ich habe mittlerweile auf die 2.1 upgedatet und bekomme nun in einem alten Script eine Fehlermeldung:
Notice: A non well formed numeric value encountered in C:\Programme\IP-Symcon2\scripts\53219.ips.php on line 91
Notice: A non well formed numeric value encountered in C:\Programme\IP-Symcon2\scripts\53219.ips.php on line 93
Folgendes Script wird verwendet:
case "Absenk":
//Nur Absenkbetrieb
$Bad_Zeit = array("07:30", "22:30","" ,"");
$Schlafzimmer_Zeit = array("07:30", "22:30","" ,"");
$Kueche_Zeit = array("07:30", "22:30","" ,"");
$Katzen_Zeit = array("07:30", "22:30","" ,"");
$Ankleide_Zeit = array("07:30", "22:30","" ,"");
$Diele_Zeit = array("07:30", "22:30","" ,"");
$WC_Zeit = array("07:30", "22:30","" ,"");
$Wohnzimmer_Zeit = array("07:30", "22:30","" ,"");
break;
$liste = IPS_GetChildrenIDs(48294 /*[1Wire\Temperatursensoren\Regelbar]*/);
foreach($liste as $temp)
$name = IPS_GetName($temp);
$sollID = IPS_GetVariableIDByName("SOLL_".$name,$temp);
$AbsenkID = IPS_GetVariableIDByName("Absenk_".$name,$temp);
$ZeitenID = IPS_GetVariableIDByName("Zeiten_".$name,$temp);
SetValueFloat($sollID, ${$name."_max"});
SetValueFloat($AbsenkID, ${$name."_min"});
$Zeiten = ${$name."_Zeit"};
$Zeit1_a = explode(":",$Zeiten[0]);
$Zeit1_a = mktime($Zeit1_a[0],$Zeit1_a[1],0,$Zeitstempel);
$Zeit1_e = explode(":",$Zeiten[1]);
$Zeit1_e = mktime($Zeit1_e[0],$Zeit1_e[1],0,$Zeitstempel);
if($Zeiten[2] != "")
$Zeit2_a = explode(":",$Zeiten[2]);
$Zeit2_a = mktime($Zeit2_a[0],$Zeit2_a[1],0,$Zeitstempel);
$Zeit2_e = explode(":",$Zeiten[3]);
$Zeit2_e = mktime($Zeit2_e[0],$Zeit2_e[1],0,$Zeitstempel);
elseif($Zeiten[2] == "")
$Zeit2_a = 0;
$Zeit2_e = 0;
$ZeitenString = $Zeit1_a.",".$Zeit1_e.",".$Zeit2_a.",".$Zeit2_e;
SetValueString($ZeitenID, $ZeitenString);
Die Zeilen die den Fehler verursachen sind diese hier (die beiden mit dem mktime() ) :
Trotz Fehler läuft das Script, aber die Fehlerausgabe nervt mich nun mal … was muss ich also tun ??
Jens
