schicke dieses:
{"jsonrpc":"2.0","method":"WFC_GetSnapshotEx","params":[19085,0],"id":"1476344430281"}
prettyString =
"method": "WFC_GetSnapshotEx",
"id": "1476344430281",
"jsonrpc": "2.0",
"params": [
"19085",
"0"
bekomme aber diesen Fehler zurück
symcon: …/res/rapidjson/include/rapidjson/document.h:1631: int rapidjson::GenericValue<Encoding, Allocator>::GetInt() const [with Encoding = rapidjson::UTF8<>; Allocator = rapidjson::CrtAllocator]: Zusicherung »data_.f.flags & kIntFlag« nicht erfüllt.
und IPS4.1 verabschiedet sich
sieht doch eigentlich OK aus - ODER?
Guido
hier noch der „Start“ welcher OK abgearbeitet wird:
{"method":"WFC_GetConfigurators","id":"1476344967891","jsonrpc":"2.0","params":[]}
"method": "WFC_GetConfigurators",
"id": "1476344967891",
"jsonrpc": "2.0",
"params": []
{result=[{editable=true, icon=IPS, mobile=true, retro=false, title=WebFront, autostart=false, retromobilerefresh=30, password=false, retrorefresh=30, retromobile=false, disabled=false, id=19085, position=0}], id=1476344967891, jsonrpc=2.0}
#0 0x766ddf70 in __GI_raise (sig=sig@entry=6)
at ../nptl/sysdeps/unix/sysv/linux/raise.c:56
#1 0x766df324 in __GI_abort () at abort.c:89
#2 0x766d6d98 in __assert_fail_base (fmt=0x0,
assertion=0xeca848 "data_.f.flags & kIntFlag", assertion@entry=0x0,
file=0x1 <error: Cannot access memory at address 0x1>,
file@entry=0x682ff430 "\001", line=1631, line@entry=1988026516,
function=function@entry=0x1017224 <_ZZNK9rapidjson12GenericValueINS_4UTF8IcEENS_12CrtAllocatorEE6GetIntEvE19__PRETTY_FUNCTION__> "int rapidjson::GenericValue<Encoding, Allocator>::GetInt() const [with Encoding = rapidjson::UTF8<>; Allocator = rapidjson::CrtAllocator]") at assert.c:92
#3 0x766d6e74 in __GI___assert_fail (assertion=0x0, file=0x682ff430 "\001",
line=1988026516,
function=0x1017224 <_ZZNK9rapidjson12GenericValueINS_4UTF8IcEENS_12CrtAllocatorEE6GetIntEvE19__PRETTY_FUNCTION__> "int rapidjson::GenericValue<Encoding, Allocator>::GetInt() const [with Encoding = rapidjson::UTF8<>; Allocator = rapidjson::CrtAllocator]") at assert.c:101
#4 0x00036364 in rapidjson::GenericValue<rapidjson::UTF8<char>, rapidjson::CrtAllocator>::GetInt() const [clone .isra.174] [clone .part.175] ()
#5 0x0090f80c in void IPSDataServer::HandleRPCRequest<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >(std::ostream&, std::shared_ptr<SimpleWeb::Request<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::as---Type <return> to continue, or q <return> to quit---
io::ip::tcp> > > >) ()
#6 0x0090fe28 in std::_Function_handler<void (std::ostream&, std::shared_ptr<SimpleWeb::Request<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >), void IPSDataServer::AssignServerHandler<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >(std::shared_ptr<SimpleWeb::Server<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >)::{lambda(std::ostream&, std::shared_ptr<SimpleWeb::Request<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >)#2}>::_M_invoke(std::_Any_data const&, std::ostream&, std::shared_ptr<SimpleWeb::Request<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >) ()
#7 0x001d57d0 in SimpleWeb::ServerBase<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >::write_response(std::shared_ptr<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >, std::shared_ptr<SimpleWeb::Request<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >, std::function<void (std::ostream&, std::shared_ptr<SimpleWeb::Request<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >)>) ()
#8 0x001d5ce0 in SimpleWeb::ServerBase<boost::asio::basic_stream_socket<boost::---Type <return> to continue, or q <return> to quit---
asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >::match_resource(std::shared_ptr<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >, std::shared_ptr<SimpleWeb::Request<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >) ()
#9 0x001d6414 in boost::asio::detail::read_streambuf_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> >, std::allocator<char>, boost::asio::detail::transfer_exactly_t, SimpleWeb::ServerBase<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >::read_request_and_content(std::shared_ptr<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >)::{lambda(boost::system::error_code const&, unsigned int)#1}::operator()(boost::system::error_code const&, unsigned int) const::{lambda(boost::system::error_code const&, unsigned int)#3}>::operator()(boost::system::error_code const&, unsigned int, int) ()
#10 0x001d6700 in boost::asio::detail::reactive_socket_recv_op<boost::asio::mutable_buffers_1, boost::asio::detail::read_streambuf_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> >, std::allocator<char>, boost::asio::detail::transfer_exactly_t, SimpleWeb::ServerBase<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >::read_request_and_content(std::shared_ptr<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >)::{lambda(boost::system::error_c---Type <return> to continue, or q <return> to quit---
ode const&, unsigned int)#1}::operator()(boost::system::error_code const&, unsigned int) const::{lambda(boost::system::error_code const&, unsigned int)#3}> >::do_complete(boost::asio::detail::task_io_service*, boost::asio::detail::task_io_service_operation*, boost::system::error_code const&, unsigned int) ()
#11 0x000da070 in boost::asio::detail::task_io_service::run(boost::system::error_code&) ()
#12 0x008ed598 in std::thread::_Impl<std::_Bind_simple<IPSDataServer::MessageSink(IPSMessage const&)::{lambda()#1} ()> >::_M_run() ()
#13 0x76967348 in ?? () from /usr/lib/arm-linux-gnueabihf/libstdc++.so.6
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
