Im Zweifel immer ein Update
kannst Du bitte die alte Version 1058 ins Github für ein Update laden ?
Dann kann ich zumindest das einspielen des Backups vermeiden…
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:00.46 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\install\DownloadListFiles
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:00.47 Copy C:\IP-Symcon\scripts\IPSLibrary\install\DownloadListFiles\Plugwise_FileList.ini --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\install\DownloadListFiles\Plugwise_FileList.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:00.47 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/install/DownloadListFiles/Plugwise_FileList.ini ---> C:\IP-Symcon\scripts\IPSLibrary\install\DownloadListFiles\Plugwise_FileList.ini
IPSModuleManager-Log-IPSFileVersionHandle2013-12-23 21:37:00.70 Set Version Plugwise=1.2.1061 (Loading)
IPSModuleManager-Log-IPSFileVersionHandle2013-12-23 21:37:00.70 Set Repository Plugwise=https://raw.github.com/1007/IPS1007Library/master\
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:00.71 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\install\InstallationScripts
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:00.71 Copy C:\IP-Symcon\scripts\IPSLibrary\install\InstallationScripts\Plugwise_Installation.ips.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\install\InstallationScripts\Plugwise_Installation.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:00.71 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/install/InstallationScripts/Plugwise_Installation.ips.php ---> C:\IP-Symcon\scripts\IPSLibrary\install\InstallationScripts\Plugwise_Installation.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:01.02 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\install\InitializationFiles\Default
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:01.02 Copy C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\Plugwise.ini --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\install\InitializationFiles\Default\Plugwise.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:01.02 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/install/InitializationFiles/Default/Plugwise.ini ---> C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\Plugwise.ini
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:01.20 Register Script Plugwise.ini in Program.IPSLibrary.install.InitializationFiles (File=C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Plugwise.ini)
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:01.20 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\app\hardware\Plugwise
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:01.21 Copy C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_Include.ips.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\app\hardware\Plugwise\Plugwise_Include.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:01.21 Copy C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_Controller.ips.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\app\hardware\Plugwise\Plugwise_Controller.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:01.21 Copy C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_ReadBuffer.ips.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\app\hardware\Plugwise\Plugwise_ReadBuffer.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:02.96 Copy C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_ReadTime.ips.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\app\hardware\Plugwise\Plugwise_ReadTime.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:02.96 Copy C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_SetTime.ips.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\app\hardware\Plugwise\Plugwise_SetTime.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:02.96 Copy C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_Recalibrate.ips.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\app\hardware\Plugwise\Plugwise_Recalibrate.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:02.97 Copy C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_Webfront.ips.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\app\hardware\Plugwise\Plugwise_Webfront.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:02.97 Copy C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_Circlesearch.ips.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\app\hardware\Plugwise\Plugwise_Circlesearch.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:02.97 Copy C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_IPSModulupdaten.ips.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\app\hardware\Plugwise\Plugwise_IPSModulupdaten.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:02.97 Copy C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_Config_Highcharts.ips.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\app\hardware\Plugwise\Plugwise_Config_Highcharts.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:02.98 Copy C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Highcharts.ips.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\app\hardware\Plugwise\Highcharts.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:02.98 Copy C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_DeleteCookie.ips.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\app\hardware\Plugwise\Plugwise_DeleteCookie.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:02.99 Copy C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_CheckUpdate.ips.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\app\hardware\Plugwise\Plugwise_CheckUpdate.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:02.99 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/app/hardware/Plugwise/Plugwise_Include.ips.php ---> C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_Include.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:07.38 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/app/hardware/Plugwise/Plugwise_Controller.ips.php ---> C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_Controller.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:07.62 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/app/hardware/Plugwise/Plugwise_ReadBuffer.ips.php ---> C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_ReadBuffer.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:07.80 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/app/hardware/Plugwise/Plugwise_ReadTime.ips.php ---> C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_ReadTime.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:08.04 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/app/hardware/Plugwise/Plugwise_SetTime.ips.php ---> C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_SetTime.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:08.23 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/app/hardware/Plugwise/Plugwise_Recalibrate.ips.php ---> C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_Recalibrate.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:08.41 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/app/hardware/Plugwise/Plugwise_Webfront.ips.php ---> C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_Webfront.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:08.62 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/app/hardware/Plugwise/Plugwise_Circlesearch.ips.php ---> C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_Circlesearch.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:08.80 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/app/hardware/Plugwise/Plugwise_IPSModulupdaten.ips.php ---> C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_IPSModulupdaten.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:09.10 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/app/hardware/Plugwise/Plugwise_Config_Highcharts.ips.php ---> C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_Config_Highcharts.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:09.34 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/app/hardware/Plugwise/Highcharts.ips.php ---> C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Highcharts.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:09.71 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/app/hardware/Plugwise/Plugwise_DeleteCookie.ips.php ---> C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_DeleteCookie.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:10.16 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/app/hardware/Plugwise/Plugwise_CheckUpdate.ips.php ---> C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_CheckUpdate.ips.php
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:11.13 Register Script Plugwise_Include in Program.IPSLibrary.app.hardware.Plugwise (File=C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_Include.ips.php)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:11.13 Register Script Plugwise_Controller in Program.IPSLibrary.app.hardware.Plugwise (File=C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_Controller.ips.php)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:11.13 Register Script Plugwise_ReadBuffer in Program.IPSLibrary.app.hardware.Plugwise (File=C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_ReadBuffer.ips.php)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:11.13 Register Script Plugwise_ReadTime in Program.IPSLibrary.app.hardware.Plugwise (File=C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_ReadTime.ips.php)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:11.13 Register Script Plugwise_SetTime in Program.IPSLibrary.app.hardware.Plugwise (File=C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_SetTime.ips.php)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:11.14 Register Script Plugwise_Recalibrate in Program.IPSLibrary.app.hardware.Plugwise (File=C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_Recalibrate.ips.php)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:11.14 Register Script Plugwise_Webfront in Program.IPSLibrary.app.hardware.Plugwise (File=C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_Webfront.ips.php)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:11.14 Register Script Plugwise_Circlesearch in Program.IPSLibrary.app.hardware.Plugwise (File=C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_Circlesearch.ips.php)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:11.14 Register Script Plugwise_IPSModulupdaten in Program.IPSLibrary.app.hardware.Plugwise (File=C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_IPSModulupdaten.ips.php)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:11.14 Register Script Plugwise_Config_Highcharts in Program.IPSLibrary.app.hardware.Plugwise (File=C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_Config_Highcharts.ips.php)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:11.14 Register Script Highcharts in Program.IPSLibrary.app.hardware.Plugwise (File=C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Highcharts.ips.php)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:11.14 Register Script Plugwise_DeleteCookie in Program.IPSLibrary.app.hardware.Plugwise (File=C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_DeleteCookie.ips.php)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:11.15 Register Script Plugwise_CheckUpdate in Program.IPSLibrary.app.hardware.Plugwise (File=C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_CheckUpdate.ips.php)
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:11.15 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\config\hardware\Plugwise\Default
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:11.15 Copy C:\IP-Symcon\scripts\IPSLibrary\config\hardware\Plugwise\Default\Plugwise_Configuration.inc.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\config\hardware\Plugwise\Default\Plugwise_Configuration.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:11.16 Copy C:\IP-Symcon\scripts\IPSLibrary\config\hardware\Plugwise\Default\Plugwise_Profile.inc.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\config\hardware\Plugwise\Default\Plugwise_Profile.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:11.16 Copy C:\IP-Symcon\scripts\IPSLibrary\config\hardware\Plugwise\Default\Plugwise_CSS3Menu.inc.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\config\hardware\Plugwise\Default\Plugwise_CSS3Menu.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:11.16 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/config/hardware/Plugwise/Default/Plugwise_Configuration.inc.php ---> C:\IP-Symcon\scripts\IPSLibrary\config\hardware\Plugwise\Default\Plugwise_Configuration.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:11.38 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/config/hardware/Plugwise/Default/Plugwise_Profile.inc.php ---> C:\IP-Symcon\scripts\IPSLibrary\config\hardware\Plugwise\Default\Plugwise_Profile.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:11.57 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/config/hardware/Plugwise/Default/Plugwise_CSS3Menu.inc.php ---> C:\IP-Symcon\scripts\IPSLibrary\config\hardware\Plugwise\Default\Plugwise_CSS3Menu.inc.php
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:11.75 Register Script Plugwise_Configuration in Program.IPSLibrary.config.hardware.Plugwise (File=C:\IP-Symcon\scripts\IPSLibrary\config\hardware\Plugwise\Plugwise_Configuration.inc.php)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:11.75 Register Script Plugwise_Profile in Program.IPSLibrary.config.hardware.Plugwise (File=C:\IP-Symcon\scripts\IPSLibrary\config\hardware\Plugwise\Plugwise_Profile.inc.php)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:11.75 Register Script Plugwise_CSS3Menu in Program.IPSLibrary.config.hardware.Plugwise (File=C:\IP-Symcon\scripts\IPSLibrary\config\hardware\Plugwise\Plugwise_CSS3Menu.inc.php)
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:11.76 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:11.76 Copy C:\IP-Symcon\webfront\user\Plugwise\jquery-1.7.2.min.js --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\jquery-1.7.2.min.js
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:11.77 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\Highcharts\js\modules
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:11.77 Copy C:\IP-Symcon\webfront\user\Plugwise\Highcharts\js\modules\exporting.js --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\Highcharts\js\modules\exporting.js
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:11.78 Copy C:\IP-Symcon\webfront\user\Plugwise\Highcharts\js\highcharts.js --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\Highcharts\js\highcharts.js
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:11.78 Copy C:\IP-Symcon\webfront\user\Plugwise\Highcharts\IPS_Template.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\Highcharts\IPS_Template.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:11.79 Copy C:\IP-Symcon\webfront\user\Plugwise\Highcharts\IPS_UpdateData.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\Highcharts\IPS_UpdateData.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:11.79 Copy C:\IP-Symcon\webfront\user\Plugwise\PlugwiseWebMenuController.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\PlugwiseWebMenuController.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.08 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\Highcharts\js hemes
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.08 Copy C:\IP-Symcon\webfront\user\Plugwise\Highcharts\js hemes\ips.js --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\Highcharts\js hemes\ips.js
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.09 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\Default
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.09 Copy C:\IP-Symcon\webfront\user\Plugwise\Default\Plugwise.css --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\Default\Plugwise.css
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.09 Copy C:\IP-Symcon\webfront\user\Plugwise\Changelog.txt --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\Changelog.txt
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.09 Copy C:\IP-Symcon\webfront\user\Plugwise abPlugwiseNormal.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise abPlugwiseNormal.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.10 Copy C:\IP-Symcon\webfront\user\Plugwise abPlugwiseRed.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise abPlugwiseRed.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.10 Copy C:\IP-Symcon\webfront\user\Plugwise\leer.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\leer.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.10 Copy C:\IP-Symcon\webfront\user\Plugwise\blitz.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\blitz.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.11 Copy C:\IP-Symcon\webfront\user\Plugwise\blitz2.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\blitz2.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.11 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.11 Copy C:\IP-Symcon\webfront\user\Plugwise\images\menu_hardwareversion.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\menu_hardwareversion.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.11 Copy C:\IP-Symcon\webfront\user\Plugwise\images\menu_softwareversion.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\menu_softwareversion.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.14 Copy C:\IP-Symcon\webfront\user\Plugwise\images\menu_hardwareversion_grau.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\menu_hardwareversion_grau.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.20 Copy C:\IP-Symcon\webfront\user\Plugwise\images\menu_softwareversion_grau.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\menu_softwareversion_grau.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.21 Copy C:\IP-Symcon\webfront\user\Plugwise\images\menu_onlineoffline.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\menu_onlineoffline.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.21 Copy C:\IP-Symcon\webfront\user\Plugwise\images\menu_einaus.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\menu_einaus.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.22 Copy C:\IP-Symcon\webfront\user\Plugwise\images\menu_uebersicht.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\menu_uebersicht.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.22 Copy C:\IP-Symcon\webfront\user\Plugwise\images\menu_uebersicht_grau.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\menu_uebersicht_grau.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.23 Copy C:\IP-Symcon\webfront\user\Plugwise\images\menu_leer.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\menu_leer.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.23 Copy C:\IP-Symcon\webfront\user\Plugwise\images\menu_leer_grau.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\menu_leer_grau.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.24 Copy C:\IP-Symcon\webfront\user\Plugwise\images\menu_letztedaten.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\menu_letztedaten.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.24 Copy C:\IP-Symcon\webfront\user\Plugwise\images\menu_letztedaten_grau.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\menu_letztedaten_grau.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.24 Copy C:\IP-Symcon\webfront\user\Plugwise\images\menu_leistung.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\menu_leistung.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.29 Copy C:\IP-Symcon\webfront\user\Plugwise\images\menu_verbrauch.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\menu_verbrauch.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.30 Copy C:\IP-Symcon\webfront\user\Plugwise\images\menu_leistung_grau.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\menu_leistung_grau.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.30 Copy C:\IP-Symcon\webfront\user\Plugwise\images\menu_verbrauch_grau.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\menu_verbrauch_grau.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.31 Copy C:\IP-Symcon\webfront\user\Plugwise\images\menu_ping.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\menu_ping.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.47 Copy C:\IP-Symcon\webfront\user\Plugwise\images\menu_ping_grau.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\menu_ping_grau.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.48 Copy C:\IP-Symcon\webfront\user\Plugwise\images\status_neu.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\status_neu.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.49 Copy C:\IP-Symcon\webfront\user\Plugwise\images\status_aus.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\status_aus.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.50 Copy C:\IP-Symcon\webfront\user\Plugwise\images\status_an.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\status_an.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.50 Copy C:\IP-Symcon\webfront\user\Plugwise\images\status_online.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\status_online.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.51 Copy C:\IP-Symcon\webfront\user\Plugwise\images\status_offline.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\status_offline.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.51 Copy C:\IP-Symcon\webfront\user\Plugwise\images\status_o.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\status_o.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.54 Copy C:\IP-Symcon\webfront\user\Plugwise\images\circleausgefallen.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\circleausgefallen.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.54 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\css3menu
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.54 Copy C:\IP-Symcon\webfront\user\Plugwise\css3menu\style_default.css --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\css3menu\style_default.css
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.54 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\default
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.54 Copy C:\IP-Symcon\webfront\user\Plugwise\images\default\Backward.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\default\Backward.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.55 Copy C:\IP-Symcon\webfront\user\Plugwise\images\default\Forward.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\default\Forward.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.55 Copy C:\IP-Symcon\webfront\user\Plugwise\images\default\Home.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\default\Home.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.55 Copy C:\IP-Symcon\webfront\user\Plugwise\images\default\Hour.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\default\Hour.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.55 Copy C:\IP-Symcon\webfront\user\Plugwise\images\default\Day.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\default\Day.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.56 Copy C:\IP-Symcon\webfront\user\Plugwise\images\default\Week.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\default\Week.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.56 Copy C:\IP-Symcon\webfront\user\Plugwise\images\default\Month.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\default\Month.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.56 Copy C:\IP-Symcon\webfront\user\Plugwise\images\default\Year.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\default\Year.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.56 Copy C:\IP-Symcon\webfront\user\Plugwise\images\default\HighchartsRueckwaerts.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\default\HighchartsRueckwaerts.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.57 Copy C:\IP-Symcon\webfront\user\Plugwise\images\default\HighchartsVorwaerts.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\default\HighchartsVorwaerts.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.59 Copy C:\IP-Symcon\webfront\user\Plugwise\images\default\HighchartsHome.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\default\HighchartsHome.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.59 Copy C:\IP-Symcon\webfront\user\Plugwise\images\default\HighchartsStunde.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\default\HighchartsStunde.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.60 Copy C:\IP-Symcon\webfront\user\Plugwise\images\default\HighchartsTag.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\default\HighchartsTag.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.60 Copy C:\IP-Symcon\webfront\user\Plugwise\images\default\HighchartsWoche.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\default\HighchartsWoche.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.61 Copy C:\IP-Symcon\webfront\user\Plugwise\images\default\HighchartsMonat.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\default\HighchartsMonat.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.61 Copy C:\IP-Symcon\webfront\user\Plugwise\images\default\HighchartsJahr.png --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-23_2137\IPSLibrary\webfront\Plugwise\images\default\HighchartsJahr.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:13.61 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/jquery-1.7.2.min.js ---> C:\IP-Symcon\webfront\user\Plugwise\jquery-1.7.2.min.js
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:14.07 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/Highcharts/js/modules/exporting.js ---> C:\IP-Symcon\webfront\user\Plugwise\Highcharts\js\modules\exporting.js
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:14.29 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/Highcharts/js/highcharts.js ---> C:\IP-Symcon\webfront\user\Plugwise\Highcharts\js\highcharts.js
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:14.83 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/Highcharts/IPS_Template.php ---> C:\IP-Symcon\webfront\user\Plugwise\Highcharts\IPS_Template.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:15.10 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/Highcharts/IPS_UpdateData.php ---> C:\IP-Symcon\webfront\user\Plugwise\Highcharts\IPS_UpdateData.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:15.30 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/PlugwiseWebMenuController.php ---> C:\IP-Symcon\webfront\user\Plugwise\PlugwiseWebMenuController.php
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:15.48 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/Highcharts/js/themes/ips.js ---> C:\IP-Symcon\webfront\user\Plugwise\Highcharts\js hemes\ips.js
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:15.68 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/Default/Plugwise.css ---> C:\IP-Symcon\webfront\user\Plugwise\Default\Plugwise.css
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:15.88 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/Changelog.txt ---> C:\IP-Symcon\webfront\user\Plugwise\Changelog.txt
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:16.07 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/tabPlugwiseNormal.png ---> C:\IP-Symcon\webfront\user\Plugwise abPlugwiseNormal.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:16.25 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/tabPlugwiseRed.png ---> C:\IP-Symcon\webfront\user\Plugwise abPlugwiseRed.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:16.44 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/leer.png ---> C:\IP-Symcon\webfront\user\Plugwise\leer.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:16.63 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/blitz.png ---> C:\IP-Symcon\webfront\user\Plugwise\blitz.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:16.81 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/blitz2.png ---> C:\IP-Symcon\webfront\user\Plugwise\blitz2.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:17.04 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/menu_hardwareversion.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\menu_hardwareversion.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:17.27 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/menu_softwareversion.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\menu_softwareversion.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:17.50 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/menu_hardwareversion_grau.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\menu_hardwareversion_grau.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:17.71 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/menu_softwareversion_grau.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\menu_softwareversion_grau.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:17.90 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/menu_onlineoffline.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\menu_onlineoffline.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:18.10 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/menu_einaus.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\menu_einaus.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:18.29 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/menu_uebersicht.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\menu_uebersicht.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:18.48 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/menu_uebersicht_grau.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\menu_uebersicht_grau.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:18.67 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/menu_leer.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\menu_leer.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:18.86 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/menu_leer_grau.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\menu_leer_grau.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:19.05 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/menu_letztedaten.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\menu_letztedaten.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:19.23 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/menu_letztedaten_grau.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\menu_letztedaten_grau.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:19.86 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/menu_leistung.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\menu_leistung.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:20.05 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/menu_verbrauch.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\menu_verbrauch.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:20.23 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/menu_leistung_grau.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\menu_leistung_grau.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:20.44 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/menu_verbrauch_grau.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\menu_verbrauch_grau.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:20.62 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/menu_ping.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\menu_ping.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:20.82 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/menu_ping_grau.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\menu_ping_grau.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:21.03 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/status_neu.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\status_neu.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:21.22 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/status_aus.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\status_aus.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:21.42 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/status_an.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\status_an.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:21.60 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/status_online.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\status_online.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:21.77 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/status_offline.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\status_offline.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:21.97 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/status_o.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\status_o.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:22.20 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/circleausgefallen.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\circleausgefallen.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:22.45 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/css3menu/style_default.css ---> C:\IP-Symcon\webfront\user\Plugwise\css3menu\style_default.css
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:22.63 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/default/Backward.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\default\Backward.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:22.82 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/default/Forward.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\default\Forward.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:23.00 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/default/Home.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\default\Home.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:23.18 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/default/Hour.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\default\Hour.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:23.37 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/default/Day.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\default\Day.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:23.60 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/default/Week.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\default\Week.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:23.82 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/default/Month.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\default\Month.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:24.04 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/default/Year.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\default\Year.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:24.24 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/default/HighchartsRueckwaerts.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\default\HighchartsRueckwaerts.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:24.48 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/default/HighchartsVorwaerts.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\default\HighchartsVorwaerts.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:24.89 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/default/HighchartsHome.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\default\HighchartsHome.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:25.08 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/default/HighchartsStunde.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\default\HighchartsStunde.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:25.27 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/default/HighchartsTag.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\default\HighchartsTag.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:25.85 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/default/HighchartsWoche.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\default\HighchartsWoche.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:26.31 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/default/HighchartsMonat.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\default\HighchartsMonat.png
IPSModuleManager-Log-IPSFileHandler 2013-12-23 21:37:26.50 Copy https://raw.github.com/1007/IPS1007Library/master/IPSLibrary/webfront/Plugwise/images/default/HighchartsJahr.png ---> C:\IP-Symcon\webfront\user\Plugwise\images\default\HighchartsJahr.png
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.70 Script jquery-1.7.2.min.js NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.70 Script exporting.js NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.70 Script highcharts.js NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.71 Script IPS_Template NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.71 Script IPS_UpdateData NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.71 Script PlugwiseWebMenuController NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.71 Script ips.js NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.71 Script Plugwise.css NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.71 Script Changelog.txt NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.71 Script tabPlugwiseNormal.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.71 Script tabPlugwiseRed.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.71 Script leer.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.71 Script blitz.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.71 Script blitz2.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.71 Script menu_hardwareversion.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.71 Script menu_softwareversion.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.71 Script menu_hardwareversion_grau.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.71 Script menu_softwareversion_grau.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.71 Script menu_onlineoffline.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.71 Script menu_einaus.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.71 Script menu_uebersicht.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.71 Script menu_uebersicht_grau.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.71 Script menu_leer.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.71 Script menu_leer_grau.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.72 Script menu_letztedaten.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.72 Script menu_letztedaten_grau.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.72 Script menu_leistung.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.72 Script menu_verbrauch.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.72 Script menu_leistung_grau.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.72 Script menu_verbrauch_grau.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.72 Script menu_ping.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.72 Script menu_ping_grau.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.72 Script status_neu.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.72 Script status_aus.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.72 Script status_an.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.72 Script status_online.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.72 Script status_offline.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.72 Script status_o.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.72 Script circleausgefallen.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.72 Script style_default.css NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.72 Script Backward.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.72 Script Forward.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.72 Script Home.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.72 Script Hour.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.72 Script Day.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.73 Script Week.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.73 Script Month.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.73 Script Year.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.73 Script HighchartsRueckwaerts.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.73 Script HighchartsVorwaerts.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.73 Script HighchartsHome.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.73 Script HighchartsStunde.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.73 Script HighchartsTag.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.73 Script HighchartsWoche.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.73 Script HighchartsMonat.png NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-23 21:37:26.73 Script HighchartsJahr.png NOT registered (Filepath)
IPSModuleManager-Log-IPSFileVersionHandle2013-12-23 21:37:26.73 Set Version Plugwise=1.2.1061 (Loaded)
IPSModuleManager-Log-IPSFileVersionHandle2013-12-23 21:37:26.73 Set Version Plugwise=1.2.1061 (Installing)
--- Create Plugwise -------------------------------------------------------------------
[~Watt.14490]--- Create Plugwise -------------------------------------------------------------------
IPSModuleManager-Log-IPSModuleManager 2013-12-23 21:37:26.85 Empty Category ID=45417
IPSModuleManager-Log-IPSModuleManager 2013-12-23 21:37:26.89 Empty Category ID=27763
IPSModuleManager-Log-IPSModuleManager 2013-12-23 21:37:28.10 Created Timer REFRESH=15809
Create Circle000D6F000278D052
PW Create Circle: 000D6F000278D052IPSModuleManager-Log-IPSModuleManager 2013-12-23 21:37:28.11 Set VariableCustomAction='' for Variable='Status'
Bei 31085 Actionscript setzenAbort Processing during Error: Instanz ist mit keiner übergeordneten Instanz verbunden!
Error in Script C:\IP-Symcon\scripts\IPSLibrary\app\hardware\Plugwise\Plugwise_Include.ips.php on Line 136
Defintiv mit Problem 3.0 - 3.1 Version zu tun . Hab das heute auch gehabt .Bin auf 3.1 und hab was unbebaut.
Freund des Lichts…das hätteste aber gerne mal dazu schreiben dürfen.
Ich habe, wie alle anderen die 3.0 im Einsatz, da ich die Tage in Urlaub will und mit einer Beta hier echt nicht agieren möchte.
Könntest Du bitte die alte Version irgendwo hinterlegen, damit ich diese wieder installieren kann.
Gruss
B71
@ 1007
ich habe morgen echt andere Sorgen als das Modul wieder zum Leben zu erwecken.
Kannst Du mir bitte irgendwo die 1058 hinstellen, um alles was es heute Abend zerschossen hat noch heute Abend zu fixen ?
Ich habe leider etwas Zeitdruck und wäre Dir echt dankbar.
Gruss
B71
Kannst du mal ein Update machen ?
Habe eben ein Update auf 3.1 gemacht und die gleichen Probleme gehabt.
Somit bin ich jetzt auf mein Backup von gestern 21.00 Uhr zurück und fasse das nicht mehr an.
Eine Bitte: Bei einer ähnlichen Anpassung dies bitte DEUTLICH kenntlich machen.
Mich hat dies jetzt 1 Tag Daten gekostet und 4h Suche und eine etwas angefressene Familie verursacht.
Merry x-mas
B71
Hast du eine ID 31085 ueberhaupt ?
Sorry, aber ich bin zum testen „raus“.
Muss jetzt erst einmal die Folgen der Aktion gerade ziehen.
Da ich aber nicht alleine Probleme habe, liegt zumindest die Vermutung nahe, dass es bestimmte Herausforderungen gibt.
Gruss
b71
Probleme mit Version < 3.1 !!!
Hatte vorhin auch das Update gemacht, die Fehlermeldung mit MENU
kam auch, irgendwann ist das Ding aber weiter durchgelaufen und war fertig. Nur das Webfront ist jetzt verändert. Das was vorher rechts war ist jetzt gequetscht links und rechts sind die jetzt überbreiten Tastenfelder für Allgemeines und Systemsteuerung.
Ach ja … 3.1
Bruno
Bitte ein Bild ( Image ) bitte!
Bist du 3.1 ?
Hallo 1007,
hab gerade die Version 1062 entdeckt und gleich probiert.
Keine roten Fehlermeldungen mehr. Leider bleibt er immer noch beim Install hängen.
Gerd
Jetzt geht nix mehr, Teilinstallation ging dann Konsole „Keine Rückmeldung“, ips hängt mit „Last Message: OM_CHILDADDED“
Probier mal die 1064
Hallo 1007,
sogar an Weihnachten gibt es Support. Unglaublich.
Die Installation läuft jetzt fehlerfrei durch.
Die Circles sind zuerst Online aber ohne Daten und gehen dann Offline.
Die Zeit bei den Circles steht auf 1.1.70.
Vielen Dank für den wahnsinns Support.
Gerd
Prozess abgeschossen, Neustart, die 1064 geht jetzt problemlos. Jetzt bitte nur noch das vertauschte Webfront anpassen und bitte beim Wizard die parent Zeile einfügen (irgendwann reicht auch).
Die Circles bleiben bei mir online.
Bruno
