Hallo Kai
Debug Dresden Elektronik Mega23M12:
TXT: 01/26/2022, 10:55:22 AM | symconExtensionCommand Topic | symcon/zigbee2mqtt/getDevice
TXT: 01/26/2022, 10:55:22 AM | symconExtensionCommand Payload | kitchen_floor_led
TXT: 01/26/2022, 10:55:22 AM | MQTT Topic | symcon/zigbee2mqtt/kitchen_floor_led/deviceInfo
TXT: 01/26/2022, 10:55:22 AM | MQTT Payload | {"zh":{"_events":{},"_eventsCount":0,"ID":30,"_type":"Router","_ieeeAddr":"0x00212effff009c76","_networkAddress":5772,"_manufacturerID":4405,"_endpoints":[{"_events":{},"_eventsCount":0,"ID":10,"profileID":49246,"deviceID":528,"inputClusters":[0,4096,4,3,5,6,8,768],"outputClusters":[25],"deviceNetworkAddress":5772,"deviceIeeeAddress":"0x00212effff009c76","clusters":{"genBasic":{"attributes":{"modelId":"FLS-PP3\u0000","manufacturerName":"dresden elektronik\u0000","powerSource":1,"zclVersion":1,"appVersion":2,"stackVersion":3,"hwVersion":1,"dateCode":"20151008\u0000","swBuildId":"020E.201000A0\u0000"}},"lightingColorCtrl":{"attributes":{"colorCapabilities":31,"colorTempPhysicalMin":153,"colorTempPhysicalMax":500,"colorMode":2,"currentX":24933,"currentY":24684,"enhancedCurrentHue":8901,"currentSaturation":120,"colorTemperature":250}},"genOnOff":{"attributes":{"onOff":0}},"genLevelCtrl":{"attributes":{"currentLevel":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"ID":11,"profileID":49246,"deviceID":256,"inputClusters":[0,4096,4,3,5,6,8],"outputClusters":[],"deviceNetworkAddress":5772,"deviceIeeeAddress":"0x00212effff009c76","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"dresden elektronik\u0000","_powerSource":"Mains (single phase)","_modelID":"FLS-PP3\u0000","_applicationVersion":2,"_stackVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20151008\u0000","_softwareBuildID":"020E.201000A0\u0000","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":2},"_lastSeen":1643190899787,"_defaultSendRequestWhen":"immediate","_linkquality":36},"_definition":{"exposes":[{"type":"light","features":[{"type":"binary","name":"state","property":"state_rgb","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On/off state of this light","endpoint":"rgb"},{"type":"numeric","name":"brightness","property":"brightness_rgb","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light","endpoint":"rgb"},{"type":"numeric","name":"color_temp","property":"color_temp_rgb","access":7,"unit":"mired","value_min":150,"value_max":500,"description":"Color temperature of this light","presets":[{"name":"coolest","value":150,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":500,"description":"Warmest temperature supported"}],"endpoint":"rgb"},{"type":"numeric","name":"color_temp_startup","property":"color_temp_startup_rgb","access":7,"unit":"mired","value_min":150,"value_max":500,"description":"Color temperature after cold power on of this light","presets":[{"name":"coolest","value":150,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":500,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}],"endpoint":"rgb"},{"type":"composite","property":"color_rgb","name":"color_xy","features":[{"type":"numeric","name":"x","property":"x","access":7},{"type":"numeric","name":"y","property":"y","access":7}],"description":"Color of this light in the CIE 1931 color space (x/y)","endpoint":"rgb"}],"endpoint":"rgb"},{"type":"light","features":[{"type":"binary","name":"state","property":"state_white","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On/off state of this light","endpoint":"white"},{"type":"numeric","name":"brightness","property":"brightness_white","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light","endpoint":"white"}],"endpoint":"white"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"],"options":[{"type":"binary","name":"color_sync","property":"color_sync","access":2,"value_on":true,"value_off":false,"description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true)."}]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","brightness","brightness_percent"],"options":[{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},{"key":["color","color_temp","color_temp_percent"],"options":[{"type":"binary","name":"color_sync","property":"color_sync","access":2,"value_on":true,"value_off":false,"description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true)."},{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},{"key":["transition"],"attr":[]},{"key":["rate"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["brightness_step","brightness_step_onoff"],"options":[{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},{"key":["color_temp_step"],"options":[{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},{"key":["hue_move","saturation_move"]},{"key":["hue_step","saturation_step"],"options":[{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},{"key":["color_temp_startup"]},{"key":["level_config"]},{"key":["power_on_behavior"]},{"key":["color_options"]},{"key":["color_mode"]},{"key":["effect","alert","flash"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"zigbeeModel":["FLS-PP3"],"model":"Mega23M12","vendor":"Dresden Elektronik","description":"ZigBee Light Link wireless electronic ballast","ota":{},"options":[{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."},{"type":"binary","name":"color_sync","property":"color_sync","access":2,"value_on":true,"value_off":false,"description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true)."}]}}
TXT: 01/26/2022, 10:55:22 AM | mapExposesToVariables:: All Exposes | [{"type":"light","features":[{"type":"binary","name":"state","property":"state_rgb","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On\/off state of this light","endpoint":"rgb"},{"type":"numeric","name":"brightness","property":"brightness_rgb","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light","endpoint":"rgb"},{"type":"numeric","name":"color_temp","property":"color_temp_rgb","access":7,"unit":"mired","value_min":150,"value_max":500,"description":"Color temperature of this light","presets":[{"name":"coolest","value":150,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds \/ 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds \/ 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds \/ 2200 Kelvin)"},{"name":"warmest","value":500,"description":"Warmest temperature supported"}],"endpoint":"rgb"},{"type":"numeric","name":"color_temp_startup","property":"color_temp_startup_rgb","access":7,"unit":"mired","value_min":150,"value_max":500,"description":"Color temperature after cold power on of this light","presets":[{"name":"coolest","value":150,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds \/ 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds \/ 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds \/ 2200 Kelvin)"},{"name":"warmest","value":500,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}],"endpoint":"rgb"},{"type":"composite","property":"color_rgb","name":"color_xy","features":[{"type":"numeric","name":"x","property":"x","access":7},{"type":"numeric","name":"y","property":"y","access":7}],"description":"Color of this light in the CIE 1931 color space (x\/y)","endpoint":"rgb"}],"endpoint":"rgb"},{"type":"light","features":[{"type":"binary","name":"state","property":"state_white","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On\/off state of this light","endpoint":"white"},{"type":"numeric","name":"brightness","property":"brightness_white","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light","endpoint":"white"}],"endpoint":"white"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}]
TXT: 01/26/2022, 10:55:22 AM | mapExposesToVariables:: Missed Exposes | {"light":[{"type":"binary","name":"state","property":"state_rgb","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On\/off state of this light","endpoint":"rgb"},{"type":"numeric","name":"brightness","property":"brightness_rgb","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light","endpoint":"rgb"},{"type":"numeric","name":"color_temp","property":"color_temp_rgb","access":7,"unit":"mired","value_min":150,"value_max":500,"description":"Color temperature of this light","presets":[{"name":"coolest","value":150,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds \/ 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds \/ 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds \/ 2200 Kelvin)"},{"name":"warmest","value":500,"description":"Warmest temperature supported"}],"endpoint":"rgb"},{"type":"numeric","name":"color_temp_startup","property":"color_temp_startup_rgb","access":7,"unit":"mired","value_min":150,"value_max":500,"description":"Color temperature after cold power on of this light","presets":[{"name":"coolest","value":150,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds \/ 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds \/ 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds \/ 2200 Kelvin)"},{"name":"warmest","value":500,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}],"endpoint":"rgb"},{"type":"composite","property":"color_rgb","name":"color_xy","features":[{"type":"numeric","name":"x","property":"x","access":7},{"type":"numeric","name":"y","property":"y","access":7}],"description":"Color of this light in the CIE 1931 color space (x\/y)","endpoint":"rgb"},{"type":"binary","name":"state","property":"state_white","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On\/off state of this light","endpoint":"white"},{"type":"numeric","name":"brightness","property":"brightness_white","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light","endpoint":"white"}],"switch":[]}
Debug Xiaomi JTYJ-GD-01LMBW:
XT: 01/26/2022, 10:55:53 AM | symconExtensionCommand Topic | symcon/zigbee2mqtt/getDevice
TXT: 01/26/2022, 10:55:53 AM | symconExtensionCommand Payload | kitchen_smoke
TXT: 01/26/2022, 10:55:53 AM | MQTT Topic | symcon/zigbee2mqtt/kitchen_smoke/deviceInfo
TXT: 01/26/2022, 10:55:53 AM | MQTT Payload | {"zh":{"_events":{},"_eventsCount":0,"ID":19,"_type":"EndDevice","_ieeeAddr":"0x00158d0003f1dc2a","_networkAddress":35171,"_manufacturerID":4151,"_endpoints":[{"_events":{},"_eventsCount":0,"ID":1,"profileID":260,"deviceID":1026,"inputClusters":[0,3,18,1280,12,1],"outputClusters":[25],"deviceNetworkAddress":35171,"deviceIeeeAddress":"0x00158d0003f1dc2a","clusters":{"genBasic":{"attributes":{"65281":{"1":3065,"3":29,"4":5032,"5":38,"6":[0,1],"8":4100,"10":0,"100":1,"150":0},"modelId":"lumi.sensor_smoke","appVersion":1,"manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":16,"dateCode":"20170314","swBuildId":"3000-0001"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b00216005f2","zoneState":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_smoke","_applicationVersion":1,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":16,"_dateCode":"20170314","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1643190449087,"_defaultSendRequestWhen":"immediate","_linkquality":40},"_definition":{"zigbeeModel":["lumi.sensor_smoke"],"model":"JTYJ-GD-01LM/BW","description":"MiJia Honeywell smoke detector","vendor":"Xiaomi","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"ssIasZone","type":"commandStatusChangeNotification"},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["sensitivity"]},{"key":["selftest"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"exposes":[{"type":"binary","name":"smoke","property":"smoke","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected smoke"},{"type":"binary","name":"battery_low","property":"battery_low","access":1,"value_on":true,"value_off":false,"description":"Indicates if the battery of this device is almost empty"},{"type":"binary","name":"tamper","property":"tamper","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device is tampered"},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"enum","name":"sensitivity","property":"sensitivity","access":3,"values":["low","medium","high"]},{"type":"numeric","name":"smoke_density","property":"smoke_density","access":1},{"type":"enum","name":"selftest","property":"selftest","access":2,"values":[""]},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"mV","description":"Voltage of the battery in millivolts"},{"type":"binary","name":"test","property":"test","access":1,"value_on":true,"value_off":false,"description":"Test mode activated"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"options":[]}}
TXT: 01/26/2022, 10:55:53 AM | mapExposesToVariables:: All Exposes | [{"type":"binary","name":"smoke","property":"smoke","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected smoke"},{"type":"binary","name":"battery_low","property":"battery_low","access":1,"value_on":true,"value_off":false,"description":"Indicates if the battery of this device is almost empty"},{"type":"binary","name":"tamper","property":"tamper","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device is tampered"},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"enum","name":"sensitivity","property":"sensitivity","access":3,"values":["low","medium","high"]},{"type":"numeric","name":"smoke_density","property":"smoke_density","access":1},{"type":"enum","name":"selftest","property":"selftest","access":2,"values":[""]},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"mV","description":"Voltage of the battery in millivolts"},{"type":"binary","name":"test","property":"test","access":1,"value_on":true,"value_off":false,"description":"Test mode activated"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}]
TXT: 01/26/2022, 10:55:53 AM | mapExposesToVariables:: Missed Exposes | {"light":[],"switch":[],"0":{"type":"numeric","name":"smoke_density","property":"smoke_density","access":1},"1":{"type":"enum","name":"selftest","property":"selftest","access":2,"values":[""]},"2":{"type":"binary","name":"test","property":"test","access":1,"value_on":true,"value_off":false,"description":"Test mode activated"}}
Dank und Gruss!
Tom
