Muss ich dann diesen ganzen Quelltext nehmen und nur die event sources einfügen?
<!DOCTYPE html>
<html>
<head>
<meta charset='utf-8' />
<link href='https://use.fontawesome.com/releases/v5.0.6/css/all.css' rel='stylesheet'>
<link href='../fullcalendar.min.css' rel='stylesheet' />
<link href='../fullcalendar.print.min.css' rel='stylesheet' media='print' />
<script src='../lib/moment.min.js'></script>
<script src='../lib/jquery.min.js'></script>
<script src='../fullcalendar.min.js'></script>
<script src='js/theme-chooser.js'></script>
<script>
$(document).ready(function() {
initThemeChooser({
init: function(themeSystem) {
$('#calendar').fullCalendar({
themeSystem: themeSystem,
header: {
left: 'prev,next today',
center: 'title',
right: 'month,agendaWeek,agendaDay,listMonth'
defaultDate: '2018-03-12',
weekNumbers: true,
navLinks: true, // can click day/week names to navigate views
editable: true,
eventLimit: true, // allow "more" link when too many events
events: [
title: 'All Day Event',
start: '2018-03-01'
title: 'Long Event',
start: '2018-03-07',
end: '2018-03-10'
title: 'Repeating Event',
start: '2018-03-09T16:00:00'
start: '2018-03-16T16:00:00'
title: 'Conference',
start: '2018-03-11',
end: '2018-03-13'
title: 'Meeting',
start: '2018-03-12T10:30:00',
end: '2018-03-12T12:30:00'
title: 'Lunch',
start: '2018-03-12T12:00:00'
title: 'Meeting',
start: '2018-03-12T14:30:00'
title: 'Happy Hour',
start: '2018-03-12T17:30:00'
title: 'Dinner',
start: '2018-03-12T20:00:00'
title: 'Birthday Party',
start: '2018-03-13T07:00:00'
title: 'Click for Google',
url: 'http://google.com/',
start: '2018-03-28'
change: function(themeSystem) {
$('#calendar').fullCalendar('option', 'themeSystem', themeSystem);
</script>
<style>
body {
margin: 0;
padding: 0;
font-size: 14px;
#top,
#calendar.fc-unthemed {
font-family: "Lucida Grande",Helvetica,Arial,Verdana,sans-serif;
#top {
background: #eee;
border-bottom: 1px solid #ddd;
padding: 0 10px;
line-height: 40px;
font-size: 12px;
color: #000;
#top .selector {
display: inline-block;
margin-right: 10px;
#top select {
font: inherit; /* mock what Boostrap does, don't compete */
.left { float: left }
.right { float: right }
.clear { clear: both }
#calendar {
max-width: 900px;
margin: 40px auto;
padding: 0 10px;
</style>
</head>
<body>
<div id='top'>
<div class='left'>
<div id='theme-system-selector' class='selector'>
Theme System:
<select>
<option value='bootstrap4' selected>Bootstrap 4</option>
<option value='bootstrap3'>Bootstrap 3</option>
<option value='jquery-ui'>jQuery UI</option>
<option value='standard'>unthemed</option>
</select>
</div>
<div data-theme-system="bootstrap3" class='selector' style='display:none'>
Theme Name:
<select>
<option value='' selected>Default</option>
<option value='cosmo'>Cosmo</option>
<option value='cyborg'>Cyborg</option>
<option value='darkly'>Darkly</option>
<option value='flatly'>Flatly</option>
<option value='journal'>Journal</option>
<option value='lumen'>Lumen</option>
<option value='paper'>Paper</option>
<option value='readable'>Readable</option>
<option value='sandstone'>Sandstone</option>
<option value='simplex'>Simplex</option>
<option value='slate'>Slate</option>
<option value='solar'>Solar</option>
<option value='spacelab'>Spacelab</option>
<option value='superhero'>Superhero</option>
<option value='united'>United</option>
<option value='yeti'>Yeti</option>
</select>
</div>
<div data-theme-system="bootstrap4" class='selector' style='display:none'>
Theme Name:
<select>
<option value='cerulean'>Cerulean</option>
<option value='litera'>Litera</option>
<option value='lux'>Lux</option>
<option value='materia'>Materia</option>
<option value='minty'>Minty</option>
<option value='pulse'>Pulse</option>
<option value='sketchy'>Sketchy</option>
</select>
</div>
<div data-theme-system="jquery-ui" class='selector' style='display:none'>
Theme Name:
<select>
<option value='black-tie'>Black Tie</option>
<option value='blitzer'>Blitzer</option>
<option value='cupertino' selected>Cupertino</option>
<option value='dark-hive'>Dark Hive</option>
<option value='dot-luv'>Dot Luv</option>
<option value='eggplant'>Eggplant</option>
<option value='excite-bike'>Excite Bike</option>
<option value='flick'>Flick</option>
<option value='hot-sneaks'>Hot Sneaks</option>
<option value='humanity'>Humanity</option>
<option value='le-frog'>Le Frog</option>
<option value='mint-choc'>Mint Choc</option>
<option value='overcast'>Overcast</option>
<option value='pepper-grinder'>Pepper Grinder</option>
<option value='redmond'>Redmond</option>
<option value='smoothness'>Smoothness</option>
<option value='south-street'>South Street</option>
<option value='start'>Start</option>
<option value='sunny'>Sunny</option>
<option value='swanky-purse'>Swanky Purse</option>
<option value='trontastic'>Trontastic</option>
<option value='ui-darkness'>UI Darkness</option>
<option value='ui-lightness'>UI Lightness</option>
<option value='vader'>Vader</option>
</select>
</div>
<span id='loading' style='display:none'>loading theme...</span>
</div>
<div class='right'>
<span class='credits' data-credit-id='bootstrap-standard' style='display:none'>
<a href='https://getbootstrap.com/docs/3.3/' target='_blank'>Theme by Bootstrap</a>
</span>
<span class='credits' data-credit-id='bootstrap-custom' style='display:none'>
<a href='https://bootswatch.com/' target='_blank'>Theme by Bootswatch</a>
</span>
<span class='credits' data-credit-id='jquery-ui' style='display:none'>
<a href='http://jqueryui.com/themeroller/' target='_blank'>Theme by jQuery UI</a>
</span>
</div>
<div class='clear'></div>
</div>
<div id='calendar'></div>
</body>
</html>
Edit: In deinem Skript geht das Theme ändern auch nicht in Zeile 6. Ist das bei dir auch so wenn du mit dem Mauszeiger über einen Termin fährst das das Feld weiß wird?
Edit: Habe jetzt den passenden Pfad gefunden wie er angegeben werden muss, um das Theme zu ändern.
