "type": "ValidationTextBox", "caption": "hardware version"},';
$form .= '{"name": "type", "type": "ValidationTextBox", "caption": "type"},';
$form .= '{"name": "model", "type": "ValidationTextBox", "caption": "model"},';
$form .= '{"name": "mac", "type": "ValidationTextBox", "caption": "mac"},';
$form .= '{"name": "deviceid", "type": "ValidationTextBox", "caption": "device id"},';
$form .= '{"name": "hardwareid", "type": "ValidationTextBox", "caption": "hardware id"},';
$form .= '{"name": "firmwareid", "type": "ValidationTextBox", "caption": "firmware id"},';
$form .= '{"name": "oemid", "type": "ValidationTextBox", "caption": "oem id"},';
$form .= '{"name": "alias", "type": "ValidationTextBox", "caption": "alias"},';
$form .= '{"name": "devicename", "type": "ValidationTextBox", "caption": "device name"},';
$form .= '{"name": "rssi", "type": "ValidationTextBox", "caption": "rssi"},';
$form .= '{"name": "ledoff", "type": "ValidationTextBox", "caption": "led state"},';
$form .= '{"name": "latitude", "type": "ValidationTextBox", "caption": "latitude"},';
$form .= '{"name": "longitude", "type": "ValidationTextBox", "caption": "longitude"},';
return $form;
protected function FormActions()
$form = '"actions":
{ "type": "Label", "label": "TP Link HS device" },
{ "type": "Label", "label": "TP Link HS Power On" },
{ "type": "Button", "label": "On", "onClick": "TPLHS_PowerOn($id);" },
{ "type": "Label", "label": "TP Link HS Power Off" },
{ "type": "Button", "label": "Off", "onClick": "TPLHS_PowerOff($id);" },
{ "type": "Label", "label": "Reset Work" },
{ "type": "Button", "label": "Reset", "onClick": "TPLHS_ResetWork($id);" }
return $form;
protected function FormStatus()
$form = '"status":
"code": 101,
"icon": "inactive",
"caption": "Creating instance."
"code": 102,
"icon": "active",
"caption": "instance created."
"code": 104,
"icon": "inactive",
"caption": "interface closed."
"code": 202,
"icon": "error",
"caption": "special errorcode."
"code": 203,
"icon": "error",
"caption": "IP Address is not valid."
return $form;
Ich weiß, dass das blöd ist, aber ich habe auf die Schnelle keine bessere Umsetzung gefunden. Folgende Unterschiede zu deiner Version:
// ~Electricity
Also andere Profile und eine bessere Übersetzung für „current“ (gant korrekt wäre „elektrische Stromstärke“).
Hier wurde ursprünglich noch zusätzlich mit 60 multipliziert, mir war nicht klar, warum. Damit wird das InfoUpdate wirklich genau wie im Formular angegeben durchgeführt.
return $result;
Funktion ergänzt, die die Arbeit zurücksetzen kann.
return array("voltage" => floatval($result->emeter->get_realtime->voltage), "current" => floatval($result->emeter->get_realtime->current), "power" => floatval($result->emeter->get_realtime->power), "work" => floatval(GetValu$
Erweiterung dieser Funktion. Inbesondere wird die Leistung nun in mA berechnet, was ich bei geringeren Leistungsaufnahmen für angenehmer halte. Zusätzlich wird die Leistung zur Arbeit aufintegriert.
$form = '"actions":
Aktion „ResetWork“ im Formular ergänzt, damit man die Arbeit zurücksetzen kann.
Gruß,
micheljarre
