nun kommt der JSON-Fehler wieder häufiger, obwohl lange Zeit Ruhe war.
Anbei ein Auszug aus der 15 MB großen Logfile.
"22.11.2011 18:28:03.109 | 0 | WARNING | ExecuteThreadID #1 | Fehler beim Ausführen des Skripts (ios.php): date/time : 2011-11-22, 18:28:02, 937ms
computer name : HOMESERVER
user name : SYSTEM <admin>
registered owner : Acer Aspire easyStore Home Server / Acer Incorporated
operating system : Windows 2003 Service Pack 2 build 3790
system language : German
system up time : 23 hours 2 minutes
program up time : 23 hours 1 minute
processors : 2x Intel(R) Atom™ CPU D410 @ 1.66GHz
physical memory : 851/2038 MB (free/total)
free disk space : (C:) 4,79 GB
display mode : 1280x720, 32 bit
process id : $708
allocated memory : 173,33 MB
executable : ips.exe
exec. date/time : 2011-07-15 17:39
version : 2.4.0.0
compiled with : Delphi 2006/07
madExcept version : 3.0l
callstack crc : $02aeba23, $0ddd0e68, $0ddd0e68
exception number : 1207
exception class : EAccessViolation
exception message : Access violation at address 02AEBA23 in module ‚php5ts.dll‘. Read of address 70747468.
thread $7f0:
02aeba23 +023 php5ts.dll
02aed321 +031 php5ts.dll _emalloc
02b8a450 +010 php5ts.dll zend_stack_init
02b92470 +0d0 php5ts.dll php_request_startup
0076d667 +03f ips.exe PHPClass 135 +3 TPHPVariables.GetVariables
007700cf +00b ips.exe PHPSapi 835 +0 TPHPClient.StartupRequest
0076feca +0f6 ips.exe PHPSapi 771 +35 TPHPClient.RunScript
0077def6 +8e6 ips.exe UIPSScriptEngine 2360 +111 TExecuteThread.Execute
0044d87b +02b ips.exe madExcept HookedTThreadExecute
004751c4 +034 ips.exe Classes ThreadProc
00405a48 +028 ips.exe System 1948 +0 ThreadWrapper
0044d75d +00d ips.exe madExcept CallThreadProcSafe
0044d7c7 +037 ips.exe madExcept ThreadExceptFrame
thread $714:
00000000 +ffbdad04 ips.exe madStackTrace +0 StackAddrToStr
>> stack will be calculated soon
cpu registers:
eax = 0626adb0
ebx = 0626ad60
ecx = 00000000
edx = 08040000
esi = 70747468
edi = 00000000
eip = 02aeba23
esp = 0330fbb8
ebp = 0330fbd8
stack dump:
0330fbb8 00 00 00 00 08 01 00 00 - 60 ad 26 06 60 ad 26 06 ….&..&.
0330fbc8 00 00 15 00 20 00 00 00 - b0 ad 26 06 f8 fb 30 03 …&…0.
0330fbd8 f8 fb 30 03 ba b6 ae 02 - 60 ad 26 06 58 fc 30 03 ..0…`.&.X.0.
0330fbe8 28 4c 24 06 00 00 00 00 - 00 00 00 00 08 01 00 00 (L$…
0330fbf8 a0 fc 30 03 26 d3 ae 02 - 00 00 04 00 00 01 00 00 ..0.&…
0330fc08 55 a4 b8 02 00 01 00 00 - 38 b4 24 06 28 21 af 02 U…8.$.(!..
0330fc18 28 4c 24 06 38 b4 24 06 - 00 00 00 00 21 23 af 02 (L$.8.$…!#..
0330fc28 38 b4 24 06 38 b4 24 06 - 91 26 ae 02 38 b4 24 06 8.$.8.$..&..8.$.
0330fc38 38 b4 24 06 38 b4 24 06 - 75 24 b9 02 38 b4 24 06 8.$.8.$.u$..8.$.
0330fc48 38 b4 24 06 30 fd 30 03 - 08 b1 24 06 00 00 00 00 8.$.0.0…$…
0330fc58 a0 fc 30 03 00 00 00 00 - 30 fd 30 03 08 b1 24 06 ..0…0.0…$.
0330fc68 40 fc 30 03 ea 23 b9 02 - b0 fc 30 03 30 fd 30 03 @.0..#…0.0.0.
0330fc78 30 32 43 56 00 00 00 00 - f0 3d 8e 02 1f 00 00 00 02CV…=…
0330fc88 6c d6 76 00 a8 6e 93 02 - 98 d6 76 00 18 dd 90 02 l.v..n…v…
0330fc98 00 00 00 00 58 fc 30 03 - 28 fd 30 03 d1 00 77 00 …X.0.(.0…w.
0330fca8 38 b4 24 06 cf fe 76 00 - bc fc 30 03 08 53 40 00 8.$…v…0..S@.
0330fcb8 28 fd 30 03 30 fd 30 03 - 08 53 40 00 28 fd 30 03 (.0.0.0..S@.(.0.
0330fcc8 30 fd 30 03 00 f0 52 05 - b0 fe 08 01 00 00 00 00 0.0…R…
0330fcd8 0a 00 00 00 01 00 00 00 - ec 5b 40 00 01 00 00 00 …[@…
0330fce8 03 fd 30 03 2c 00 00 00 - 74 20 45 00 70 93 53 05 ..0.,…t.E.p.S.
22.11.2011 18:28:03.109 | 0 | DEBUG | ExecuteThreadID #1 | Ausgeführt, Resultat: -1, Erfolgreich: False, Zeit: 168 ms
22.11.2011 18:28:03.546 | 0 | DEBUG | ExecuteThreadID #7 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:03.593 | 0 | DEBUG | ExecuteThreadID #7 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 47 ms
22.11.2011 18:28:05.000 | 38825 | DEBUG | ExecuteThreadID #8 | Skriptausführung: 38825.ips.php ~ Absender: Ereignis #30052, Zeit Ereignis
22.11.2011 18:28:05.140 | 0 | DEBUG | ExecuteThreadID #3 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:05.296 | 0 | DEBUG | ExecuteThreadID #3 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 153 ms
22.11.2011 18:28:05.343 | 18666 | DEBUG | VariableManager | [Zuletzt geklingelt] = Mon 21.11.2011 19:46.40
22.11.2011 18:28:05.343 | 38825 | DEBUG | ExecuteThreadID #8 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 346 ms
22.11.2011 18:28:06.718 | 0 | DEBUG | ExecuteThreadID #6 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:06.843 | 0 | DEBUG | ExecuteThreadID #6 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 117 ms
22.11.2011 18:28:07.515 | 0 | DEBUG | ExecuteThreadID #8 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:07.593 | 0 | DEBUG | ExecuteThreadID #8 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 79 ms
22.11.2011 18:28:08.515 | 0 | DEBUG | ExecuteThreadID #3 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:08.593 | 0 | DEBUG | ExecuteThreadID #3 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 72 ms
22.11.2011 18:28:09.515 | 0 | DEBUG | ExecuteThreadID #6 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:09.609 | 0 | DEBUG | ExecuteThreadID #6 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 84 ms
22.11.2011 18:28:10.000 | 38825 | DEBUG | ExecuteThreadID #7 | Skriptausführung: 38825.ips.php ~ Absender: Ereignis #30052, Zeit Ereignis
22.11.2011 18:28:10.171 | 18666 | DEBUG | VariableManager | [Zuletzt geklingelt] = Mon 21.11.2011 19:46.40
22.11.2011 18:28:10.171 | 38825 | DEBUG | ExecuteThreadID #7 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 176 ms
22.11.2011 18:28:10.546 | 0 | DEBUG | ExecuteThreadID #4 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:10.625 | 0 | DEBUG | ExecuteThreadID #4 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 86 ms
22.11.2011 18:28:11.531 | 0 | DEBUG | ExecuteThreadID #7 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:11.593 | 0 | DEBUG | ExecuteThreadID #7 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 72 ms
22.11.2011 18:28:12.515 | 0 | DEBUG | ExecuteThreadID #10 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:12.578 | 0 | DEBUG | ExecuteThreadID #10 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 59 ms
22.11.2011 18:28:13.531 | 0 | DEBUG | ExecuteThreadID #10 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:13.578 | 0 | DEBUG | ExecuteThreadID #10 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 46 ms
22.11.2011 18:28:14.515 | 0 | DEBUG | ExecuteThreadID #7 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:14.593 | 0 | DEBUG | ExecuteThreadID #7 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 71 ms
22.11.2011 18:28:15.000 | 54094 | DEBUG | ExecuteThreadID #4 | Skriptausführung: 54094.ips.php ~ Absender: Ereignis #28700, Zeit Ereignis
22.11.2011 18:28:15.015 | 20007 | DEBUG | VariableManager | [Dummy\Wartung\Druckerstatus\Cyan] = 3
22.11.2011 18:28:15.015 | 0 | DEBUG | ExecuteThreadID #10 | Skriptausführung (Text) - Länge: 31 ~ Absender: Ereignis #47887, Variable #20007, Auslöser: OnLimitDrop
22.11.2011 18:28:15.015 | 46201 | DEBUG | VariableManager | [Dummy\Wartung\Druckerstatus\Magenta] = 3
22.11.2011 18:28:15.015 | 24244 | DEBUG | VariableManager | [Dummy\Status\Drucker] = True
22.11.2011 18:28:15.015 | 52713 | DEBUG | VariableManager | [Dummy\Wartung\Druckerstatus\Gelb] = 90
22.11.2011 18:28:15.015 | 0 | DEBUG | ExecuteThreadID #10 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 6 ms
22.11.2011 18:28:15.015 | 58730 | DEBUG | VariableManager | [Dummy\Wartung\Druckerstatus\Schwarz] = 68
22.11.2011 18:28:15.015 | 39638 | DEBUG | VariableManager | [Dummy\Wartung\Druckerstatus\Seitenanzahl] = 95779
22.11.2011 18:28:15.031 | 54094 | DEBUG | ExecuteThreadID #4 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 23 ms
22.11.2011 18:28:15.031 | 0 | DEBUG | ExecuteThreadID #4 | Skriptausführung (Text) - Länge: 31 ~ Absender: Ereignis #27445, Variable #46201, Auslöser: OnLimitDrop
22.11.2011 18:28:15.031 | 24244 | DEBUG | VariableManager | [Dummy\Status\Drucker] = True
22.11.2011 18:28:15.031 | 0 | DEBUG | ExecuteThreadID #4 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 2 ms
22.11.2011 18:28:15.500 | 38825 | DEBUG | ExecuteThreadID #4 | Skriptausführung: 38825.ips.php ~ Absender: Ereignis #30052, Zeit Ereignis
22.11.2011 18:28:15.531 | 0 | DEBUG | ExecuteThreadID #3 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:15.578 | 0 | DEBUG | ExecuteThreadID #3 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 50 ms
22.11.2011 18:28:15.671 | 18666 | DEBUG | VariableManager | [Zuletzt geklingelt] = Mon 21.11.2011 19:46.40
22.11.2011 18:28:15.718 | 38825 | DEBUG | ExecuteThreadID #4 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 224 ms
22.11.2011 18:28:16.515 | 0 | DEBUG | ExecuteThreadID #4 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:16.578 | 0 | DEBUG | ExecuteThreadID #4 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 56 ms
22.11.2011 18:28:17.515 | 0 | DEBUG | ExecuteThreadID #4 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:17.593 | 0 | DEBUG | ExecuteThreadID #4 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 74 ms
22.11.2011 18:28:18.515 | 0 | DEBUG | ExecuteThreadID #3 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:18.593 | 0 | DEBUG | ExecuteThreadID #3 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 71 ms
22.11.2011 18:28:19.515 | 0 | DEBUG | ExecuteThreadID #6 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:19.609 | 0 | DEBUG | ExecuteThreadID #6 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 81 ms
22.11.2011 18:28:20.000 | 38825 | DEBUG | ExecuteThreadID #6 | Skriptausführung: 38825.ips.php ~ Absender: Ereignis #30052, Zeit Ereignis
22.11.2011 18:28:20.171 | 18666 | DEBUG | VariableManager | [Zuletzt geklingelt] = Mon 21.11.2011 19:46.40
22.11.2011 18:28:20.171 | 38825 | DEBUG | ExecuteThreadID #6 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 170 ms
22.11.2011 18:28:20.515 | 0 | DEBUG | ExecuteThreadID #6 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:20.609 | 0 | DEBUG | ExecuteThreadID #6 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 84 ms
22.11.2011 18:28:21.671 | 0 | DEBUG | ExecuteThreadID #6 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:21.812 | 0 | DEBUG | ExecuteThreadID #6 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 138 ms
22.11.2011 18:28:22.593 | 0 | DEBUG | ExecuteThreadID #3 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:22.640 | 0 | DEBUG | ExecuteThreadID #3 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 37 ms
22.11.2011 18:28:23.718 | 0 | DEBUG | ExecuteThreadID #3 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:23.765 | 0 | DEBUG | ExecuteThreadID #3 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 44 ms
22.11.2011 18:28:24.546 | 0 | DEBUG | ExecuteThreadID #3 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:24.578 | 0 | DEBUG | ExecuteThreadID #3 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 40 ms
22.11.2011 18:28:25.000 | 38825 | DEBUG | ExecuteThreadID #3 | Skriptausführung: 38825.ips.php ~ Absender: Ereignis #30052, Zeit Ereignis
22.11.2011 18:28:25.187 | 18666 | DEBUG | VariableManager | [Zuletzt geklingelt] = Mon 21.11.2011 19:46.40
22.11.2011 18:28:25.187 | 38825 | DEBUG | ExecuteThreadID #3 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 176 ms
22.11.2011 18:28:25.515 | 0 | DEBUG | ExecuteThreadID #3 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:25.593 | 0 | DEBUG | ExecuteThreadID #3 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 67 ms
22.11.2011 18:28:26.562 | 0 | DEBUG | ExecuteThreadID #4 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:26.703 | 0 | DEBUG | ExecuteThreadID #4 | Ausgeführt, Resultat: 1, Erfolgreich: True, Zeit: 140 ms
22.11.2011 18:28:27.718 | 0 | DEBUG | ExecuteThreadID #1 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:27.796 | 0 | WARNING | ExecuteThreadID #1 | Fehler beim Ausführen des Skripts (ios.php): date/time : 2011-11-22, 18:28:27, 718ms
user name : SYSTEM
program up time : 23 hours 2 minutes
physical memory : 838/2038 MB (free/total)
process id : $708
allocated memory : 173,52 MB
version : 2.4.0.0
callstack crc : $02aeba23, $c6547b5d, $c6547b5d
exception number : 1208
thread $7f0 (TExecuteThread):
created by thread $794 (TServiceThread) at:
0077cd9b +083 ips.exe UIPSScriptEngine 2111 +12 TExecuteThread.Create
main thread ($714):
cpu registers:
eax = 0626adb0
ebx = 0626ad60
ecx = 00000000
edx = 08040000
esi = 70747468
edi = 00000000
eip = 02aeba23
esp = 0330fbb8
ebp = 0330fbd8
stack dump:
0330fcc8 30 fd 30 03 90 ea 52 05 - b0 fe 08 01 00 00 00 00 0.0…R…
0330fce8 03 fd 30 03 2c 00 00 00 - 74 20 45 00 30 9d 53 05 ..0.,…t.E.0.S.
22.11.2011 18:28:27.796 | 0 | DEBUG | ExecuteThreadID #1 | Ausgeführt, Resultat: -1, Erfolgreich: False, Zeit: 75 ms
22.11.2011 18:28:28.437 | 0 | DEBUG | ExecuteThreadID #1 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:28.531 | 0 | WARNING | ExecuteThreadID #1 | Fehler beim Ausführen des Skripts (ios.php): date/time : 2011-11-22, 18:28:28, 437ms
system up time : 23 hours 3 minutes
physical memory : 836/2038 MB (free/total)
process id : $708
allocated memory : 173,45 MB
version : 2.4.0.0
exception number : 1209
main thread ($714):
cpu registers:
eax = 0626adb0
ebx = 0626ad60
ecx = 00000000
edx = 08040000
esi = 70747468
edi = 00000000
eip = 02aeba23
esp = 0330fbb8
ebp = 0330fbd8
stack dump:
0330fc88 6c d6 76 00 a8 6e 93 02 - 98 d6 76 00 d0 64 97 02 l.v..n…v..d..
0330fce8 03 fd 30 03 2c 00 00 00 - 74 20 45 00 50 92 53 05 ..0.,…t.E.P.S.
22.11.2011 18:28:28.531 | 0 | DEBUG | ExecuteThreadID #1 | Ausgeführt, Resultat: -1, Erfolgreich: False, Zeit: 92 ms
22.11.2011 18:28:29.437 | 0 | DEBUG | ExecuteThreadID #1 | Skriptausführung: ios.php ~ Absender: WebInterface
22.11.2011 18:28:29.515 | 0 | WARNING | ExecuteThreadID #1 | Fehler beim Ausführen des Skripts (ios.php): date/time : 2011-11-22, 18:28:29, 437ms
user name : SYSTEM
physical memory : 837/2038 MB (free/total)
process id : $708
allocated memory : 173,46 MB
version : 2.4.0.0
exception number : 1210
main thread ($714):
cpu registers:
eax = 0626adb0
ebx = 0626ad60
ecx = 00000000
edx = 08040000
esi = 70747468
edi = 00000000
eip = 02aeba23
esp = 0330fbb8
ebp = 0330fbd8
stack dump:
0330fc88 6c d6 76 00 a8 6e 93 02 - 98 d6 76 00 58 a0 97 02 l.v..n…v.X…
0330fcc8 30 fd 30 03 a0 e6 52 05 - b0 fe 08 01 00 00 00 00 0.0…R…
0330fce8 03 fd 30 03 2c 00 00 00 - 74 20 45 00 f0 93 53 05 ..0.,…t.E…S."
Felix
