obwohl ich den Image Grabber geloescht habe, ist das Problem immer noch da. Hier die relevanten Log-Entraege:
11/23/2013 01:36:32.866 | 0 | ERROR | InstanceManager | Error Processing Message: VM_UPDATE, Instance #26915, Message: Out of memory
11/23/2013 01:36:32.882 | 0 | ERROR | InstanceManager | Error Processing Message: VM_UPDATE, Instance #26915, Message: Out of memory
11/23/2013 01:36:32.897 | 0 | ERROR | InstanceManager | Error Processing Message: VM_UPDATE, Instance #26915, Message: Out of memory
11/23/2013 01:36:37.250 | 0 | ERROR | Settings | Error updating on message VM_UPDATE for Sender 53176. Error: Out of memory
11/23/2013 01:36:43.646 | 0 | WARNING | TimerID #20, TimerThread #29 | [None] = Out of memory
11/23/2013 01:36:44.114 | 0 | WARNING | ReadThread | Out of memory
11/23/2013 01:36:44.114 | 16169 | MESSAGE | HomeMatic Socket | Socket (Data Radio) - Disconnected
11/23/2013 01:36:44.676 | 0 | WARNING | TimerID #20, TimerThread #7 | [None] = Out of memory
11/23/2013 01:36:45.705 | 0 | WARNING | TimerID #20, TimerThread #20 | [None] = Out of memory
11/23/2013 01:36:46.735 | 0 | WARNING | TimerID #20, TimerThread #45 | [None] = Out of memory
11/23/2013 01:36:47.764 | 0 | WARNING | TimerID #20, TimerThread #43 | [None] = Out of memory
11/23/2013 01:36:48.794 | 0 | WARNING | TimerID #20, TimerThread #36 | [None] = Out of memory
11/23/2013 01:36:49.106 | 13072 | WARNING | ExecuteThreadID #7 | Error executing Script (13072.ips.php): Out of memory
11/23/2013 01:36:49.824 | 0 | WARNING | TimerID #20, TimerThread #26 | [None] = Out of memory
11/23/2013 01:36:50.854 | 0 | WARNING | TimerID #20, TimerThread #7 | [None] = Out of memory
11/23/2013 01:36:51.884 | 0 | WARNING | TimerID #20, TimerThread #49 | [None] = Out of memory
11/23/2013 01:36:52.913 | 0 | WARNING | TimerID #20, TimerThread #50 | [None] = Out of memory
11/23/2013 01:36:53.942 | 0 | WARNING | TimerID #20, TimerThread #40 | [None] = Out of memory
11/23/2013 01:36:54.972 | 0 | WARNING | TimerID #20, TimerThread #7 | [None] = Out of memory
11/23/2013 01:36:56.002 | 0 | WARNING | TimerID #20, TimerThread #27 | [None] = Out of memory
11/23/2013 01:36:57.031 | 0 | WARNING | TimerID #20, TimerThread #45 | [None] = Out of memory
11/23/2013 01:36:58.061 | 0 | WARNING | TimerID #20, TimerThread #5 | [None] = Out of memory
11/23/2013 01:36:59.091 | 0 | WARNING | TimerID #20, TimerThread #27 | [None] = Out of memory
11/23/2013 01:37:00.120 | 0 | WARNING | TimerID #20, TimerThread #16 | [None] = Out of memory
11/23/2013 01:37:01.197 | 0 | WARNING | TimerID #20, TimerThread #11 | [None] = Out of memory
11/23/2013 01:37:01.743 | 0 | ERROR | InstanceManager | Error Processing Message: VM_UPDATE, Instance #26915, Message: Out of memory
11/23/2013 01:37:07.031 | 0 | ERROR | KernelMT | Error in message loop: Out of memory
11/23/2013 01:37:07.047 | 0 | ERROR | KernelMT | Error in message loop: Out of memory
11/23/2013 01:37:07.062 | 0 | ERROR | KernelMT | Error in message loop: Out of memory
11/23/2013 01:37:07.078 | 0 | ERROR | KernelMT | Error in message loop: Out of memory
11/23/2013 01:37:07.094 | 0 | ERROR | KernelMT | Error in message loop: Out of memory
11/23/2013 01:37:25.299 | 16169 | ERROR | EventControl | Reconnecting [HomeMatic Socket] failed = Thread creation error: Not enough storage is available to process this command
11/23/2013 01:37:30.244 | 16169 | WARNING | TimerID #12, TimerThread #46 | [HomeMatic Socket] = Waiting for response timed out
11/23/2013 01:38:25.318 | 16169 | ERROR | EventControl | Reconnecting [HomeMatic Socket] failed = Thread creation error: Not enough storage is available to process this command
11/23/2013 01:39:25.347 | 16169 | ERROR | EventControl | Reconnecting [HomeMatic Socket] failed = Thread creation error: Not enough storage is available to process this command
11/23/2013 01:40:25.512 | 16169 | MESSAGE | HomeMatic Socket | Socket (Data Radio) - Connected
11/23/2013 01:40:25.512 | 16169 | MESSAGE | EventControl | Reconnecting [HomeMatic Socket] succeeded
11/23/2013 06:00:16.560 | 0 | ERROR | ScriptEngine | FunctionName: SetValue, ThreadID: 6784, CrashReport: Out of memory
11/23/2013 06:00:22.457 | 0 | ERROR | ScriptEngine | FunctionName: SetValue, ThreadID: 6784, CrashReport: Out of memory
11/23/2013 06:00:32.761 | 0 | WARNING | ReadThread | Out of memory
11/23/2013 06:00:32.761 | 16169 | MESSAGE | HomeMatic Socket | Socket (Data Radio) - Disconnected
11/23/2013 06:00:37.410 | 0 | ERROR | ScriptEngine | FunctionName: SetValue, ThreadID: 6784, CrashReport: Out of memory
11/23/2013 06:00:37.769 | 16169 | WARNING | TimerID #12, TimerThread #16 | [HomeMatic Socket] = Waiting for response timed out
11/23/2013 06:00:52.327 | 0 | ERROR | ScriptEngine | FunctionName: SetValue, ThreadID: 6784, CrashReport: Out of memory
11/23/2013 06:01:07.350 | 0 | ERROR | ScriptEngine | FunctionName: SetValue, ThreadID: 6784, CrashReport: Out of memory
11/23/2013 06:01:22.370 | 0 | ERROR | ScriptEngine | FunctionName: SetValue, ThreadID: 6784, CrashReport: Out of memory
11/23/2013 06:01:28.049 | 16169 | ERROR | EventControl | Reconnecting [HomeMatic Socket] failed = Thread creation error: Not enough storage is available to process this command
11/23/2013 06:02:28.078 | 16169 | ERROR | EventControl | Reconnecting [HomeMatic Socket] failed = Thread creation error: Not enough storage is available to process this command
11/23/2013 06:03:28.097 | 16169 | ERROR | EventControl | Reconnecting [HomeMatic Socket] failed = Thread creation error: Not enough storage is available to process this command
11/23/2013 06:04:28.122 | 16169 | ERROR | EventControl | Reconnecting [HomeMatic Socket] failed = Thread creation error: Not enough storage is available to process this command
11/23/2013 06:05:28.141 | 16169 | ERROR | EventControl | Reconnecting [HomeMatic Socket] failed = Thread creation error: Not enough storage is available to process this command
11/23/2013 06:06:28.171 | 16169 | ERROR | EventControl | Reconnecting [HomeMatic Socket] failed = Thread creation error: Not enough storage is available to process this command
11/23/2013 06:07:28.220 | 16169 | ERROR | EventControl | Reconnecting [HomeMatic Socket] failed = Thread creation error: Not enough storage is available to process this command
11/23/2013 06:08:07.237 | 0 | ERROR | ScriptEngine | FunctionName: SetValue, ThreadID: 1736, CrashReport: Out of memory
11/23/2013 06:08:28.291 | 12742 | WARNING | TimerID #13, TimerThread #49 | [Event Handler] = Out of memory
11/23/2013 06:09:28.320 | 16169 | ERROR | EventControl | Reconnecting [HomeMatic Socket] failed = Thread creation error: Not enough storage is available to process this command
11/23/2013 06:10:28.407 | 16169 | ERROR | EventControl | Reconnecting [HomeMatic Socket] failed = Thread creation error: Not enough storage is available to process this command
11/23/2013 06:11:28.615 | 16169 | ERROR | EventControl | Reconnecting [HomeMatic Socket] failed = Thread creation error: Not enough storage is available to process this command
11/23/2013 06:12:28.776 | 16169 | ERROR | EventControl | Reconnecting [HomeMatic Socket] failed = Thread creation error: Not enough storage is available to process this command
11/23/2013 06:13:28.973 | 16169 | ERROR | EventControl | Reconnecting [HomeMatic Socket] failed = Thread creation error: Not enough storage is available to process this command
Interessanterweise sind die Logs der drei Tage davor fast leer, die haben nur diesen Inhalt:
11/22/2013 00:06:26.361 | 0 | MESSAGE | Kernel | Log File Rotation after Midnight...
11/22/2013 00:06:26.361 | 0 | MESSAGE | Kernel | Backuping Settings after Midnight...
11/22/2013 00:06:26.377 | 0 | MESSAGE | Kernel | Cleaning up Logfile Folder...
11/22/2013 00:06:26.377 | 0 | MESSAGE | Settings | Backuping Settings after Midnight...
11/22/2013 00:06:26.377 | 0 | MESSAGE | Settings | Cleaning up Settings Folder...
11/23/2013 00:09:44.756 | 0 | MESSAGE | Kernel | Log File Rotation after Midnight...
Ich habe seit Monaten nichts am Setup des Systems geaendert, dieses Problem tritt seit #3007 auf. Ich gehe also davon aus, dass das ein Bug ist und bitte IP-Symcon hoeflich um Reaktion.
Adrian
