Moinsen,
wollte gerade ein Update durchführen und bekomme folgenden Fehler:
Was habe ich da falsch gemacht?
-Joe
Preparing to unpack .../symcon_4.4-2055_armhf.deb ...
IP-Symcon is running.
Stopping...
IP-Symcon stopped
/var/lib/dpkg/tmp.ci/preinst: line 49: awk: command not found
/var/lib/dpkg/tmp.ci/preinst: line 50: awk: command not found
/var/lib/dpkg/tmp.ci/preinst: line 51: awk: command not found
/var/lib/dpkg/tmp.ci/preinst: line 57: awk: command not found
/var/lib/dpkg/tmp.ci/preinst: line 58: awk: command not found
/var/lib/dpkg/tmp.ci/preinst: line 61: [: -eq: unary operator expected
IP-Symcon: "Missing AuthenticationToken"
403
Press any key to continue...
dpkg: error processing archive /var/cache/apt/archives/symcon_4.4-2055_armhf.deb (--unpack):
subprocess new pre-installation script returned error exit status 1
IP-Symcon is not running.
Starting...
IP-Symcon started with PID 21229
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
