habe heute folgende Meldung mit Logfile erhalten.
--------------------------------2006/1/28 12:35:56--------------------------------
This application has leaked memory. The small block leaks are (excluding expected leaks registered by pointer):
1 - 4 bytes: Unknown x 2237
5 - 12 bytes: Unknown x 14
13 - 20 bytes: TList x 2, Unknown x 34
21 - 28 bytes: Unknown x 24
29 - 36 bytes: Unknown x 2
149 - 164 bytes: Unknown x 1
Note: Memory leak detail is logged to a text file in the same folder as this application. To disable this memory leak check, undefine „EnableMemoryLeakReporting“.
Könnet Ihr damit etwas anfangen ?
