hier mal ein aktuelles Log von „gerade“:
7.1.1 0e03ffd8270f4f039d63e4db2cf72b55f8996537 1712061704 iOS 161 iPad
3.4.2024 - 17:31:20: Connected to Socket of http://192.168.178.4:3777/api/
3.4.2024 - 17:31:20: Successfully updated snapshot diff of http://192.168.178.4:3777/api/
3.4.2024 - 17:46:04: Disconnected from Socket of http://192.168.178.4:3777/api/: WebSocket closed
3.4.2024 - 17:46:04: Trying to establish a connection to http://192.168.178.4:3777/...
3.4.2024 - 17:46:04: Found server at http://192.168.178.4:3777/. Establishing connection...
3.4.2024 - 17:46:04: Updating connection, active = ServerConnection(http://192.168.178.4:3777/api/, null, null, false, null, false), previous = ServerConnection(http://192.168.178.4:3777/api/, null, 59501, true, 972187, true)
3.4.2024 - 17:46:04: Connected to Socket of http://192.168.178.4:3777/api/
3.4.2024 - 17:46:04: Failed to update snapshot diff of http://192.168.178.4:3777/api/: Request range is bigger than message buffer
3.4.2024 - 17:46:05: Snapshot from http://192.168.178.4:3777/api/ loaded
3.4.2024 - 17:46:05: Connected to Socket of http://192.168.178.4:3777/api/
3.4.2024 - 17:46:05: Successfully updated snapshot diff of http://192.168.178.4:3777/api/
3.4.2024 - 17:56:43: Disconnected from Socket of http://192.168.178.4:3777/api/: WebSocket closed
3.4.2024 - 17:56:43: Trying to establish a connection to http://192.168.178.4:3777/...
3.4.2024 - 17:56:43: Found server at http://192.168.178.4:3777/. Establishing connection...
3.4.2024 - 17:56:43: Updating connection, active = ServerConnection(http://192.168.178.4:3777/api/, null, null, false, null, false), previous = ServerConnection(http://192.168.178.4:3777/api/, null, 59501, true, 1019342, true)
3.4.2024 - 17:56:43: Connected to Socket of http://192.168.178.4:3777/api/
3.4.2024 - 17:56:43: Successfully updated snapshot diff of http://192.168.178.4:3777/api/
3.4.2024 - 18:08:42: Disconnected from Socket of http://192.168.178.4:3777/api/: WebSocket closed
3.4.2024 - 18:08:42: Trying to establish a connection to http://192.168.178.4:3777/...
3.4.2024 - 18:08:42: Found server at http://192.168.178.4:3777/. Establishing connection...
3.4.2024 - 18:08:42: Updating connection, active = ServerConnection(http://192.168.178.4:3777/api/, null, null, false, null, false), previous = ServerConnection(http://192.168.178.4:3777/api/, null, 59501, true, 1054690, true)
3.4.2024 - 18:08:42: Connected to Socket of http://192.168.178.4:3777/api/
3.4.2024 - 18:08:42: Successfully updated snapshot diff of http://192.168.178.4:3777/api/
3.4.2024 - 18:34:22: Disconnected from Socket of http://192.168.178.4:3777/api/: WebSocket closed
3.4.2024 - 18:34:22: Trying to establish a connection to http://192.168.178.4:3777/...
3.4.2024 - 18:34:22: Found server at http://192.168.178.4:3777/. Establishing connection...
3.4.2024 - 18:34:22: Updating connection, active = ServerConnection(http://192.168.178.4:3777/api/, null, null, false, null, false), previous = ServerConnection(http://192.168.178.4:3777/api/, null, 59501, true, 1096859, true)
3.4.2024 - 18:34:22: Connected to Socket of http://192.168.178.4:3777/api/
3.4.2024 - 18:34:22: Failed to update snapshot diff of http://192.168.178.4:3777/api/: Request range is bigger than message buffer
3.4.2024 - 18:34:22: Snapshot from http://192.168.178.4:3777/api/ loaded
3.4.2024 - 18:34:22: Successfully updated snapshot diff of http://192.168.178.4:3777/api/
3.4.2024 - 18:45:21: Disconnected from Socket of http://192.168.178.4:3777/api/: WebSocket closed
3.4.2024 - 18:45:21: Trying to establish a connection to http://192.168.178.4:3777/...
3.4.2024 - 18:45:22: Found server at http://192.168.178.4:3777/. Establishing connection...
3.4.2024 - 18:45:22: Updating connection, active = ServerConnection(http://192.168.178.4:3777/api/, null, null, false, null, false), previous = ServerConnection(http://192.168.178.4:3777/api/, null, 59501, true, 1182317, true)
3.4.2024 - 18:45:22: Connected to Socket of http://192.168.178.4:3777/api/
3.4.2024 - 18:45:22: Successfully updated snapshot diff of http://192.168.178.4:3777/api/
3.4.2024 - 19:33:47: Disconnected from Socket of http://192.168.178.4:3777/api/: WebSocket closed
3.4.2024 - 19:33:47: Trying to establish a connection to http://192.168.178.4:3777/...
3.4.2024 - 19:33:47: Found server at http://192.168.178.4:3777/. Establishing connection...
3.4.2024 - 19:33:47: Updating connection, active = ServerConnection(http://192.168.178.4:3777/api/, null, null, false, null, false), previous = ServerConnection(http://192.168.178.4:3777/api/, null, 59501, true, 1217429, true)
3.4.2024 - 19:33:47: Connected to Socket of http://192.168.178.4:3777/api/
3.4.2024 - 19:33:47: Failed to update snapshot diff of http://192.168.178.4:3777/api/: Request range is bigger than message buffer
3.4.2024 - 19:33:47: Snapshot from http://192.168.178.4:3777/api/ loaded
3.4.2024 - 19:33:47: Successfully updated snapshot diff of http://192.168.178.4:3777/api/
3.4.2024 - 20:22:45: Disconnected from Socket of http://192.168.178.4:3777/api/: WebSocket closed
3.4.2024 - 20:22:45: Trying to establish a connection to http://192.168.178.4:3777/...
3.4.2024 - 20:22:46: Found server at http://192.168.178.4:3777/. Establishing connection...
3.4.2024 - 20:22:46: Updating connection, active = ServerConnection(http://192.168.178.4:3777/api/, null, null, false, null, false), previous = ServerConnection(http://192.168.178.4:3777/api/, null, 59501, true, 1365726, true)
3.4.2024 - 20:22:46: Connected to Socket of http://192.168.178.4:3777/api/
3.4.2024 - 20:22:46: Failed to update snapshot diff of http://192.168.178.4:3777/api/: Request range is bigger than message buffer
3.4.2024 - 20:22:46: Disconnected from Socket of http://192.168.178.4:3777/api/: WebSocket closed
3.4.2024 - 20:46:27: Disconnected from Socket of http://192.168.178.4:3777/api/: ClientException: Bad file descriptor, uri=http://192.168.178.4:3777/api/
4.4.2024 - 11:57:43: Trying to establish a connection to http://192.168.178.4:3777/...
4.4.2024 - 11:57:43: Found server at http://192.168.178.4:3777/. Establishing connection...
4.4.2024 - 11:57:43: Updating connection, active = ServerConnection(http://192.168.178.4:3777/api/, null, null, false, null, false), previous = null
4.4.2024 - 11:57:45: Trying to establish a connection to http://192.168.178.4:3777/...
4.4.2024 - 11:57:45: Found server at http://192.168.178.4:3777/. Establishing connection...
4.4.2024 - 11:57:45: Updating connection, active = ServerConnection(http://192.168.178.4:3777/api/, null, null, false, null, false), previous = null
4.4.2024 - 11:57:46: Trying to establish a connection to http://192.168.178.4:3777/...
4.4.2024 - 11:57:46: Found server at http://192.168.178.4:3777/. Establishing connection...
4.4.2024 - 11:57:46: Updating connection, active = ServerConnection(http://192.168.178.4:3777/api/, null, null, false, null, false), previous = null
4.4.2024 - 11:57:46: Snapshot from http://192.168.178.4:3777/api/ loaded
4.4.2024 - 11:57:46: Connected to Socket of http://192.168.178.4:3777/api/
4.4.2024 - 11:57:46: Successfully updated snapshot diff of http://192.168.178.4:3777/api/
4.4.2024 - 12:27:21: Disconnected from Socket of http://192.168.178.4:3777/api/: WebSocket closed
4.4.2024 - 12:27:21: Trying to establish a connection to http://192.168.178.4:3777/...
4.4.2024 - 12:27:21: Found server at http://192.168.178.4:3777/. Establishing connection...
4.4.2024 - 12:27:21: Updating connection, active = ServerConnection(http://192.168.178.4:3777/api/, null, null, false, null, false), previous = ServerConnection(http://192.168.178.4:3777/api/, null, null, false, null, false)
4.4.2024 - 12:27:21: Disconnected from Socket of http://192.168.178.4:3777/api/: HttpException: Connection closed before full header was received, uri = http://192.168.178.4:3777/wfc/null/api/
4.4.2024 - 14:39:01: Trying to establish a connection to http://192.168.178.4:3777/...
4.4.2024 - 14:39:01: Found server at http://192.168.178.4:3777/. Establishing connection...
4.4.2024 - 14:39:01: Updating connection, active = ServerConnection(http://192.168.178.4:3777/api/, null, null, false, null, false), previous = null
4.4.2024 - 14:39:02: Trying to establish a connection to http://192.168.178.4:3777/...
4.4.2024 - 14:39:02: Found server at http://192.168.178.4:3777/. Establishing connection...
4.4.2024 - 14:39:02: Updating connection, active = ServerConnection(http://192.168.178.4:3777/api/, null, null, false, null, false), previous = null
4.4.2024 - 14:39:03: Trying to establish a connection to http://192.168.178.4:3777/...
4.4.2024 - 14:39:03: Found server at http://192.168.178.4:3777/. Establishing connection...
4.4.2024 - 14:39:03: Updating connection, active = ServerConnection(http://192.168.178.4:3777/api/, null, null, false, null, false), previous = null
4.4.2024 - 14:39:03: Snapshot from http://192.168.178.4:3777/api/ loaded
4.4.2024 - 14:39:04: Connected to Socket of http://192.168.178.4:3777/api/
4.4.2024 - 14:39:04: Successfully updated snapshot diff of http://192.168.178.4:3777/api/
4.4.2024 - 16:01:12: Disconnected from Socket of http://192.168.178.4:3777/api/: WebSocket closed
4.4.2024 - 17:47:07: Trying to establish a connection to http://192.168.178.4:3777/...
4.4.2024 - 17:47:07: Found server at http://192.168.178.4:3777/. Establishing connection...
4.4.2024 - 17:47:07: Updating connection, active = ServerConnection(http://192.168.178.4:3777/api/, null, null, false, null, false), previous = null
4.4.2024 - 17:47:08: Trying to establish a connection to http://192.168.178.4:3777/...
4.4.2024 - 17:47:08: Found server at http://192.168.178.4:3777/. Establishing connection...
4.4.2024 - 17:47:08: Updating connection, active = ServerConnection(http://192.168.178.4:3777/api/, null, null, false, null, false), previous = null
4.4.2024 - 17:47:09: Trying to establish a connection to http://192.168.178.4:3777/...
4.4.2024 - 17:47:09: Found server at http://192.168.178.4:3777/. Establishing connection...
4.4.2024 - 17:47:09: Updating connection, active = ServerConnection(http://192.168.178.4:3777/api/, null, null, false, null, false), previous = null
4.4.2024 - 17:47:10: Snapshot from http://192.168.178.4:3777/api/ loaded
4.4.2024 - 17:47:10: Connected to Socket of http://192.168.178.4:3777/api/
4.4.2024 - 17:47:10: Successfully updated snapshot diff of http://192.168.178.4:3777/api/
nachdem ich einen anderen „Server auswählen“ gewählt habe und dann auf den bekannten Server verbunden habe läuft es jetzt wieder - bis zum nächsten Standby.
