hab gerade mal auf die Beta gewechselt. Dabei sind mir zwei dinge Aufgefallen:
- Wenn ich über Instanz hinzufügen nach Entkoppler suche werden mir zwei gleiche Geräte angezeigt.
- Nach dem erstellen der Instanz erhalte ich folgende Fehlermeldung:
/var/lib/symcon/modules/.store/de.blackorca.vafimap/Decoupler/module.php on line 237
{"elements":[{"type":"CheckBox","name":"IsSelectedTypeLocked","caption":"Protect from Type or Profile Changing."},{"type":"Label","caption":"At first configure must this checkbox to off.","italic":true},{"type":"SelectVariable","caption":"Source Variable","name":"Source","validVariableTypes":[0,1,2],"onChange":"DC_VariableSelected($id, $Source);"},{"type":"Label","caption":"Supported are Integer, Float and Boolean.","italic":true},{"type":"CheckBox","name":"IsLowFilterActive","caption":"Low Filter Active","visible":false},{"type":"NumberSpinner","name":"LowFilterValue","caption":"Filter all values lower then this value","moreDigits":true,"visible":false},{"type":"CheckBox","name":"IsHighFilterActive","caption":"High Filter Active","visible":false},{"type":"NumberSpinner","name":"HighFilterValue","caption":"Filter all values higher then this value","moreDigits":true,"visible":false},{"type":"CheckBox","name":"IsMaxValueChangeActive","caption":"Max Value Change Active","visible":false},{"type":"NumberSpinner","name":"MaxValueChange","caption":"Max Value Change","moreDigits":true,"visible":false},{"type":"List","name":"ListOfIgnoreValues","caption":"List of ignored values","visible":false,"rowCount":5,"add":true,"delete":true,"sort":{"column":"Value","direction":"ascending"},"columns":[{"caption":"Value","name":"Value","width":"75px","add":0,"edit":{"type":"NumberSpinner","moreDigits":true}}],"values":[]},{"type":"CheckBox","name":"UseValueInverting","caption":"Should the Value Inverted?"},{"type":"Label","caption":"IMPORTANT: A combination of all Filters can be confusing. In case of Inverting it can be more confusing.","italic":true,"bold":true}],"actions":[{"type":"RowLayout","items":[{"type":"Label","caption":"Support me!"},{"type":"Image","onClick":"echo 'https:\/\/www.amazon.de\/hz\/wishlist\/ls\/1G7JKGDS69030';","image":"data:image\/jpeg;base64,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"}]},{"type":"RowLayout","items":[{"type":"Label","caption":"This module is only for the not Commercial use!"},{"type":"Image","image":"data:image\/png;base64,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"}]}],"status":[{"code":200,"icon":"error","caption":"No Source Variable selected"}]} (Code: -32603)
ObjektIDs in Zwischenablage kopiert und Objekte für Kopieren ausgewählt
viele Grüße
Stephan
