Edit: Das problem scheint die komplette Buskommunikation nach Symcon zu betreffen. Hier mal ein kurzer Ausschnitt der „Meldungen“
TXT: 15.10.2020, 17:45:25 | 0/4/0 | <NUL>€?›dZ
HEX: 15.10.2020, 17:45:25 | 0/4/0 | 00 80 3F 9B 64 5A
TXT: 15.10.2020, 17:45:25 | 0/4/1 | <NUL>€?,ÌÍ
HEX: 15.10.2020, 17:45:25 | 0/4/1 | 00 80 3F 2C CC CD
TXT: 15.10.2020, 17:45:25 | 0/4/2 | <NUL>€B<DLE>Ĝ
HEX: 15.10.2020, 17:45:25 | 0/4/2 | 00 80 42 10 011C
TXT: 15.10.2020, 17:45:26 | 0/4/5 | <NUL>€Cý€<NUL>
HEX: 15.10.2020, 17:45:26 | 0/4/5 | 00 80 43 FD 80 00
TXT: 15.10.2020, 17:45:26 | 1/3/8 | <NUL>€<BEL>
HEX: 15.10.2020, 17:45:26 | 1/3/8 | 00 80 07 9D
TXT: 15.10.2020, 17:45:28 | 0/4/0 | <NUL>€?zŸ¾
HEX: 15.10.2020, 17:45:28 | 0/4/0 | 00 80 3F 7A 9F BE
TXT: 15.10.2020, 17:45:28 | 0/4/1 | <NUL>€>Û"Ñ
HEX: 15.10.2020, 17:45:28 | 0/4/1 | 00 80 3E DB 22 D1
TXT: 15.10.2020, 17:45:28 | 0/4/2 | <NUL>€B<FF>‰7
HEX: 15.10.2020, 17:45:28 | 0/4/2 | 00 80 42 0C 89 37
TXT: 15.10.2020, 17:45:29 | 1/3/2 | <NUL>€<BEL>ˆ
HEX: 15.10.2020, 17:45:29 | 1/3/2 | 00 80 07 88
TXT: 15.10.2020, 17:45:31 | 0/4/0 | <NUL>€?ÒÐå
HEX: 15.10.2020, 17:45:31 | 0/4/0 | 00 80 3F D2 D0 E5
TXT: 15.10.2020, 17:45:31 | 0/4/1 | <NUL>€½ýó¶
HEX: 15.10.2020, 17:45:31 | 0/4/1 | 00 80 BD FD F3 B6
TXT: 15.10.2020, 17:45:31 | 0/4/2 | <NUL>€B<FF>cT
HEX: 15.10.2020, 17:45:31 | 0/4/2 | 00 80 42 0C 63 54
TXT: 15.10.2020, 17:45:32 | 0/4/5 | <NUL>€Cý<NUL><NUL>
HEX: 15.10.2020, 17:45:32 | 0/4/5 | 00 80 43 FD 00 00
TXT: 15.10.2020, 17:45:32 | 0/7/2 | <NUL>€
HEX: 15.10.2020, 17:45:32 | 0/7/2 | 00 80
TXT: 15.10.2020, 17:45:32 | Received: 1 | <NUL>€
HEX: 15.10.2020, 17:45:32 | Received: 1 | 00 80
TXT: 15.10.2020, 17:45:34 | 0/4/0 | <NUL>€?®Ù<ETB>
HEX: 15.10.2020, 17:45:34 | 0/4/0 | 00 80 3F AE D9 17
TXT: 15.10.2020, 17:45:34 | 0/4/1 | <NUL>€?<STX><FF>J
HEX: 15.10.2020, 17:45:34 | 0/4/1 | 00 80 3F 02 0C 4A
TXT: 15.10.2020, 17:45:34 | 0/4/2 | <NUL>€B<DC4>Ïß
HEX: 15.10.2020, 17:45:34 | 0/4/2 | 00 80 42 14 CF DF
TXT: 15.10.2020, 17:45:37 | 0/4/0 | <NUL>€?ÂÐå
HEX: 15.10.2020, 17:45:37 | 0/4/0 | 00 80 3F C2 D0 E5
TXT: 15.10.2020, 17:45:37 | 0/4/5 | <NUL>€Cü€<NUL>
HEX: 15.10.2020, 17:45:37 | 0/4/5 | 00 80 43 FC 80 00
TXT: 15.10.2020, 17:45:37 | 0/4/1 | <NUL>€½™™š
HEX: 15.10.2020, 17:45:37 | 0/4/1 | 00 80 BD 99 99 9A
TXT: 15.10.2020, 17:45:37 | 0/4/2 | <NUL>€B<CAN>¹X
HEX: 15.10.2020, 17:45:37 | 0/4/2 | 00 80 42 18 B9 58
TXT: 15.10.2020, 17:45:38 | 0/4/3 | <NUL>€<NUL><NUL>Na
HEX: 15.10.2020, 17:45:38 | 0/4/3 | 00 80 00 00 4E 61
TXT: 15.10.2020, 17:45:38 | 0/4/4 | <NUL>€<NUL><NUL>ÿü
HEX: 15.10.2020, 17:45:38 | 0/4/4 | 00 80 00 00 FF FC
ich möchte eine Shelly RGBW2 mit einem KNX-Tast/Dimmsensor Dimmen (nur einen Farbkanal).
Dazu habe ich den Taster zum Scahlt-/Dimmsensor gemacht. Dieser sendet bei langem Druck jede Sekunde ein Telegramm auf den Bus.
In Symcon habe ich mir eine Instanz DPT003.x angelegt (Einheit 3.007) und diese mit der Gruppenadresse verknüpft.
Auf "Bewegung Erhöhen/Ernidrigen habe ich mir ein Ereignis gelegt, welches bei Aktualisierung einen Logeintrag schreibt (IPS_LogMessage). Drücke ich nun den Taster für bsp. 5 Sekunden, wird der Logeintrag jedoch insgesamt 10 mal geschrieben. Die Variable wird also pro Bustelegramm zweimal aktualisiert.
Ich habe mit das auf dem Bus angesehen; so sieht es dort aus:
# Zeit Dienst Flags Prio Quell-Adresse Quell-Name Ziel-Adresse Ziel-Name Rout Typ DPT Info
29 15.10.2020 11:21:56,937 vom Bus Low 1.1.9 6119/20 2f-Universalschnittstelle, UP 1/0/20 OG - Schlafen - LED-Stripe Bett (Shelly RGBW2) 6 Schreiben 3.007 Dimmer Schritt $05 | Verringern, 6 %
32 15.10.2020 11:21:57,948 vom Bus Low 1.1.9 6119/20 2f-Universalschnittstelle, UP 1/0/20 OG - Schlafen - LED-Stripe Bett (Shelly RGBW2) 6 Schreiben 3.007 Dimmer Schritt $05 | Verringern, 6 %
36 15.10.2020 11:21:58,928 vom Bus Low 1.1.9 6119/20 2f-Universalschnittstelle, UP 1/0/20 OG - Schlafen - LED-Stripe Bett (Shelly RGBW2) 6 Schreiben 3.007 Dimmer Schritt $05 | Verringern, 6 %
38 15.10.2020 11:21:59,929 vom Bus Low 1.1.9 6119/20 2f-Universalschnittstelle, UP 1/0/20 OG - Schlafen - LED-Stripe Bett (Shelly RGBW2) 6 Schreiben 3.007 Dimmer Schritt $05 | Verringern, 6 %
40 15.10.2020 11:22:01,025 vom Bus Low 1.1.9 6119/20 2f-Universalschnittstelle, UP 1/0/20 OG - Schlafen - LED-Stripe Bett (Shelly RGBW2) 6 Schreiben 3.007 Dimmer Schritt $05 | Verringern, 6 %
Anschließend habe ich in das Debug der Instanz geschaut und dort sieht es so aus:
TXT: 15.10.2020, 11:21:50 | 1/0/20 | <NUL>…
HEX: 15.10.2020, 11:21:50 | 1/0/20 | 00 85
TXT: 15.10.2020, 11:21:50 | Received: 1 | <NUL>…
HEX: 15.10.2020, 11:21:50 | Received: 1 | 00 85
TXT: 15.10.2020, 11:21:51 | 1/0/20 | <NUL>…
HEX: 15.10.2020, 11:21:51 | 1/0/20 | 00 85
TXT: 15.10.2020, 11:21:51 | Received: 1 | <NUL>…
HEX: 15.10.2020, 11:21:51 | Received: 1 | 00 85
TXT: 15.10.2020, 11:21:52 | 1/0/20 | <NUL>…
HEX: 15.10.2020, 11:21:52 | 1/0/20 | 00 85
TXT: 15.10.2020, 11:21:52 | Received: 1 | <NUL>…
HEX: 15.10.2020, 11:21:52 | Received: 1 | 00 85
TXT: 15.10.2020, 11:21:53 | 1/0/20 | <NUL>…
HEX: 15.10.2020, 11:21:53 | 1/0/20 | 00 85
TXT: 15.10.2020, 11:21:53 | Received: 1 | <NUL>…
HEX: 15.10.2020, 11:21:53 | Received: 1 | 00 85
TXT: 15.10.2020, 11:21:54 | 1/0/20 | <NUL>…
HEX: 15.10.2020, 11:21:54 | 1/0/20 | 00 85
TXT: 15.10.2020, 11:21:54 | Received: 1 | <NUL>…
HEX: 15.10.2020, 11:21:54 | Received: 1 | 00 85
Ist das Verhalten so normal?
Wie kann ich es umgehen? Ziel wäre es, bei jeder Aktualisierung (analog jedes Telegramm) increase oder decrease auszuwerten und damit dann den LED-Stripe um einen bestimmten Wert zu erhellen bzw. zu verdunkeln. So wie es jedoch jetzt ist, würde für jede Sekunde Tastendruck der Strip um zwei Steps verändert werden.
Hat jemand eine Idee?
Vielen Dank.
PS: Bitte nicht genau auf die Timestamps achten; scheinbar ist die Zwit auf dem Bus und Symcon unterschiedlich. Ich habe jedoch nur einen ganz kurzen Zeitraum gemonitored - das sind die passenden Ausschnitte.
