Nabend,
ich hab die module.php jetzt ein bisschen abgeaendert so dass man die Farbe und Saettigung auswaehlen kann.
Leider kriege ich die Farbe bei der Saettigungsuebergabe nicht hin. Hat da einer ne Idee. (Da wo die 0 steht unter function Saturation)
// Klassendefinition
class YeelightColorBulb extends IPSModule {
// Der Konstruktor des Moduls
public function __construct($InstanceID) {
// Diese Zeile nicht löschen
parent::__construct($InstanceID);
// Selbsterstellter Code
public function Create() {
parent::Create();
$this->RegisterPropertyString("ipadress", "");
$this->RequireParent("{3CFF0FD9-E306-41DB-9B5A-9D06D38576C3}"); // CLIENT SOCKET
public function ApplyChanges() {
parent::ApplyChanges();
$this->RegisterVariableBoolean("power", "Power", "~Switch", 0);
$this->RegisterVariableInteger("bright", "Brightness", "~Intensity.100", 1);
$this->RegisterVariableInteger("ct", "Color Temperature", "~Intensity.65535", 2);
$this->RegisterVariableInteger("rgb", "Color", "~HexColor", 3);
$this->RegisterVariableString("hue", "Hue", "~String", 4);
$this->RegisterVariableInteger("sat", "Saturation", "~Intensity.100", 5);
$this->RegisterVariableInteger("color_mode", "Color Mode", "", 6);
$this->GetConfigurationForParent();
$this->EnableAction("power");
$this->EnableAction("bright");
$this->EnableAction("rgb");
$this->EnableAction("sat");
public function GetConfigurationForParent()
$host = $this->ReadPropertyString("ipadress");
$port = 55443;
return "{\"Host\": \"$host\", \"Port\": \"$port\"}";
// Lese alle Konfigurationsdaten aus
public function readStatesFromDevice() {
$this->buildAndSendCommand('444', 'get_prop', array('power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode'));
public function ReceiveData($JSONString)
$data = json_decode($JSONString);
$payload = json_decode($data->Buffer);
//27/12/2017 16:06:33 | Receive | {"id":1, "result":["off","27","2945","255","359","100","2"]}
// this is our Datafetch from Configuration GUI, which has a fixed sorting of values
if (isset($payload->id) && '444' == $payload->id) {
SetValueBoolean(IPS_GetObjectIDByIdent("power", $this->InstanceID), 'on' == $payload->result[0] ? TRUE : FALSE);
SetValueInteger(IPS_GetObjectIDByIdent("bright", $this->InstanceID), $payload->result[1]);
SetValueInteger(IPS_GetObjectIDByIdent("ct", $this->InstanceID), $payload->result[2]);
SetValueInteger(IPS_GetObjectIDByIdent("rgb", $this->InstanceID), $payload->result[3]);
SetValueString(IPS_GetObjectIDByIdent("hue", $this->InstanceID), $payload->result[4]);
SetValueInteger(IPS_GetObjectIDByIdent("sat", $this->InstanceID), $payload->result[5]);
SetValueInteger(IPS_GetObjectIDByIdent("color_mode", $this->InstanceID), $payload->result[6]);
IPS_LogMessage("Reciever", "done");
return;
//IPS_LogMessage("Receiver", utf8_decode($data->Buffer));
//27/12/2017 17:40:01 | Receiver | {"method":"props","params":{"power":"off"}}
if (isset($payload->method) && 'props' == $payload->method) {
foreach ($payload->params as $key => $val) {
if ('power' == $key) {
SetValueBoolean(IPS_GetObjectIDByIdent("power", $this->InstanceID), 'on' == $val ? TRUE : FALSE);
} else if ('bright' == $key) {
SetValueInteger(IPS_GetObjectIDByIdent("bright", $this->InstanceID), $val);
} else if ('ct' == $key) {
SetValueInteger(IPS_GetObjectIDByIdent("ct", $this->InstanceID), $val);
} else if ('rgb' == $key) {
SetValueInteger(IPS_GetObjectIDByIdent("rgb", $this->InstanceID), $val);
} else if ('hue' == $key) {
SetValueString(IPS_GetObjectIDByIdent("hue", $this->InstanceID), $val);
} else if ('sat' == $key) {
SetValueInteger(IPS_GetObjectIDByIdent("sat", $this->InstanceID), $val);
} else if ('color_mode' == $key) {
SetValueInteger(IPS_GetObjectIDByIdent("color_mode", $this->InstanceID), $val);
} else {
IPS_LogMessage("YeelightColorBulb", "Unknown Notification received " . utf8_decode($data->Buffer));
public function RequestAction($Ident, $Value)
IPS_LogMessage("RequestAction ", utf8_decode($Ident) . " value: " . $Value);
switch ($Ident) {
case "power":
$this->Power($Value);
break;
case "bright":
$this->Brightness($Value);
break;
case "rgb":
$this->RGB($Value);
break;
case "sat":
$this->Saturation($Value);
break;
default:
throw new Exception("Invalid Ident: " . $Ident);
public function Power($Value)
$this->buildAndSendCommand(10, "set_power", array($Value ? 'on' : 'off', 'smooth', 500));
public function Brightness($Value)
$this->buildAndSendCommand('20', "set_bright", array($Value));
public function RGB($Value)
$this->buildAndSendCommand(10, "set_rgb", array($Value, 'smooth', 500));
public function Saturation($Value)
$this->buildAndSendCommand(10, "set_hsv", array(0, $Value, 'smooth', 500));
private function buildAndSendCommand($id, $method, $params)
$Data = Array(
'id' => $id,
'method' => $method,
'params' => $params
$payload = json_encode($Data);
$this->SendDataToParent(json_encode(Array(
"DataID" => "{79827379-F36E-4ADA-8A95-5F8D1DC92FA9}",
"Buffer" => $payload . "
