nach dem letzten Update (Version 5.5, 13.3.21 Revision wird als unbekannt gezeigt) kommen bei mir viele nie zuvor gezeigte Fehler (System ist ein Mac).
18.03.2021, 19:15:21 | TimerPool | COVID-19 Landkreis Statistik (COVID_DistrictUpdateStats):
Warning: no valid certs found cafile stream: `/Applications/Symcon.app/Contents/Service/cacert.pem’ in /Library/Application Support/Symcon/modules/.store/info.schnittcher.ips.covid19/libs/COVID19Helper.php on line 34
Warning: file_get_contents(): Failed to enable crypto in /Library/Application Support/Symcon/modules/.store/info.schnittcher.ips.covid19/libs/COVID19Helper.php on line 34
Warning: file_get_contents(Query: Landkreise (ID: 0) in /Library/Application Support/Symcon/modules/.store/info.schnittcher.ips.covid19/libs/COVID19Helper.php on line 34
Fatal error: Uncaught TypeError: json_decode() expects parameter 1 to be string, bool given in /Library/Application Support/Symcon/modules/.store/info.schnittcher.ips.covid19/libs/COVID19Helper.php:35
Stack trace:
#0 /Library/Application Support/Symcon/modules/.store/info.schnittcher.ips.covid19/libs/COVID19Helper.php(35): json_decode(false, true)
#1 /Library/Application Support/Symcon/modules/.store/info.schnittcher.ips.covid19/DistrictStats/module.php(97): DistrictStats->DistrictRequest(‚GEN+%3D+%27Rend…‘, ‚cases7_per_100k…‘)
#2 /Library/Application Support/Symcon/scripts/__generated.inc.php(199): DistrictStats->updateDistrictStats()
#3 /Applications/Symcon.app/Contents/Service/-(1): COVID_updateDistrictStats(29640)
#4 {main}
thrown in /Library/Application Support/Symcon/modules/.store/info.schnittcher.ips.covid19/libs/COVID19Helper.php on line 35
18.03.2021, 19:16:31 | AmazonEchoIO | Error: (77) error setting certificate verify locations:
CAfile: /Applications/Symcon.app/Contents/Service/cacert.pem
CApath: none
Ich hoffe ihr könnt helfen
Jan Peter
