hier al ein Auszug aus der Doku zu meiner Camera:
8.4.13 /ISAPI/System/Video/inputs/channels/<ID>/motionDetection
/ISAPI/System/Video/inputs/channels/ID
/MotionDetection
GET
Description It is used to get the motion detection configuration for all video input channels.
Query None
Inbound Data None
Success Return MotionDetection
PUT
Description It is used to udpate the motion detection configuration for a video input channel.
Query None
Inbound Data MotionDetection
Success Return ResponseStatus
Notes:
If motion detection is supported by the device, a motion detection ID will be allocated for
each video input channel ID. The motion detection ID must correspond to the video input
channel ID.
MotionDetection XML Block
<MotionDetection version=“2.0” xmlns=“http://www.isapi.org/ver20/XMLSchema”>
<enabled> <!-- req, xs:boolean --> </enabled>
<enableHighlight> <!-- opt, xs:boolean --> </enableHighlight>
<samplingInterval> <!-- opt, xs:integer, number of frames --> </samplingInterval>
<startTriggerTime> <!-- opt, xs:integer, milliseconds --> </startTriggerTime>
<endTriggerTime> <!-- opt, xs:integer, milliseconds --> </endTriggerTime>
<regionType> <!-- ro, req, xs:string, “grid, roi, none” --> </regionType>
<Grid> <!-- dep -->
<rowGranularity> <!-- ro, req, xs:integer --> </rowGranularity>
<columnGranularity> <!-- ro, req, xs:integer --> </columnGranularity>
</Grid>
<ROI> <!-- dep -->
<normalizedScreenWidth> <!-- ro, req, xs:integer --></normalizedScreenWidth>
<normalizedScreenHeight> <!-- ro, req, xs:integer --></normalizedScreenHeight>
</ROI>
<MotionDetectionLayout/> <!-- req -->
</MotionDetection>
Den GET bekomme ich so hin:
$out =„http://admin:12345@192.168.178.166/ISAPI/System/Video/inputs/channels/1/motionDetection“;
$ch = curl_init($out);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
$ergebnis = curl_exec($ch);
$fehler = curl_error($ch);
echo $ergebnis;
echo $fehler;
curl_close($ch);
Ich bekomme dann folgendes zurück:
<?xml version=„1.0“ encoding=„UTF-8“?>
<MotionDetection version=„2.0“ xmlns=„http://www.isapi.org/ver20/XMLSchema“>
<enabled>true</enabled>
<enableHighlight>true</enableHighlight>
<samplingInterval>2</samplingInterval>
<startTriggerTime>500</startTriggerTime>
<endTriggerTime>500</endTriggerTime>
<regionType>grid</regionType>
<Grid>
<rowGranularity>15</rowGranularity>
<columnGranularity>22</columnGranularity>
</Grid>
<MotionDetectionLayout version=„2.0“ xmlns=„http://www.isapi.org/ver20/XMLSchema“>
<sensitivityLevel>60</sensitivityLevel>
<layout>
<gridMap>7ffff87ffff8fffffcfffffcfffffcfffffcfffffcfffffcfffffcfffffcfffffcfffffcfffffcfffffcfffffc</gridMap>
</layout>
</MotionDetectionLayout>
</MotionDetection>
Davon möchte ich <enabled>true</enabled> in <enabled>false</enabled> ändern.
Nur beim senden der geänderten Einstellungen haperts…
So wie ich es verstanden habe, muss ich eigentlich „nur“ das manipulierte Ergebnis des GET wieder an die Kamera senden.
Andreas
