Kla…
TXT: 26.03.2018 22:14:08.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":6486}
HEX: 26.03.2018 22:14:08.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 36 34 38 36 7D
TXT: 26.03.2018 22:14:08.00 | Receive Direct | {"id":6486,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":383580,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:08.00 | Receive Direct | 7B 22 69 64 22 3A 36 34 38 36 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 33 35 38 30 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:08.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:08.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:08.00 | Receive Direct Result.currentaudiostream.bitrate | 383580
HEX: 26.03.2018 22:14:08.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 33 35 38 30
TXT: 26.03.2018 22:14:08.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:08.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:08.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:08.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:08.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:08.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:08.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:08.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:08.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:08.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:08.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:08.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:08.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:08.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:08.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:08.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:08.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:08.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:08.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:08.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:08.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:08.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:08.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:08.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:08.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:08.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:08.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:08.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:08.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:08.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:08.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:08.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:08.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:08.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:08.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:08.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:08.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:08.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:08.00 | GetProperties.currentaudiostream.bitrate | 383580
HEX: 26.03.2018 22:14:08.00 | GetProperties.currentaudiostream.bitrate | 33 38 33 35 38 30
TXT: 26.03.2018 22:14:08.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:08.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:08.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:08.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:08.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:08.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:08.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:08.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:08.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:08.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:08.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:08.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:08.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:08.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:08.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:08.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:08.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:08.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:08.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:08.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:08.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:08.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:08.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:08.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:08.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:08.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:08.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:08.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:08.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:08.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:08.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:08.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:08.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:08.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:08.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:08.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:08.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:08.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:10.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":7905}
HEX: 26.03.2018 22:14:10.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 37 39 30 35 7D
TXT: 26.03.2018 22:14:10.00 | Receive Direct | {"id":7905,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":391479,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:10.00 | Receive Direct | 7B 22 69 64 22 3A 37 39 30 35 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 39 31 34 37 39 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:10.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:10.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:10.00 | Receive Direct Result.currentaudiostream.bitrate | 391479
HEX: 26.03.2018 22:14:10.00 | Receive Direct Result.currentaudiostream.bitrate | 33 39 31 34 37 39
TXT: 26.03.2018 22:14:10.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:10.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:10.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:10.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:10.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:10.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:10.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:10.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:10.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:10.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:10.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:10.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:10.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:10.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:10.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:10.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:10.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:10.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:10.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:10.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:10.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:10.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:10.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:10.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:10.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:10.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:10.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:10.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:10.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:10.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:10.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:10.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:10.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:10.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:10.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:10.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:10.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:10.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:10.00 | GetProperties.currentaudiostream.bitrate | 391479
HEX: 26.03.2018 22:14:10.00 | GetProperties.currentaudiostream.bitrate | 33 39 31 34 37 39
TXT: 26.03.2018 22:14:10.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:10.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:10.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:10.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:10.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:10.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:10.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:10.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:10.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:10.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:10.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:10.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:10.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:10.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:10.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:10.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:10.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:10.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:10.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:10.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:10.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:10.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:10.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:10.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:10.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:10.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:10.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:10.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:10.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:10.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:10.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:10.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:10.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:10.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:10.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:10.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:10.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:10.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:12.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":9800}
HEX: 26.03.2018 22:14:12.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 39 38 30 30 7D
TXT: 26.03.2018 22:14:12.00 | Receive Direct | {"id":9800,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":381767,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:12.00 | Receive Direct | 7B 22 69 64 22 3A 39 38 30 30 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 31 37 36 37 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:12.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:12.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:12.00 | Receive Direct Result.currentaudiostream.bitrate | 381767
HEX: 26.03.2018 22:14:12.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 31 37 36 37
TXT: 26.03.2018 22:14:12.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:12.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:12.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:12.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:12.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:12.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:12.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:12.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:12.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:12.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:12.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:12.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:12.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:12.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:12.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:12.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:12.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:12.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:12.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:12.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:12.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:12.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:12.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:12.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:12.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:12.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:12.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:12.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:12.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:12.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:12.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:12.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:12.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:12.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:12.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:12.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:12.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:12.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:12.00 | GetProperties.currentaudiostream.bitrate | 381767
HEX: 26.03.2018 22:14:12.00 | GetProperties.currentaudiostream.bitrate | 33 38 31 37 36 37
TXT: 26.03.2018 22:14:12.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:12.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:12.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:12.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:12.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:12.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:12.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:12.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:12.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:12.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:12.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:12.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:12.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:12.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:12.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:12.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:12.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:12.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:12.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:12.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:12.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:12.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:12.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:12.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:12.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:12.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:12.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:12.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:12.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:12.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:12.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:12.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:12.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:12.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:12.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:12.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:12.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:12.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:15.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":1033}
HEX: 26.03.2018 22:14:15.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 31 30 33 33 7D
TXT: 26.03.2018 22:14:15.00 | Receive Direct | {"id":1033,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":384536,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:15.00 | Receive Direct | 7B 22 69 64 22 3A 31 30 33 33 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 34 35 33 36 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:15.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:15.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:15.00 | Receive Direct Result.currentaudiostream.bitrate | 384536
HEX: 26.03.2018 22:14:15.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 34 35 33 36
TXT: 26.03.2018 22:14:15.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:15.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:15.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:15.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:15.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:15.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:15.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:15.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:15.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:15.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:15.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:15.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:15.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:15.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:15.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:15.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:15.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:15.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:15.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:15.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:15.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:15.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:15.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:15.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:15.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:15.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:15.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:15.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:15.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:15.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:15.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:15.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:15.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:15.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:15.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:15.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:15.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:15.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:15.00 | GetProperties.currentaudiostream.bitrate | 384536
HEX: 26.03.2018 22:14:15.00 | GetProperties.currentaudiostream.bitrate | 33 38 34 35 33 36
TXT: 26.03.2018 22:14:15.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:15.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:15.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:15.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:15.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:15.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:15.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:15.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:15.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:15.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:15.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:15.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:15.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:15.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:15.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:15.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:15.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:15.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:15.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:15.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:15.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:15.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:15.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:15.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:15.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:15.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:15.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:15.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:15.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:15.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:15.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:15.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:15.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:15.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:15.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:15.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:15.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:15.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:17.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":2525}
HEX: 26.03.2018 22:14:17.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 32 35 32 35 7D
TXT: 26.03.2018 22:14:17.00 | Receive Direct | {"id":2525,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":384570,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:17.00 | Receive Direct | 7B 22 69 64 22 3A 32 35 32 35 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 34 35 37 30 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:17.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:17.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:17.00 | Receive Direct Result.currentaudiostream.bitrate | 384570
HEX: 26.03.2018 22:14:17.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 34 35 37 30
TXT: 26.03.2018 22:14:17.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:17.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:17.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:17.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:17.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:17.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:17.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:17.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:17.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:17.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:17.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:17.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:17.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:17.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:17.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:17.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:17.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:17.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:17.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:17.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:17.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:17.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:17.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:17.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:17.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:17.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:17.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:17.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:17.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:17.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:17.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:17.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:17.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:17.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:17.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:17.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:17.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:17.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:17.00 | GetProperties.currentaudiostream.bitrate | 384570
HEX: 26.03.2018 22:14:17.00 | GetProperties.currentaudiostream.bitrate | 33 38 34 35 37 30
TXT: 26.03.2018 22:14:17.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:17.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:17.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:17.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:17.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:17.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:17.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:17.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:17.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:17.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:17.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:17.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:17.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:17.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:17.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:17.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:17.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:17.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:17.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:17.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:17.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:17.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:17.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:17.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:17.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:17.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:17.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:17.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:17.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:17.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:17.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:17.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:17.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:17.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:17.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:17.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:17.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:17.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:19.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":4268}
HEX: 26.03.2018 22:14:19.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 34 32 36 38 7D
TXT: 26.03.2018 22:14:19.00 | Receive Direct | {"id":4268,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":387853,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:19.00 | Receive Direct | 7B 22 69 64 22 3A 34 32 36 38 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 37 38 35 33 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:19.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:19.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:19.00 | Receive Direct Result.currentaudiostream.bitrate | 387853
HEX: 26.03.2018 22:14:19.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 37 38 35 33
TXT: 26.03.2018 22:14:19.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:19.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:19.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:19.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:19.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:19.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:19.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:19.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:19.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:19.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:19.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:19.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:19.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:19.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:19.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:19.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:19.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:19.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:19.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:19.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:19.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:19.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:19.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:19.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:19.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:19.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:19.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:19.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:19.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:19.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:19.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:19.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:19.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:19.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:19.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:19.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:19.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:19.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:19.00 | GetProperties.currentaudiostream.bitrate | 387853
HEX: 26.03.2018 22:14:19.00 | GetProperties.currentaudiostream.bitrate | 33 38 37 38 35 33
TXT: 26.03.2018 22:14:19.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:19.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:19.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:19.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:19.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:19.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:19.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:19.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:19.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:19.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:19.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:19.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:19.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:19.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:19.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:19.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:19.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:19.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:19.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:19.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:19.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:19.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:19.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:19.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:19.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:19.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:19.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:19.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:19.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:19.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:19.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:19.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:19.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:19.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:19.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:19.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:19.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:19.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:21.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":5793}
HEX: 26.03.2018 22:14:21.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 35 37 39 33 7D
TXT: 26.03.2018 22:14:21.00 | Receive Direct | {"id":5793,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":387739,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:21.00 | Receive Direct | 7B 22 69 64 22 3A 35 37 39 33 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 37 37 33 39 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:21.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:21.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:21.00 | Receive Direct Result.currentaudiostream.bitrate | 387739
HEX: 26.03.2018 22:14:21.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 37 37 33 39
TXT: 26.03.2018 22:14:21.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:21.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:21.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:21.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:21.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:21.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:21.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:21.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:21.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:21.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:21.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:21.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:21.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:21.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:21.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:21.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:21.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:21.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:21.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:21.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:21.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:21.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:21.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:21.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:21.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:21.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:21.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:21.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:21.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:21.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:21.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:21.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:21.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:21.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:21.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:21.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:21.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:21.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:21.00 | GetProperties.currentaudiostream.bitrate | 387739
HEX: 26.03.2018 22:14:21.00 | GetProperties.currentaudiostream.bitrate | 33 38 37 37 33 39
TXT: 26.03.2018 22:14:21.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:21.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:21.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:21.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:21.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:21.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:21.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:21.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:21.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:21.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:21.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:21.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:21.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:21.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:21.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:21.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:21.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:21.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:21.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:21.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:21.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:21.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:21.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:21.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:21.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:21.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:21.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:21.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:21.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:21.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:21.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:21.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:21.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:21.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:21.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:21.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:21.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:21.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:23.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":7588}
HEX: 26.03.2018 22:14:23.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 37 35 38 38 7D
TXT: 26.03.2018 22:14:23.00 | Receive Direct | {"id":7588,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":378744,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:23.00 | Receive Direct | 7B 22 69 64 22 3A 37 35 38 38 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 37 38 37 34 34 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:23.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:23.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:23.00 | Receive Direct Result.currentaudiostream.bitrate | 378744
HEX: 26.03.2018 22:14:23.00 | Receive Direct Result.currentaudiostream.bitrate | 33 37 38 37 34 34
TXT: 26.03.2018 22:14:23.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:23.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:23.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:23.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:23.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:23.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:23.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:23.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:23.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:23.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:23.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:23.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:23.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:23.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:23.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:23.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:23.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:23.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:23.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:23.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:23.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:23.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:23.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:23.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:23.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:23.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:23.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:23.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:23.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:23.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:23.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:23.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:23.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:23.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:23.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:23.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:23.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:23.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:23.00 | GetProperties.currentaudiostream.bitrate | 378744
HEX: 26.03.2018 22:14:23.00 | GetProperties.currentaudiostream.bitrate | 33 37 38 37 34 34
TXT: 26.03.2018 22:14:23.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:23.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:23.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:23.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:23.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:23.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:23.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:23.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:23.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:23.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:23.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:23.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:23.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:23.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:23.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:23.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:23.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:23.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:23.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:23.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:23.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:23.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:23.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:23.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:23.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:23.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:23.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:23.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:23.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:23.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:23.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:23.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:23.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:23.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:23.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:23.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:23.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:23.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:25.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":8786}
HEX: 26.03.2018 22:14:25.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 38 37 38 36 7D
TXT: 26.03.2018 22:14:25.00 | Receive Direct | {"id":8786,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":387790,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:25.00 | Receive Direct | 7B 22 69 64 22 3A 38 37 38 36 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 37 37 39 30 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:25.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:25.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:25.00 | Receive Direct Result.currentaudiostream.bitrate | 387790
HEX: 26.03.2018 22:14:25.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 37 37 39 30
TXT: 26.03.2018 22:14:25.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:25.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:25.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:25.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:25.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:25.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:25.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:25.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:25.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:25.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:25.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:25.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:25.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:25.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:25.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:25.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:25.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:25.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:25.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:25.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:25.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:25.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:25.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:25.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:25.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:25.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:25.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:25.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:25.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:25.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:25.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:25.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:25.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:25.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:25.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:25.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:25.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:25.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:25.00 | GetProperties.currentaudiostream.bitrate | 387790
HEX: 26.03.2018 22:14:25.00 | GetProperties.currentaudiostream.bitrate | 33 38 37 37 39 30
TXT: 26.03.2018 22:14:25.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:25.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:25.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:25.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:25.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:25.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:25.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:25.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:25.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:25.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:25.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:25.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:25.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:25.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:25.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:25.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:25.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:25.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:25.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:25.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:25.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:25.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:25.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:25.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:25.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:25.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:25.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:25.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:25.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:25.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:25.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:25.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:25.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:25.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:25.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:25.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:25.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:25.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:28.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":283}
HEX: 26.03.2018 22:14:28.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 32 38 33 7D
TXT: 26.03.2018 22:14:28.00 | Receive Direct | {"id":283,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":387896,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:28.00 | Receive Direct | 7B 22 69 64 22 3A 32 38 33 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 37 38 39 36 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:28.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:28.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:28.00 | Receive Direct Result.currentaudiostream.bitrate | 387896
HEX: 26.03.2018 22:14:28.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 37 38 39 36
TXT: 26.03.2018 22:14:28.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:28.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:28.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:28.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:28.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:28.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:28.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:28.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:28.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:28.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:28.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:28.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:28.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:28.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:28.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:28.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:28.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:28.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:28.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:28.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:28.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:28.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:28.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:28.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:28.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:28.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:28.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:28.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:28.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:28.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:28.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:28.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:28.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:28.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:28.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:28.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:28.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:28.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:28.00 | GetProperties.currentaudiostream.bitrate | 387896
HEX: 26.03.2018 22:14:28.00 | GetProperties.currentaudiostream.bitrate | 33 38 37 38 39 36
TXT: 26.03.2018 22:14:28.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:28.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:28.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:28.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:28.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:28.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:28.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:28.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:28.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:28.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:28.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:28.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:28.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:28.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:28.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:28.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:28.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:28.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:28.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:28.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:28.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:28.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:28.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:28.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:28.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:28.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:28.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:28.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:28.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:28.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:28.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:28.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:28.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:28.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:28.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:28.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:28.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:28.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:30.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":2391}
HEX: 26.03.2018 22:14:30.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 32 33 39 31 7D
TXT: 26.03.2018 22:14:30.00 | Receive Direct | {"id":2391,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":378610,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:30.00 | Receive Direct | 7B 22 69 64 22 3A 32 33 39 31 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 37 38 36 31 30 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:30.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:30.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:30.00 | Receive Direct Result.currentaudiostream.bitrate | 378610
HEX: 26.03.2018 22:14:30.00 | Receive Direct Result.currentaudiostream.bitrate | 33 37 38 36 31 30
TXT: 26.03.2018 22:14:30.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:30.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:30.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:30.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:30.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:30.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:30.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:30.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:30.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:30.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:30.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:30.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:30.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:30.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:30.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:30.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:30.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:30.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:30.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:30.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:30.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:30.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:30.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:30.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:30.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:30.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:30.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:30.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:30.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:30.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:30.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:30.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:30.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:30.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:30.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:30.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:30.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:30.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:30.00 | GetProperties.currentaudiostream.bitrate | 378610
HEX: 26.03.2018 22:14:30.00 | GetProperties.currentaudiostream.bitrate | 33 37 38 36 31 30
TXT: 26.03.2018 22:14:30.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:30.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:30.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:30.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:30.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:30.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:30.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:30.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:30.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:30.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:30.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:30.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:30.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:30.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:30.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:30.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:30.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:30.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:30.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:30.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:30.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:30.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:30.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:30.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:30.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:30.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:30.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:30.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:30.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:30.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:30.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:30.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:30.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:30.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:30.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:30.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:30.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:30.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:32.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":4325}
HEX: 26.03.2018 22:14:32.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 34 33 32 35 7D
TXT: 26.03.2018 22:14:32.00 | Receive Direct | {"id":4325,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":384190,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:32.00 | Receive Direct | 7B 22 69 64 22 3A 34 33 32 35 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 34 31 39 30 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:32.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:32.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:32.00 | Receive Direct Result.currentaudiostream.bitrate | 384190
HEX: 26.03.2018 22:14:32.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 34 31 39 30
TXT: 26.03.2018 22:14:32.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:32.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:32.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:32.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:32.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:32.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:32.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:32.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:32.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:32.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:32.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:32.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:32.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:32.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:32.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:32.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:32.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:32.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:32.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:32.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:32.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:32.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:32.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:32.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:32.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:32.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:32.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:32.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:32.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:32.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:32.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:32.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:32.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:32.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:32.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:32.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:32.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:32.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:32.00 | GetProperties.currentaudiostream.bitrate | 384190
HEX: 26.03.2018 22:14:32.00 | GetProperties.currentaudiostream.bitrate | 33 38 34 31 39 30
TXT: 26.03.2018 22:14:32.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:32.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:32.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:32.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:32.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:32.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:32.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:32.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:32.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:32.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:32.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:32.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:32.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:32.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:32.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:32.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:32.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:32.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:32.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:32.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:32.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:32.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:32.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:32.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:32.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:32.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:32.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:32.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:32.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:32.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:32.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:32.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:32.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:32.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:32.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:32.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:32.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:32.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:34.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":6309}
HEX: 26.03.2018 22:14:34.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 36 33 30 39 7D
TXT: 26.03.2018 22:14:34.00 | Receive Direct | {"id":6309,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":387754,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:34.00 | Receive Direct | 7B 22 69 64 22 3A 36 33 30 39 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 37 37 35 34 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:34.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:34.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:34.00 | Receive Direct Result.currentaudiostream.bitrate | 387754
HEX: 26.03.2018 22:14:34.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 37 37 35 34
TXT: 26.03.2018 22:14:34.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:34.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:34.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:34.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:34.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:34.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:34.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:34.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:34.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:34.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:34.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:34.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:34.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:34.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:34.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:34.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:34.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:34.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:34.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:34.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:34.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:34.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:34.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:34.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:34.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:34.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:34.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:34.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:34.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:34.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:34.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:34.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:34.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:34.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:34.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:34.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:34.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:34.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:34.00 | GetProperties.currentaudiostream.bitrate | 387754
HEX: 26.03.2018 22:14:34.00 | GetProperties.currentaudiostream.bitrate | 33 38 37 37 35 34
TXT: 26.03.2018 22:14:34.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:34.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:34.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:34.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:34.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:34.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:34.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:34.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:34.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:34.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:34.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:34.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:34.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:34.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:34.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:34.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:34.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:34.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:34.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:34.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:34.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:34.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:34.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:34.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:34.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:34.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:34.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:34.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:34.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:34.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:34.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:34.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:34.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:34.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:34.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:34.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:34.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:34.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:36.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":7836}
HEX: 26.03.2018 22:14:36.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 37 38 33 36 7D
TXT: 26.03.2018 22:14:36.00 | Receive Direct | {"id":7836,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":384853,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:36.00 | Receive Direct | 7B 22 69 64 22 3A 37 38 33 36 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 34 38 35 33 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:36.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:36.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:36.00 | Receive Direct Result.currentaudiostream.bitrate | 384853
HEX: 26.03.2018 22:14:36.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 34 38 35 33
TXT: 26.03.2018 22:14:36.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:36.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:36.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:36.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:36.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:36.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:36.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:36.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:36.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:36.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:36.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:36.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:36.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:36.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:36.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:36.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:36.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:36.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:36.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:36.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:36.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:36.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:36.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:36.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:36.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:36.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:36.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:36.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:36.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:36.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:36.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:36.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:36.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:36.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:36.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:36.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:36.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:36.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:36.00 | GetProperties.currentaudiostream.bitrate | 384853
HEX: 26.03.2018 22:14:36.00 | GetProperties.currentaudiostream.bitrate | 33 38 34 38 35 33
TXT: 26.03.2018 22:14:36.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:36.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:36.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:36.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:36.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:36.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:36.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:36.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:36.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:36.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:36.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:36.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:36.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:36.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:36.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:36.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:36.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:36.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:36.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:36.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:36.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:36.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:36.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:36.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:36.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:36.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:36.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:36.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:36.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:36.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:36.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:36.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:36.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:36.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:36.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:36.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:36.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:36.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:38.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":9584}
HEX: 26.03.2018 22:14:38.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 39 35 38 34 7D
TXT: 26.03.2018 22:14:38.00 | Receive Direct | {"id":9584,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":384591,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:38.00 | Receive Direct | 7B 22 69 64 22 3A 39 35 38 34 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 34 35 39 31 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:38.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:38.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:38.00 | Receive Direct Result.currentaudiostream.bitrate | 384591
HEX: 26.03.2018 22:14:38.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 34 35 39 31
TXT: 26.03.2018 22:14:38.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:38.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:38.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:38.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:38.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:38.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:38.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:38.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:38.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:38.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:38.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:38.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:38.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:38.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:38.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:38.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:38.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:38.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:38.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:38.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:38.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:38.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:38.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:38.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:38.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:38.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:38.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:38.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:38.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:38.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:38.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:38.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:38.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:38.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:38.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:38.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:38.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:38.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:38.00 | GetProperties.currentaudiostream.bitrate | 384591
HEX: 26.03.2018 22:14:38.00 | GetProperties.currentaudiostream.bitrate | 33 38 34 35 39 31
TXT: 26.03.2018 22:14:38.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:38.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:38.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:38.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:38.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:38.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:38.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:38.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:38.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:38.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:38.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:38.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:38.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:38.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:38.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:38.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:38.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:38.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:38.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:38.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:38.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:38.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:38.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:38.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:38.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:38.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:38.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:38.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:38.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:38.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:38.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:38.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:38.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:38.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:38.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:38.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:38.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:38.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:41.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":1126}
HEX: 26.03.2018 22:14:41.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 31 31 32 36 7D
TXT: 26.03.2018 22:14:41.00 | Receive Direct | {"id":1126,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":387949,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:41.00 | Receive Direct | 7B 22 69 64 22 3A 31 31 32 36 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 37 39 34 39 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:41.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:41.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:41.00 | Receive Direct Result.currentaudiostream.bitrate | 387949
HEX: 26.03.2018 22:14:41.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 37 39 34 39
TXT: 26.03.2018 22:14:41.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:41.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:41.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:41.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:41.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:41.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:41.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:41.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:41.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:41.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:41.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:41.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:41.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:41.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:41.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:41.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:41.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:41.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:41.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:41.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:41.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:41.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:41.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:41.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:41.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:41.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:41.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:41.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:41.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:41.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:41.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:41.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:41.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:41.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:41.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:41.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:41.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:41.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:41.00 | GetProperties.currentaudiostream.bitrate | 387949
HEX: 26.03.2018 22:14:41.00 | GetProperties.currentaudiostream.bitrate | 33 38 37 39 34 39
TXT: 26.03.2018 22:14:41.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:41.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:41.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:41.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:41.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:41.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:41.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:41.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:41.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:41.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:41.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:41.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:41.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:41.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:41.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:41.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:41.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:41.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:41.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:41.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:41.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:41.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:41.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:41.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:41.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:41.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:41.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:41.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:41.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:41.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:41.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:41.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:41.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:41.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:41.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:41.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:41.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:41.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:43.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":2879}
HEX: 26.03.2018 22:14:43.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 32 38 37 39 7D
TXT: 26.03.2018 22:14:43.00 | Receive Direct | {"id":2879,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":381543,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:43.00 | Receive Direct | 7B 22 69 64 22 3A 32 38 37 39 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 31 35 34 33 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:43.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:43.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:43.00 | Receive Direct Result.currentaudiostream.bitrate | 381543
HEX: 26.03.2018 22:14:43.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 31 35 34 33
TXT: 26.03.2018 22:14:43.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:43.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:43.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:43.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:43.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:43.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:43.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:43.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:43.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:43.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:43.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:43.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:43.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:43.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:43.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:43.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:43.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:43.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:43.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:43.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:43.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:43.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:43.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:43.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:43.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:43.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:43.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:43.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:43.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:43.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:43.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:43.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:43.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:43.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:43.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:43.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:43.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:43.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:43.00 | GetProperties.currentaudiostream.bitrate | 381543
HEX: 26.03.2018 22:14:43.00 | GetProperties.currentaudiostream.bitrate | 33 38 31 35 34 33
TXT: 26.03.2018 22:14:43.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:43.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:43.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:43.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:43.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:43.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:43.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:43.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:43.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:43.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:43.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:43.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:43.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:43.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:43.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:43.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:43.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:43.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:43.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:43.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:43.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:43.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:43.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:43.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:43.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:43.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:43.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:43.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:43.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:43.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:43.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:43.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:43.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:43.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:43.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:43.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:43.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:43.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:45.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":4134}
HEX: 26.03.2018 22:14:45.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 34 31 33 34 7D
TXT: 26.03.2018 22:14:45.00 | Receive Direct | {"id":4134,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":384750,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:45.00 | Receive Direct | 7B 22 69 64 22 3A 34 31 33 34 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 34 37 35 30 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:45.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:45.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:45.00 | Receive Direct Result.currentaudiostream.bitrate | 384750
HEX: 26.03.2018 22:14:45.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 34 37 35 30
TXT: 26.03.2018 22:14:45.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:45.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:45.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:45.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:45.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:45.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:45.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:45.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:45.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:45.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:45.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:45.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:45.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:45.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:45.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:45.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:45.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:45.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:45.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:45.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:45.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:45.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:45.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:45.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:45.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:45.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:45.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:45.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:45.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:45.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:45.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:45.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:45.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:45.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:45.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:45.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:45.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:45.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:45.00 | GetProperties.currentaudiostream.bitrate | 384750
HEX: 26.03.2018 22:14:45.00 | GetProperties.currentaudiostream.bitrate | 33 38 34 37 35 30
TXT: 26.03.2018 22:14:45.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:45.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:45.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:45.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:45.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:45.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:45.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:45.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:45.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:45.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:45.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:45.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:45.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:45.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:45.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:45.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:45.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:45.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:45.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:45.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:45.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:45.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:45.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:45.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:45.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:45.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:45.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:45.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:45.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:45.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:45.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:45.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:45.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:45.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:45.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:45.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:45.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:45.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:47.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":5635}
HEX: 26.03.2018 22:14:47.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 35 36 33 35 7D
TXT: 26.03.2018 22:14:47.00 | Receive Direct | {"id":5635,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":383820,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:47.00 | Receive Direct | 7B 22 69 64 22 3A 35 36 33 35 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 33 38 32 30 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:47.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:47.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:47.00 | Receive Direct Result.currentaudiostream.bitrate | 383820
HEX: 26.03.2018 22:14:47.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 33 38 32 30
TXT: 26.03.2018 22:14:47.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:47.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:47.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:47.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:47.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:47.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:47.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:47.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:47.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:47.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:47.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:47.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:47.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:47.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:47.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:47.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:47.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:47.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:47.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:47.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:47.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:47.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:47.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:47.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:47.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:47.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:47.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:47.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:47.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:47.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:47.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:47.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:47.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:47.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:47.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:47.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:47.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:47.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:47.00 | GetProperties.currentaudiostream.bitrate | 383820
HEX: 26.03.2018 22:14:47.00 | GetProperties.currentaudiostream.bitrate | 33 38 33 38 32 30
TXT: 26.03.2018 22:14:47.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:47.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:47.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:47.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:47.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:47.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:47.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:47.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:47.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:47.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:47.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:47.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:47.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:47.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:47.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:47.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:47.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:47.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:47.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:47.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:47.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:47.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:47.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:47.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:47.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:47.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:47.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:47.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:47.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:47.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:47.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:47.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:47.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:47.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:47.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:47.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:47.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:47.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:49.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":6908}
HEX: 26.03.2018 22:14:49.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 36 39 30 38 7D
TXT: 26.03.2018 22:14:49.00 | Receive Direct | {"id":6908,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":385557,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:49.00 | Receive Direct | 7B 22 69 64 22 3A 36 39 30 38 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 35 35 35 37 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:49.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:49.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:49.00 | Receive Direct Result.currentaudiostream.bitrate | 385557
HEX: 26.03.2018 22:14:49.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 35 35 35 37
TXT: 26.03.2018 22:14:49.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:49.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:49.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:49.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:49.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:49.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:49.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:49.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:49.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:49.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:49.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:49.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:49.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:49.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:49.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:49.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:49.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:49.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:49.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:49.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:49.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:49.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:49.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:49.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:49.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:49.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:49.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:49.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:49.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:49.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:49.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:49.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:49.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:49.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:49.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:49.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:49.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:49.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:49.00 | GetProperties.currentaudiostream.bitrate | 385557
HEX: 26.03.2018 22:14:49.00 | GetProperties.currentaudiostream.bitrate | 33 38 35 35 35 37
TXT: 26.03.2018 22:14:49.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:49.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:49.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:49.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:49.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:49.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:49.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:49.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:49.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:49.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:49.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:49.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:49.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:49.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:49.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:49.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:49.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:49.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:49.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:49.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:49.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:49.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:49.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:49.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:49.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:49.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:49.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:49.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:49.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:49.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:49.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:49.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:49.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:49.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:49.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:49.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:49.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:49.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:51.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":8649}
HEX: 26.03.2018 22:14:51.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 38 36 34 39 7D
TXT: 26.03.2018 22:14:51.00 | Receive Direct | {"id":8649,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":384459,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:51.00 | Receive Direct | 7B 22 69 64 22 3A 38 36 34 39 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 34 34 35 39 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:51.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:51.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:51.00 | Receive Direct Result.currentaudiostream.bitrate | 384459
HEX: 26.03.2018 22:14:51.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 34 34 35 39
TXT: 26.03.2018 22:14:51.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:51.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:51.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:51.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:51.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:51.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:51.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:51.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:51.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:51.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:51.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:51.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:51.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:51.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:51.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:51.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:51.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:51.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:51.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:51.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:51.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:51.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:51.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:51.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:51.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:51.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:51.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:51.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:51.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:51.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:51.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:51.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:51.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:51.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:51.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:51.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:51.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:51.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:51.00 | GetProperties.currentaudiostream.bitrate | 384459
HEX: 26.03.2018 22:14:51.00 | GetProperties.currentaudiostream.bitrate | 33 38 34 34 35 39
TXT: 26.03.2018 22:14:51.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:51.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:51.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:51.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:51.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:51.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:51.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:51.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:51.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:51.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:51.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:51.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:51.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:51.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:51.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:51.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:51.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:51.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:51.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:51.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:51.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:51.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:51.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:51.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:51.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:51.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:51.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:51.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:51.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:51.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:51.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:51.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:51.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:51.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:51.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:51.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:51.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:51.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:54.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":81}
HEX: 26.03.2018 22:14:54.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 38 31 7D
TXT: 26.03.2018 22:14:54.00 | Receive Direct | {"id":81,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":387932,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:54.00 | Receive Direct | 7B 22 69 64 22 3A 38 31 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 37 39 33 32 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:54.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:54.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:54.00 | Receive Direct Result.currentaudiostream.bitrate | 387932
HEX: 26.03.2018 22:14:54.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 37 39 33 32
TXT: 26.03.2018 22:14:54.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:54.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:54.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:54.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:54.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:54.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:54.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:54.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:54.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:54.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:54.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:54.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:54.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:54.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:54.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:54.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:54.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:54.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:54.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:54.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:54.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:54.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:54.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:54.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:54.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:54.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:54.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:54.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:54.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:54.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:54.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:54.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:54.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:54.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:54.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:54.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:54.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:54.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:54.00 | GetProperties.currentaudiostream.bitrate | 387932
HEX: 26.03.2018 22:14:54.00 | GetProperties.currentaudiostream.bitrate | 33 38 37 39 33 32
TXT: 26.03.2018 22:14:54.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:54.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:54.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:54.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:54.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:54.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:54.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:54.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:54.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:54.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:54.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:54.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:54.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:54.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:54.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:54.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:54.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:54.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:54.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:54.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:54.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:54.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:54.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:54.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:54.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:54.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:54.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:54.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:54.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:54.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:54.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:54.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:54.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:54.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:54.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:54.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:54.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:54.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:56.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":1844}
HEX: 26.03.2018 22:14:56.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 31 38 34 34 7D
TXT: 26.03.2018 22:14:56.00 | Receive Direct | {"id":1844,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":381649,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:56.00 | Receive Direct | 7B 22 69 64 22 3A 31 38 34 34 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 31 36 34 39 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:56.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:56.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:56.00 | Receive Direct Result.currentaudiostream.bitrate | 381649
HEX: 26.03.2018 22:14:56.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 31 36 34 39
TXT: 26.03.2018 22:14:56.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:56.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:56.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:56.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:56.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:56.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:56.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:56.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:56.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:56.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:56.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:56.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:56.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:56.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:56.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:56.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:56.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:56.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:56.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:56.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:56.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:56.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:56.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:56.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:56.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:56.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:56.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:56.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:56.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:56.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:56.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:56.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:56.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:56.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:56.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:56.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:56.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:56.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:56.00 | GetProperties.currentaudiostream.bitrate | 381649
HEX: 26.03.2018 22:14:56.00 | GetProperties.currentaudiostream.bitrate | 33 38 31 36 34 39
TXT: 26.03.2018 22:14:56.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:56.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:56.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:56.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:56.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:56.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:56.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:56.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:56.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:56.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:56.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:56.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:56.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:56.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:56.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:56.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:56.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:56.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:56.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:56.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:56.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:56.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:56.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:56.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:56.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:56.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:56.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:56.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:56.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:56.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:56.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:56.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:56.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:56.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:56.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:56.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:56.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:56.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:58.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":3287}
HEX: 26.03.2018 22:14:58.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 33 32 38 37 7D
TXT: 26.03.2018 22:14:58.00 | Receive Direct | {"id":3287,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":384769,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:14:58.00 | Receive Direct | 7B 22 69 64 22 3A 33 32 38 37 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 34 37 36 39 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:14:58.00 | Receive Direct Method | .
HEX: 26.03.2018 22:14:58.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:14:58.00 | Receive Direct Result.currentaudiostream.bitrate | 384769
HEX: 26.03.2018 22:14:58.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 34 37 36 39
TXT: 26.03.2018 22:14:58.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:58.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:58.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:58.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:58.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:58.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:58.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:58.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:58.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:58.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:58.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:58.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:58.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:58.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:58.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:14:58.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:14:58.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:14:58.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:58.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:14:58.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:14:58.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:14:58.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:14:58.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:14:58.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:58.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:14:58.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:14:58.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:58.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:58.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:14:58.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:14:58.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:14:58.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:14:58.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:14:58.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:14:58.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:14:58.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:14:58.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:14:58.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:14:58.00 | GetProperties.currentaudiostream.bitrate | 384769
HEX: 26.03.2018 22:14:58.00 | GetProperties.currentaudiostream.bitrate | 33 38 34 37 36 39
TXT: 26.03.2018 22:14:58.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:14:58.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:14:58.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:14:58.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:14:58.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:14:58.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:14:58.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:14:58.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:14:58.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:14:58.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:14:58.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:14:58.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:14:58.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:14:58.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:14:58.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:14:58.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:14:58.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:14:58.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:14:58.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:14:58.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:14:58.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:14:58.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:14:58.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:14:58.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:58.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:14:58.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:14:58.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:14:58.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:14:58.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:14:58.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:14:58.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:14:58.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:14:58.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:14:58.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:14:58.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:14:58.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:14:58.00 | GetProperties.type | video
HEX: 26.03.2018 22:14:58.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:15:00.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":5826}
HEX: 26.03.2018 22:15:00.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 35 38 32 36 7D
TXT: 26.03.2018 22:15:00.00 | Receive Direct | {"id":5826,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":387859,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:15:00.00 | Receive Direct | 7B 22 69 64 22 3A 35 38 32 36 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 37 38 35 39 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:15:00.00 | Receive Direct Method | .
HEX: 26.03.2018 22:15:00.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:15:00.00 | Receive Direct Result.currentaudiostream.bitrate | 387859
HEX: 26.03.2018 22:15:00.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 37 38 35 39
TXT: 26.03.2018 22:15:00.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:15:00.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:15:00.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:15:00.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:15:00.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:15:00.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:15:00.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:15:00.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:15:00.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:15:00.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:15:00.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:15:00.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:15:00.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:15:00.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:15:00.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:15:00.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:15:00.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:15:00.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:15:00.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:15:00.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:15:00.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:15:00.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:15:00.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:15:00.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:00.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:15:00.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:15:00.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:15:00.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:00.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:15:00.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:15:00.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:15:00.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:15:00.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:15:00.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:15:00.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:15:00.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:15:00.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:15:00.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:15:00.00 | GetProperties.currentaudiostream.bitrate | 387859
HEX: 26.03.2018 22:15:00.00 | GetProperties.currentaudiostream.bitrate | 33 38 37 38 35 39
TXT: 26.03.2018 22:15:00.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:15:00.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:15:00.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:15:00.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:15:00.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:15:00.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:15:00.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:15:00.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:15:00.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:15:00.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:15:00.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:15:00.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:15:00.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:15:00.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:15:00.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:15:00.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:15:00.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:15:00.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:15:00.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:15:00.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:15:00.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:15:00.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:15:00.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:15:00.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:00.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:15:00.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:15:00.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:15:00.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:00.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:15:00.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:15:00.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:15:00.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:15:00.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:15:00.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:15:00.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:15:00.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:15:00.00 | GetProperties.type | video
HEX: 26.03.2018 22:15:00.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:15:02.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":7987}
HEX: 26.03.2018 22:15:02.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 37 39 38 37 7D
TXT: 26.03.2018 22:15:02.00 | Receive Direct | {"id":7987,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":381808,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:15:02.00 | Receive Direct | 7B 22 69 64 22 3A 37 39 38 37 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 31 38 30 38 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:15:02.00 | Receive Direct Method | .
HEX: 26.03.2018 22:15:02.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:15:02.00 | Receive Direct Result.currentaudiostream.bitrate | 381808
HEX: 26.03.2018 22:15:02.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 31 38 30 38
TXT: 26.03.2018 22:15:02.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:15:02.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:15:02.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:15:02.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:15:02.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:15:02.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:15:02.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:15:02.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:15:02.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:15:02.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:15:02.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:15:02.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:15:02.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:15:02.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:15:02.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:15:02.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:15:02.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:15:02.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:15:02.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:15:02.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:15:02.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:15:02.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:15:02.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:15:02.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:02.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:15:02.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:15:02.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:15:02.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:02.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:15:02.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:15:02.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:15:02.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:15:02.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:15:02.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:15:02.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:15:02.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:15:02.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:15:02.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:15:02.00 | GetProperties.currentaudiostream.bitrate | 381808
HEX: 26.03.2018 22:15:02.00 | GetProperties.currentaudiostream.bitrate | 33 38 31 38 30 38
TXT: 26.03.2018 22:15:02.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:15:02.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:15:02.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:15:02.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:15:02.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:15:02.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:15:02.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:15:02.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:15:02.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:15:02.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:15:02.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:15:02.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:15:02.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:15:02.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:15:02.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:15:02.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:15:02.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:15:02.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:15:02.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:15:02.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:15:02.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:15:02.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:15:02.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:15:02.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:02.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:15:02.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:15:02.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:15:02.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:02.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:15:02.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:15:02.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:15:02.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:15:02.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:15:02.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:15:02.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:15:02.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:15:02.00 | GetProperties.type | video
HEX: 26.03.2018 22:15:02.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:15:05.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":1332}
HEX: 26.03.2018 22:15:05.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 31 33 33 32 7D
TXT: 26.03.2018 22:15:05.00 | Receive Direct | {"id":1332,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":387397,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:15:05.00 | Receive Direct | 7B 22 69 64 22 3A 31 33 33 32 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 37 33 39 37 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:15:05.00 | Receive Direct Method | .
HEX: 26.03.2018 22:15:05.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:15:05.00 | Receive Direct Result.currentaudiostream.bitrate | 387397
HEX: 26.03.2018 22:15:05.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 37 33 39 37
TXT: 26.03.2018 22:15:05.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:15:05.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:15:05.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:15:05.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:15:05.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:15:05.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:15:05.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:15:05.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:15:05.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:15:05.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:15:05.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:15:05.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:15:05.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:15:05.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:15:05.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:15:05.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:15:05.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:15:05.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:15:05.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:15:05.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:15:05.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:15:05.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:15:05.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:15:05.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:05.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:15:05.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:15:05.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:15:05.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:05.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:15:05.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:15:05.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:15:05.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:15:05.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:15:05.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:15:05.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:15:05.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:15:05.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:15:05.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:15:05.00 | GetProperties.currentaudiostream.bitrate | 387397
HEX: 26.03.2018 22:15:05.00 | GetProperties.currentaudiostream.bitrate | 33 38 37 33 39 37
TXT: 26.03.2018 22:15:05.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:15:05.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:15:05.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:15:05.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:15:05.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:15:05.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:15:05.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:15:05.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:15:05.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:15:05.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:15:05.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:15:05.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:15:05.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:15:05.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:15:05.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:15:05.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:15:05.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:15:05.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:15:05.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:15:05.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:15:05.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:15:05.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:15:05.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:15:05.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:05.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:15:05.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:15:05.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:15:05.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:05.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:15:05.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:15:05.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:15:05.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:15:05.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:15:05.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:15:05.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:15:05.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:15:05.00 | GetProperties.type | video
HEX: 26.03.2018 22:15:05.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:15:07.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":2637}
HEX: 26.03.2018 22:15:07.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 32 36 33 37 7D
TXT: 26.03.2018 22:15:07.00 | Receive Direct | {"id":2637,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":385203,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:15:07.00 | Receive Direct | 7B 22 69 64 22 3A 32 36 33 37 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 35 32 30 33 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:15:07.00 | Receive Direct Method | .
HEX: 26.03.2018 22:15:07.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:15:07.00 | Receive Direct Result.currentaudiostream.bitrate | 385203
HEX: 26.03.2018 22:15:07.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 35 32 30 33
TXT: 26.03.2018 22:15:07.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:15:07.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:15:07.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:15:07.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:15:07.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:15:07.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:15:07.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:15:07.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:15:07.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:15:07.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:15:07.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:15:07.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:15:07.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:15:07.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:15:07.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:15:07.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:15:07.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:15:07.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:15:07.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:15:07.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:15:07.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:15:07.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:15:07.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:15:07.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:07.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:15:07.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:15:07.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:15:07.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:07.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:15:07.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:15:07.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:15:07.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:15:07.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:15:07.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:15:07.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:15:07.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:15:07.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:15:07.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:15:07.00 | GetProperties.currentaudiostream.bitrate | 385203
HEX: 26.03.2018 22:15:07.00 | GetProperties.currentaudiostream.bitrate | 33 38 35 32 30 33
TXT: 26.03.2018 22:15:07.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:15:07.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:15:07.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:15:07.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:15:07.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:15:07.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:15:07.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:15:07.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:15:07.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:15:07.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:15:07.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:15:07.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:15:07.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:15:07.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:15:07.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:15:07.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:15:07.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:15:07.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:15:07.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:15:07.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:15:07.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:15:07.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:15:07.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:15:07.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:07.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:15:07.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:15:07.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:15:07.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:07.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:15:07.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:15:07.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:15:07.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:15:07.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:15:07.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:15:07.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:15:07.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:15:07.00 | GetProperties.type | video
HEX: 26.03.2018 22:15:07.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:15:09.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":4829}
HEX: 26.03.2018 22:15:09.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 34 38 32 39 7D
TXT: 26.03.2018 22:15:09.00 | Receive Direct | {"id":4829,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":381714,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:15:09.00 | Receive Direct | 7B 22 69 64 22 3A 34 38 32 39 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 31 37 31 34 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:15:09.00 | Receive Direct Method | .
HEX: 26.03.2018 22:15:09.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:15:09.00 | Receive Direct Result.currentaudiostream.bitrate | 381714
HEX: 26.03.2018 22:15:09.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 31 37 31 34
TXT: 26.03.2018 22:15:09.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:15:09.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:15:09.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:15:09.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:15:09.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:15:09.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:15:09.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:15:09.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:15:09.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:15:09.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:15:09.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:15:09.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:15:09.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:15:09.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:15:09.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:15:09.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:15:09.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:15:09.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:15:09.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:15:09.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:15:09.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:15:09.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:15:09.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:15:09.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:09.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:15:09.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:15:09.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:15:09.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:09.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:15:09.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:15:09.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:15:09.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:15:09.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:15:09.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:15:09.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:15:09.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:15:09.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:15:09.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:15:09.00 | GetProperties.currentaudiostream.bitrate | 381714
HEX: 26.03.2018 22:15:09.00 | GetProperties.currentaudiostream.bitrate | 33 38 31 37 31 34
TXT: 26.03.2018 22:15:09.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:15:09.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:15:09.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:15:09.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:15:09.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:15:09.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:15:09.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:15:09.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:15:09.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:15:09.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:15:09.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:15:09.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:15:09.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:15:09.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:15:09.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:15:09.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:15:09.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:15:09.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:15:09.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:15:09.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:15:09.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:15:09.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:15:09.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:15:09.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:09.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:15:09.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:15:09.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:15:09.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:09.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:15:09.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:15:09.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:15:09.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:15:09.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:15:09.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:15:09.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:15:09.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:15:09.00 | GetProperties.type | video
HEX: 26.03.2018 22:15:09.00 | GetProperties.type | 76 69 64 65 6F
TXT: 26.03.2018 22:15:11.00 | Send Direct | {"jsonrpc":"2.0","method":"Player.GetProperties","params":{"properties":["type","partymode","speed","time","percentage","repeat","shuffled","currentaudiostream","subtitleenabled","currentsubtitle"],"playerid":1},"id":6921}
HEX: 26.03.2018 22:15:11.00 | Send Direct | 7B 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 6D 65 74 68 6F 64 22 3A 22 50 6C 61 79 65 72 2E 47 65 74 50 72 6F 70 65 72 74 69 65 73 22 2C 22 70 61 72 61 6D 73 22 3A 7B 22 70 72 6F 70 65 72 74 69 65 73 22 3A 5B 22 74 79 70 65 22 2C 22 70 61 72 74 79 6D 6F 64 65 22 2C 22 73 70 65 65 64 22 2C 22 74 69 6D 65 22 2C 22 70 65 72 63 65 6E 74 61 67 65 22 2C 22 72 65 70 65 61 74 22 2C 22 73 68 75 66 66 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 5D 2C 22 70 6C 61 79 65 72 69 64 22 3A 31 7D 2C 22 69 64 22 3A 36 39 32 31 7D
TXT: 26.03.2018 22:15:11.00 | Receive Direct | {"id":6921,"jsonrpc":"2.0","result":{"currentaudiostream":{"bitrate":381709,"channels":2,"codec":"ac3","index":0,"language":"ger","name":"AC3 Stereo"},"currentsubtitle":{"index":0,"language":"ger","name":""},"partymode":false,"percentage":0,"repeat":"off","shuffled":false,"speed":1,"subtitleenabled":false,"time":{"hours":0,"milliseconds":0,"minutes":0,"seconds":0},"type":"video"}}
HEX: 26.03.2018 22:15:11.00 | Receive Direct | 7B 22 69 64 22 3A 36 39 32 31 2C 22 6A 73 6F 6E 72 70 63 22 3A 22 32 2E 30 22 2C 22 72 65 73 75 6C 74 22 3A 7B 22 63 75 72 72 65 6E 74 61 75 64 69 6F 73 74 72 65 61 6D 22 3A 7B 22 62 69 74 72 61 74 65 22 3A 33 38 31 37 30 39 2C 22 63 68 61 6E 6E 65 6C 73 22 3A 32 2C 22 63 6F 64 65 63 22 3A 22 61 63 33 22 2C 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 41 43 33 20 53 74 65 72 65 6F 22 7D 2C 22 63 75 72 72 65 6E 74 73 75 62 74 69 74 6C 65 22 3A 7B 22 69 6E 64 65 78 22 3A 30 2C 22 6C 61 6E 67 75 61 67 65 22 3A 22 67 65 72 22 2C 22 6E 61 6D 65 22 3A 22 22 7D 2C 22 70 61 72 74 79 6D 6F 64 65 22 3A 66 61 6C 73 65 2C 22 70 65 72 63 65 6E 74 61 67 65 22 3A 30 2C 22 72 65 70 65 61 74 22 3A 22 6F 66 66 22 2C 22 73 68 75 66 66 6C 65 64 22 3A 66 61 6C 73 65 2C 22 73 70 65 65 64 22 3A 31 2C 22 73 75 62 74 69 74 6C 65 65 6E 61 62 6C 65 64 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 22 3A 7B 22 68 6F 75 72 73 22 3A 30 2C 22 6D 69 6C 6C 69 73 65 63 6F 6E 64 73 22 3A 30 2C 22 6D 69 6E 75 74 65 73 22 3A 30 2C 22 73 65 63 6F 6E 64 73 22 3A 30 7D 2C 22 74 79 70 65 22 3A 22 76 69 64 65 6F 22 7D 7D
TXT: 26.03.2018 22:15:11.00 | Receive Direct Method | .
HEX: 26.03.2018 22:15:11.00 | Receive Direct Method | 2E
TXT: 26.03.2018 22:15:11.00 | Receive Direct Result.currentaudiostream.bitrate | 381709
HEX: 26.03.2018 22:15:11.00 | Receive Direct Result.currentaudiostream.bitrate | 33 38 31 37 30 39
TXT: 26.03.2018 22:15:11.00 | Receive Direct Result.currentaudiostream.channels | 2
HEX: 26.03.2018 22:15:11.00 | Receive Direct Result.currentaudiostream.channels | 32
TXT: 26.03.2018 22:15:11.00 | Receive Direct Result.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:15:11.00 | Receive Direct Result.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:15:11.00 | Receive Direct Result.currentaudiostream.index | 0
HEX: 26.03.2018 22:15:11.00 | Receive Direct Result.currentaudiostream.index | 30
TXT: 26.03.2018 22:15:11.00 | Receive Direct Result.currentaudiostream.language | ger
HEX: 26.03.2018 22:15:11.00 | Receive Direct Result.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:15:11.00 | Receive Direct Result.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:15:11.00 | Receive Direct Result.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:15:11.00 | Receive Direct Result.currentsubtitle.index | 0
HEX: 26.03.2018 22:15:11.00 | Receive Direct Result.currentsubtitle.index | 30
TXT: 26.03.2018 22:15:11.00 | Receive Direct Result.currentsubtitle.language | ger
HEX: 26.03.2018 22:15:11.00 | Receive Direct Result.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:15:11.00 | Receive Direct Result.currentsubtitle.name |
HEX: 26.03.2018 22:15:11.00 | Receive Direct Result.currentsubtitle.name |
TXT: 26.03.2018 22:15:11.00 | Receive Direct Result.partymode | FALSE
HEX: 26.03.2018 22:15:11.00 | Receive Direct Result.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:15:11.00 | Receive Direct Result.percentage | 0
HEX: 26.03.2018 22:15:11.00 | Receive Direct Result.percentage | 30
TXT: 26.03.2018 22:15:11.00 | Receive Direct Result.repeat | off
HEX: 26.03.2018 22:15:11.00 | Receive Direct Result.repeat | 6F 66 66
TXT: 26.03.2018 22:15:11.00 | Receive Direct Result.shuffled | FALSE
HEX: 26.03.2018 22:15:11.00 | Receive Direct Result.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:11.00 | Receive Direct Result.speed | 1
HEX: 26.03.2018 22:15:11.00 | Receive Direct Result.speed | 31
TXT: 26.03.2018 22:15:11.00 | Receive Direct Result.subtitleenabled | FALSE
HEX: 26.03.2018 22:15:11.00 | Receive Direct Result.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:11.00 | Receive Direct Result.time.hours | 0
HEX: 26.03.2018 22:15:11.00 | Receive Direct Result.time.hours | 30
TXT: 26.03.2018 22:15:11.00 | Receive Direct Result.time.milliseconds | 0
HEX: 26.03.2018 22:15:11.00 | Receive Direct Result.time.milliseconds | 30
TXT: 26.03.2018 22:15:11.00 | Receive Direct Result.time.minutes | 0
HEX: 26.03.2018 22:15:11.00 | Receive Direct Result.time.minutes | 30
TXT: 26.03.2018 22:15:11.00 | Receive Direct Result.time.seconds | 0
HEX: 26.03.2018 22:15:11.00 | Receive Direct Result.time.seconds | 30
TXT: 26.03.2018 22:15:11.00 | Receive Direct Result.type | video
HEX: 26.03.2018 22:15:11.00 | Receive Direct Result.type | 76 69 64 65 6F
TXT: 26.03.2018 22:15:11.00 | GetProperties.currentaudiostream.bitrate | 381709
HEX: 26.03.2018 22:15:11.00 | GetProperties.currentaudiostream.bitrate | 33 38 31 37 30 39
TXT: 26.03.2018 22:15:11.00 | GetProperties.currentaudiostream.channels | 2
HEX: 26.03.2018 22:15:11.00 | GetProperties.currentaudiostream.channels | 32
TXT: 26.03.2018 22:15:11.00 | GetProperties.currentaudiostream.codec | ac3
HEX: 26.03.2018 22:15:11.00 | GetProperties.currentaudiostream.codec | 61 63 33
TXT: 26.03.2018 22:15:11.00 | GetProperties.currentaudiostream.index | 0
HEX: 26.03.2018 22:15:11.00 | GetProperties.currentaudiostream.index | 30
TXT: 26.03.2018 22:15:11.00 | GetProperties.currentaudiostream.language | ger
HEX: 26.03.2018 22:15:11.00 | GetProperties.currentaudiostream.language | 67 65 72
TXT: 26.03.2018 22:15:11.00 | GetProperties.currentaudiostream.name | AC3 Stereo
HEX: 26.03.2018 22:15:11.00 | GetProperties.currentaudiostream.name | 41 43 33 20 53 74 65 72 65 6F
TXT: 26.03.2018 22:15:11.00 | GetProperties.currentsubtitle.index | 0
HEX: 26.03.2018 22:15:11.00 | GetProperties.currentsubtitle.index | 30
TXT: 26.03.2018 22:15:11.00 | GetProperties.currentsubtitle.language | ger
HEX: 26.03.2018 22:15:11.00 | GetProperties.currentsubtitle.language | 67 65 72
TXT: 26.03.2018 22:15:11.00 | GetProperties.currentsubtitle.name |
HEX: 26.03.2018 22:15:11.00 | GetProperties.currentsubtitle.name |
TXT: 26.03.2018 22:15:11.00 | GetProperties.partymode | FALSE
HEX: 26.03.2018 22:15:11.00 | GetProperties.partymode | 46 41 4C 53 45
TXT: 26.03.2018 22:15:11.00 | GetProperties.percentage | 0
HEX: 26.03.2018 22:15:11.00 | GetProperties.percentage | 30
TXT: 26.03.2018 22:15:11.00 | GetProperties.repeat | off
HEX: 26.03.2018 22:15:11.00 | GetProperties.repeat | 6F 66 66
TXT: 26.03.2018 22:15:11.00 | GetProperties.shuffled | FALSE
HEX: 26.03.2018 22:15:11.00 | GetProperties.shuffled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:11.00 | GetProperties.speed | 1
HEX: 26.03.2018 22:15:11.00 | GetProperties.speed | 31
TXT: 26.03.2018 22:15:11.00 | GetProperties.subtitleenabled | FALSE
HEX: 26.03.2018 22:15:11.00 | GetProperties.subtitleenabled | 46 41 4C 53 45
TXT: 26.03.2018 22:15:11.00 | GetProperties.time.hours | 0
HEX: 26.03.2018 22:15:11.00 | GetProperties.time.hours | 30
TXT: 26.03.2018 22:15:11.00 | GetProperties.time.milliseconds | 0
HEX: 26.03.2018 22:15:11.00 | GetProperties.time.milliseconds | 30
TXT: 26.03.2018 22:15:11.00 | GetProperties.time.minutes | 0
HEX: 26.03.2018 22:15:11.00 | GetProperties.time.minutes | 30
TXT: 26.03.2018 22:15:11.00 | GetProperties.time.seconds | 0
HEX: 26.03.2018 22:15:11.00 | GetProperties.time.seconds | 30
TXT: 26.03.2018 22:15:11.00 | GetProperties.type | video
HEX: 26.03.2018 22:15:11.00 | GetProperties.type | 76 69 64 65 6F
