Hello, how can I change the Date Time format of the logged messages within the logfile.log. IP-Symcon is running on Raspberry linux platform. Thank you.
You cannot change the date format. It is fixed and not adjustable unless you modify the log file manually.
Unless you mean the time zone. That one is chosen based on the one set in your operating system. Thus, you would need to change the time zone of your Raspberry and then restart IP-Symcon. But that would not only affect the log file but every time within IP-Symcon.
