Der Fehler kommt auch, wenn ich versuche die Lampe zB über das WebFront zu schalten. Im Debug des Gateway kommt dann folgendes:
TXT: 02/10/2025, 03:56:33 PM | WAITING | >M000058!A1DI100000<LF>
HEX: 02/10/2025, 03:56:33 PM | WAITING | 3E 4D 30 30 30 30 35 38 21 41 31 44 49 31 30 30 30 30 30 0A
TXT: 02/10/2025, 03:56:33 PM | TRANSMIT | >M000058!A1DI100000<LF>
HEX: 02/10/2025, 03:56:33 PM | TRANSMIT | 3E 4D 30 30 30 30 35 38 21 41 31 44 49 31 30 30 30 30 30 0A
TXT: 02/10/2025, 03:56:33 PM | RECEIVED | -M000058007
HEX: 02/10/2025, 03:56:33 PM | RECEIVED | 2D 4D 30 30 30 30 35 38 30 30 37
Das Debug der Output Instanz sowie das Debug des Splitter Instanz bleiben leer.
Schalte ich den Ausgang per script
LCN_SwitchMode(29077,0);
erhalte ich im Debug des Gateway folgendes:
TXT: 02/10/2025, 03:58:50 PM | WAITING | >M000058!A1TA000<LF>
HEX: 02/10/2025, 03:58:50 PM | WAITING | 3E 4D 30 30 30 30 35 38 21 41 31 54 41 30 30 30 0A
TXT: 02/10/2025, 03:58:50 PM | TRANSMIT | >M000058!A1TA000<LF>
HEX: 02/10/2025, 03:58:50 PM | TRANSMIT | 3E 4D 30 30 30 30 35 38 21 41 31 54 41 30 30 30 0A
TXT: 02/10/2025, 03:58:50 PM | RECEIVED | -M000058!
HEX: 02/10/2025, 03:58:50 PM | RECEIVED | 2D 4D 30 30 30 30 35 38 21
TXT: 02/10/2025, 03:58:51 PM | RECEIVED | :M000058A1025
HEX: 02/10/2025, 03:58:51 PM | RECEIVED | 3A 4D 30 30 30 30 35 38 41 31 30 32 35
TXT: 02/10/2025, 03:58:51 PM | WAITING | >M000052!LA009E<LF>
HEX: 02/10/2025, 03:58:51 PM | WAITING | 3E 4D 30 30 30 30 35 32 21 4C 41 30 30 39 45 0A
TXT: 02/10/2025, 03:58:51 PM | TRANSMIT | >M000052!LA009E<LF>
HEX: 02/10/2025, 03:58:51 PM | TRANSMIT | 3E 4D 30 30 30 30 35 32 21 4C 41 30 30 39 45 0A
TXT: 02/10/2025, 03:58:51 PM | RECEIVED | -M000052!
HEX: 02/10/2025, 03:58:51 PM | RECEIVED | 2D 4D 30 30 30 30 35 32 21
TXT: 02/10/2025, 03:58:51 PM | WAITING | >M000052!LA004A<LF>
HEX: 02/10/2025, 03:58:51 PM | WAITING | 3E 4D 30 30 30 30 35 32 21 4C 41 30 30 34 41 0A
TXT: 02/10/2025, 03:58:51 PM | TRANSMIT | >M000052!LA004A<LF>
HEX: 02/10/2025, 03:58:51 PM | TRANSMIT | 3E 4D 30 30 30 30 35 32 21 4C 41 30 30 34 41 0A
In der alten VM Version von IP Symcon - dort wo es klappt - gibt mir das Gateway folgenden Debug, wenn ich den Ausgang per Kontextmenu einschalte
TXT: 02/10/2025, 04:00:28 PM | WAITING | >M000058!A1DI100000<LF>
HEX: 02/10/2025, 04:00:28 PM | WAITING | 3E 4D 30 30 30 30 35 38 21 41 31 44 49 31 30 30 30 30 30 0A
TXT: 02/10/2025, 04:00:28 PM | TRANSMIT | >M000058!A1DI100000<LF>
HEX: 02/10/2025, 04:00:28 PM | TRANSMIT | 3E 4D 30 30 30 30 35 38 21 41 31 44 49 31 30 30 30 30 30 0A
TXT: 02/10/2025, 04:00:28 PM | RECEIVED | -M000058!
HEX: 02/10/2025, 04:00:28 PM | RECEIVED | 2D 4D 30 30 30 30 35 38 21
Für mich schauen beide Debugs via Kontext Menü identisch aus, nur die Rückmeldung ist unterschiedlich.
Beide IP Instanzen verwenden das selbe PCHK
