Question is in the wrong section, if a mod can move this please.
Hi all, I recently started to use IPSView and I have a couple of questions:
In Viewdesigner
Define the specific settings for the device you are using.
Does this mean I can only use one type of device?
The only „view“ that looks usable on all my devices (iPad, iPhone, webbrowser) is the universal setting. Other settings mess up the looks on all the devices. Does this mean that IPSview cannot detect the device it’s being used on and thus cannot scale correctly?
In Viewdesigner
When selecting Clients, to add/import the selected view to a client by scanning the QR code only opens the the app ipsview on the iPhone/ipad. It does not use/create/import any settings in the QR code to do automatic config.
Adding mediastream (Not supported in webbrowser, I just found that out)
Media stream does show on iPad and iPhone. But not in a webbrowser (Safari or Firefox)
Message: ImageCodeExeption: Failed to load Network image. Than it points to https://flutter.dev/docs/etc… (only displayed in Safari, FF does not show anything.
At the moment I am using a docker version of Symcon.
IP-Symcon 6.3, Ubuntu (Docker) (amd64), 09-02-2023.
IPSView 6.0.21
IPSview Blue Template
