KNX DPT 7 ( EIS 10 ) send a specific value through the bus
Hi everyone ,
I need some help how to configure Ip-Symcon to send a specific value through the bus to a specific knx address .
I have a KNX Arcus-Eds IMPZ1 interface ( 1 channel impulse counter ) , for the consumption reading data no problem , but I would like to create on the webfront a space how to insert a password and send it trought the bus to reset the consumtion .
I don’t know how to manage that … someone can help me please ?
Thank you
What have you tried already? At which point are you stuck?
Hi Paresy …
I am to a dead point … :banghead:
Try using an action script for the String variable. That should enable you to input a password. In the script you can react on the input und evaluate it. (see $_IPS[‚VALUE‘])
Hi everyone ,
after a couple of weeks I could finish writing the script to reset the KNX counter .
Reset works properly, but there is a strange error message on the popup … can someone explain me how I can fix that ?
