Garten Aktent Beleuchtung günstig
Wie kann ich günstig eine Wlan Infrarot bridge bauen
Die aus China stammenden LED Leuchten (Günstig) haben meist nur Infrarot Steuerung
zb so eine Solar-RGB-LED-Leuchtkugel, 30 cm, IP67 | ELV-Elektronik
ESP8266 V3 ^// dieser kann mit der Arduino Software programmiert werden
IR Sendediode aus alter FB
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <IRremoteESP8266.h>
MDNSResponder mdns;
const char* host = "192.168.xxx.xxx"; //Web Server
// Replace with your network credentials
const char* ssid = "xxx";
const char* password = "xxxxxxxxxxxxxxxxxxx";
IRsend irsend(5); //an IR led is connected to GPIO pin 5
ESP8266WebServer server(80);
String webPage = "";
float TmpWert = 0.00;
int gpio0_pin = 0;
int gpio2_pin = 2;
int outputPin= 0;
void setup(void){
webPage += "<h1>IR Server Garten Web Server</h1><p>LED KUGEL GARTEN <a href=\"socket1On\"><button>ON</button></a> <a href=\"socket1Off\"><button>OFF</button></a></p>";
webPage += "<p>Socket #2 <a href=\"socket2On\"><button>ON</button></a> <a href=\"socket2Off\"><button>OFF</button></a></p>";
// preparing GPIOs
pinMode(gpio0_pin, OUTPUT);
digitalWrite(gpio0_pin, LOW);
pinMode(gpio2_pin, OUTPUT);
digitalWrite(gpio2_pin, LOW);
irsend.begin();
delay(1000);
Serial.begin(115200);
WiFi.begin(ssid, password);
Serial.println("");
// Wait for connection
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
Serial.println(WiFi.localIP());
if (mdns.begin("esp8266", WiFi.localIP())) {
Serial.println("MDNS responder started");
server.on("/", [](){
server.send(200, "text/html", webPage);
server.on("/socket1On", [](){
digitalWrite(gpio0_pin, HIGH);
irsend.sendNEC(0xFFE21D, 32); // IR Befehl senden für an
delay(500);
server.on("/socket1Off", [](){
irsend.sendNEC(0xFFA25D, 32); // IR Befehl senden für aus
delay(500);
server.on("/socket2On", [](){
digitalWrite(gpio2_pin, HIGH);
delay(500);
server.on("/socket2Off", [](){
delay(500);
server.begin();
Serial.println("HTTP server started");
void loop(void){
server.handleClient();
int rawvoltage= analogRead(outputPin);
float millivolts= (rawvoltage/1024.0) * 3300;
float kelvin= (millivolts/10);
Serial.print(kelvin);
Serial.println(" degrees Kelvin");
float celsius= kelvin - 273.15;
Serial.print(celsius);
Serial.println(" degrees Celsius");
TmpWert = (celsius);
WiFiClient client;
const int httpPort = 80;
if (!client.connect(host, httpPort)) {
Serial.println("connection failed");
return;
// We now create a URI for the request
String url = "/get_val.php?";
url += "&Wert=";
url += TmpWert;
Serial.print("Requesting URL: ");
Serial.println(url);
// This will send the request to the server
client.print(String("GET ") + url + " HTTP/1.1
"Host: " + host + "
"Connection: close
Serial.println("Werte an WebServer uebergeben");
delay(10);
// Read all the lines of the reply from server and print them to Serial
while(client.available()){
String line = client.readStringUntil('\r');
//Serial.print(line);
delay(100);
Auf IPS Seite
Ganz einfach den Http String aufrufen per WWW Reader für den ESP
und Skript Inhalt
$bw1 = getvalue(xxxxx /*[HM\Fensterkontakt Wohnzimmer 2 \STATE]*/ );
if ($bw1 == false)
$url = "http://192.168.xxx.xxx/socket1On";
$wwwReaderID = xxxxx /*[WWW Reader led http]*/;
WWWReader_SetPage($wwwReaderID, $url);
IPS_ApplyChanges($wwwReaderID);
WWWReader_UpdatePage($wwwReaderID);
else
$url = "http://192.168.xxx.xx/socket1Off";
Ich habe das Skript über mein Tür Kontakt getriggert bei Änderung
Farben sind der nächste Step lange Wintertage liegen vor uns
