Wie sieht das Ergebnis aus, wenn du die URL
http://192.168....
aufrufst? Als Ergebnis sollte ein JSON Ausdruck kommen. Der sieht etwa so aus:
"700": {
"messages": { "AdaptHeatCurve": {
"name": "AdaptHeatCurve",
"passive": false,
"write": false,
"lastup": 1689317222,
"zz": 21,
"id": [181, 36, 2, 0, 0, 0, 20, 0], "comment": "Adaptive Heizkurve",
"fields": {
"yesno": {"value": "nein", "comment": "automatic correction of configured heat curve"}
"fielddefs": [
{ "name": "", "slave": true, "type": "IGN", "isbits": false, "length": 4, "unit": "", "comment": ""},
{ "name": "yesno", "slave": true, "type": "UCH", "isbits": false, "length": 1, "values": { "0": "nein", "1": "ja" }, "unit": "", "comment": "automatic correction of configured heat curve"}
"AdaptHeatCurve-w": {
"passive": false,
"write": true,
"lastup": 0,
"zz": 21,
"id": [181, 36, 2, 1, 0, 0, 20, 0], "comment": "Adaptive Heizkurve",
"fielddefs": [
{ "name": "yesno", "slave": false, "type": "UCH", "isbits": false, "length": 1, "values": { "0": "nein", "1": "ja" }, "unit": "", "comment": "automatic correction of configured heat curve"}
"BankHolidayEndPeriod": {
"name": "BankHolidayEndPeriod",
"passive": false,
"write": false,
"lastup": 0,
"zz": 21,
"id": [181, 36, 2, 0, 0, 0, 132, 0], "comment": "BankHolidayEndPeriod",
"fielddefs": [
{ "name": "hto", "slave": true, "type": "HDA:3", "isbits": false, "length": 3, "unit": "", "comment": "end date of bank holidays"}
Die Antwort scheint bei dir nicht JSON konform zu sein.
