hab heute die neue Version 4 installiert. Wenn ich nun versuche via JSON eine Abfrage zu machen erhalte ich folgende Antwort:
{"jsonrpc":"2.0","error":{"code":-32700,"message":"Parse error"},"id":null}
Die Abfrage mache ich via VB.NET:
Net.ServicePointManager.ServerCertificateValidationCallback = New System.Net.Security.RemoteCertificateValidationCallback(AddressOf AcceptCert)
' Create a request using a URL that can receive a post.
Dim request As Net.WebRequest = Net.WebRequest.Create(IP_Symcon_Server)
' Set the Method property of the request to POST.
request.Method = "POST"
'request.Credentials = New System.Net.NetworkCredential("xxxx@web.de", "123")
' Create POST data and convert it to a byte array.
request.Headers.Add("Authorization", "Basic " + Convert.ToBase64String(System.Text.Encoding.ASCII.GetBytes("Beispiel@web.de" + ":" + "123456")))
Dim postData As String = "{'jsonrpc': '2.0', 'method': 'IPS_GetSnapshotChanges', 'params': [0], 'id': 1}"
Dim byteArray As Byte() = System.Text.Encoding.UTF8.GetBytes(postData)
' Set the ContentType property of the WebRequest.
request.ContentType = "application/json"
' Set the ContentLength property of the WebRequest.
request.ContentLength = byteArray.Length
' Get the request stream.
Dim dataStream As IO.Stream = request.GetRequestStream()
' Write the data to the request stream.
dataStream.Write(byteArray, 0, byteArray.Length)
' Close the Stream object.
dataStream.Close()
' Get the response.
Dim response As Net.WebResponse = request.GetResponse()
Dim myDB As New DBHomematicEntities
' Display the status.
If CType(response, Net.HttpWebResponse).StatusDescription = "OK" Then
' Get the stream containing content returned by the server.
dataStream = response.GetResponseStream()
' Open the stream using a StreamReader for easy access.
Dim reader As New IO.StreamReader(dataStream)
' Read the content.
Dim responseFromServer As String = reader.ReadToEnd()
'Antwort vom Server
Dim AntwortVomServer As String = responseFromServer
Mit Version 3.X hatte noch alles funktioniert.
Jemand ne Idee woran es liegt?
