Does anyone know why my modbus variable do not have the trending icon in the WebFront. I am logging the variables and I can see them in the archive handler.
I now use the following script to write the values in Float’s to see them in the webfront.
Is that the original script without change?
That could never work with the quotes!
To display in WebFront is also necessary that the variables have a profile. Have you thought about?
Please copy the script, what you’re using right here.
