wie gewünscht anbei das Debugging.
Es passiert jedes Mail beim Anlernen von WiredKomponenten.
Gruss Ralf.
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fffb67fc700 (LWP 26003)]
0x00000000005b48c9 in HomeMaticSocket::ProcessEvent(std::string) ()
(gdb) bt
#0 0x00000000005b48c9 in HomeMaticSocket::ProcessEvent(std::string) ()
#1 0x00000000005b5260 in HomeMaticSocket::HandleRequest(std::ostream&, std::shared_ptr<SimpleWeb::Request<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >) ()
#2 0x00000000005b54d4 in HomeMaticSocket::Connect()::{lambda(std::ostream&, std::shared_ptr<SimpleWeb::Request<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >)#1}::operator()(std::ostream&, std::shared_ptr<SimpleWeb::Request<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >) const ()
#3 0x00000000005b576f in std::_Function_handler<void (std::ostream&, std::shared_ptr<SimpleWeb::Request<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >), HomeMaticSocket::Connect()::{lambda(std::ostream&, std::shared_ptr<SimpleWeb::Request<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >)#1}>::_M_invoke(std::_Any_data const&, std::ostream&, std::shared_ptr<SimpleWeb::Request<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >) ()
#4 0x00000000005c10ab in SimpleWeb::ServerBase<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >::write_response(std::shared_ptr<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >, std::shared_ptr<SimpleWeb::Request<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >, std::function<void (std::ostream&, std::shared_ptr<SimpleWeb::Request<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >)>) ()
#5 0x00000000005c17eb in SimpleWeb::ServerBase<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >::match_resource(std::shared_ptr<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >, std::shared_ptr<SimpleWeb::Request<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >) ()
#6 0x00000000005c1d41 in boost::asio::detail::read_streambuf_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> >, std::allocator<char>, boost::asio::detail::transfer_exactly_t, SimpleWeb::ServerBase<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >::read_request_and_content(std::shared_ptr<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >)::{lambda(boost::system::error_code const&, unsigned long)#1}::operator()(boost::system::error_code const&, unsigned long) const::{lambda(boost::system::error_code const&, unsigned long)#3}>::operator()(boost::system::error_code const&, unsigned long, int) ()
#7 0x00000000005c1f1d in boost::asio::detail::reactive_socket_recv_op<boost::asio::mutable_buffers_1, boost::asio::detail::read_streambuf_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> >, std::allocator<char>, boost::asio::detail::transfer_exactly_t, SimpleWeb::ServerBase<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >::read_request_and_content(std::shared_ptr<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >)::{lambda(boost::system::error_code const&, unsigned long)#1}::operator()(boost::system::error_code const&, unsigned long) const::{lambda(boost::system::error_code const&, unsigned long)#3}> >::do_complete(boost::asio::detail::task_io_service*, boost::asio::detail::task_io_service_operation*, boost::system::error_code const&, unsigned long)
#8 0x00000000004ca790 in boost::asio::detail::task_io_service::run(boost::system::error_code&) ()
#9 0x00000000005aa3f4 in std::thread::_Impl<std::_Bind_simple<HomeMaticSocket::Connect()::{lambda()#2} ()> >::_M_run() ()
#10 0x00007ffff59e3a60 in ?? () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#11 0x00007ffff5200182 in start_thread (arg=0x7fffb67fc700) at pthread_create.c:312
#12 0x00007ffff4f2d47d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
