ich habe mir ein Modul gemacht um Nachrichten an verschiedene Instanzen zu leiten.
Dieses funktioniert auch alles.
Nun habe ich zum Testen einen neuen Zweig erstellt und im Formular in der Liste ein neuen Feld (Checkbox) hinzugefügt. Ebenso im „GetConfigurationForm()“ im Modul.
Wenn ich die Instanz vom Modul neu anlege, kommt kein Fehler. Wenn ich jedoch das Modul aus dem alten Zweig schon hinzugefügt habe, und dann auf den neuen wechsel, bekomme ich eine Fehlermeldung.
<br />
<b>Notice</b>: Undefined property: stdClass::$SendDefault in <b>/var/lib/symcon/modules/NotificationBoard/NotificationBoard/module.php</b> on line <b>169</b><br />
<br />
<br />
{"elements":[{"type":"List","name":"notificationWays","caption":"NotifyTypes","rowCount":10,"add":true,"delete":true,"sort":{"column":"NotificationWay","direction":"ascending"},"columns":[{"label":"InstanceID","name":"instanceID","width":"300px","add":0,"edit":{"type":"SelectInstance"}},{"label":"Notificationway","name":"NotificationWay","width":"300px","add":0,"edit":{"type":"ValidationTextBox"}},{"label":"Receiver","name":"Receiver","width":"auto","add":0,"edit":{"type":"ValidationTextBox"}},{"label":"Send default true","name":"SendDefault","width":"100px","add":1,"edit":{"type":"CheckBox"}}],"values":[{"NotificationWay":"E-Mail","Receiver":"deine@mail.de","SendDefault":null},{"NotificationWay":"WebFront SendNotification","Receiver":"","SendDefault":null},{"NotificationWay":"WebFront PopUp","Receiver":"","SendDefault":null}]},{"type":"ExpansionPanel","caption":"Create area for variables...","items":[{"type":"CheckBox","name":"CreateNotifyTypes","caption":"Create Variable for change Subjects (needed for HtmlBox or PopUp)"},{"type":"CheckBox","name":"CreateHtmlBox","caption":"Create Variable HtmlBox"},{"type":"CheckBox","name":"CreatePopUpModul","caption":"Create PopUp Module"}]},{"type":"ExpansionPanel","caption":"If checkbox active, then instances or variables become invisible","items":[{"type":"CheckBox","name":"NotifyTypesVisible","caption":"Variable NotifyTypes invisible (Attention! When using HtmlBox or PopUp this should be disabled)."},{"type":"CheckBox","name":"HtmlVisible","caption":"Variable Html Box invisible"},{"type":"CheckBox","name":"PopUpVisible","caption":"PopUp invisible"},{"type":"CheckBox","name":"InstanceVisible","caption":"Notification Instances invisible"}]},{"type":"ExpansionPanel","caption":"WebHook Control","items":[{"type":"ValidationTextBox","name":"Username","caption":"Username"},{"type":"PasswordTextBox","name":"Password","caption":"Password"}]}]} (Code: -32603)
Ich steh gerade auf dem Schlauch was ich falsch mache. Will die Instanz nach möglichkeit nicht neu anlegen und alles neu konfigurieren.
Hier die Form.json, es geht um die Spalte „SendDefault“.
"elements": [
"type": "List",
"name": "notificationWays",
"caption": "NotifyTypes",
"rowCount": 10,
"add": true,
"delete": true,
"sort": {
"column": "NotificationWay",
"direction": "ascending"
"columns": [
"label": "InstanceID",
"name": "instanceID",
"width": "300px",
"add": 0,
"edit": {
"type": "SelectInstance"
"label": "Notificationway",
"name": "NotificationWay",
"width": "300px",
"add": 0,
"edit": {
"type": "ValidationTextBox"
"label": "Receiver",
"name": "Receiver",
"width": "auto",
"add": 0,
"edit": {
"label": "Send default true",
"name": "SendDefault",
"width": "100px",
"add": 1,
"edit": {
"type": "CheckBox"
"values": [
"type": "ExpansionPanel",
"caption": "Create area for variables...",
"items": [
"type": "CheckBox",
"name": "CreateNotifyTypes",
"caption": "Create Variable for change Subjects (needed for HtmlBox or PopUp)"
"type": "CheckBox",
"name": "CreateHtmlBox",
"caption": "Create Variable HtmlBox"
"type": "CheckBox",
"name": "CreatePopUpModul",
"caption": "Create PopUp Module"
"caption": "If checkbox active, then instances or variables become invisible",
"items": [
"type": "CheckBox",
"name": "NotifyTypesVisible",
"caption": "Variable NotifyTypes invisible (Attention! When using HtmlBox or PopUp this should be disabled)."
"type": "CheckBox",
"name": "HtmlVisible",
"caption": "Variable Html Box invisible"
"type": "CheckBox",
"name": "PopUpVisible",
"caption": "PopUp invisible"
"type": "CheckBox",
"name": "InstanceVisible",
"caption": "Notification Instances invisible"
"caption": "WebHook Control",
"items": [
{ "type": "ValidationTextBox", "name": "Username", "caption": "Username" },
{ "type": "PasswordTextBox", "name": "Password", "caption": "Password" }
Hier der Teil vom GetConfigurationForm(). Die Zeile 169 ist " „SendDefault“ => $treeRow->SendDefault".
public function GetConfigurationForm()
$data = json_decode(file_get_contents(__DIR__ . "/form.json"));
//Only add default element if we do not have anything in persistence
if($this->ReadPropertyString("notificationWays") == "") {
$data->elements[0]->values[] = Array(
"instanceID" => @IPS_GetInstanceListByModuleID ("{375EAF21-35EF-4BC4-83B3-C780FD8BD88A}")[0],
"NotificationWay" => "E-Mail",
"Receiver" => "deine@mail.de",
"SendDefault" => false
"instanceID" => @IPS_GetInstanceListByModuleID ("{3565B1F2-8F7B-4311-A4B6-1BF1D868F39E}")[0],
"NotificationWay" => "WebFront SendNotification",
"Receiver" => "",
"NotificationWay" => "WebFront PopUp",
"Receiver" => "",
} else {
//Annotate existing elements
$notificationWays = json_decode($this->ReadPropertyString("notificationWays"));
foreach($notificationWays as $treeRow) {
"NotificationWay" => $treeRow->NotificationWay,
"Receiver" => $treeRow->Receiver,
"SendDefault" => $treeRow->SendDefault
return json_encode($data);
Auch ein MC_ReloadModule(35608,„NotificationBoard“) bringt nichts.
Vielleicht kann mich einer auf den richtigen Weg bringen.
Oli
