Is it possible to show a Category, Instance or Variable from IPS in a page on my website? I want to show only one page from the IPS webfront.
Thanks ….
Albert
Thanks ….
Albert
Sure. Using SOAP or a custom PHP page in your webfront/user folder, or maybe some nice RPC magic? (http://www.ip-symcon.de/forum/threads/18690-Einfache-eigene-Seiten-mit-JSON-RPC-Dojo-Javascript-ab-IP-Symcon-2-6?highlight=RPC)
I’m not sure this is what I’m looking for, is there a simple way just to show a category of instance n a HTML of PHP page?
Albert
Still looking for a way to show some parts of IPS on my website.
The only way now is to link to one of the webfront’s I have made with a link like http://xxxxx.nl:82/index.php?configuratorID=26860. Is there a way to show a certain Category, Instance or Variable form IPS?
The answer from paresy is much too complicated for me, I hope a easier way can be used.
Thanks ….
Albert
Absolutely. Add a second WebFront Configurator to your IP-Symcon. There you can modify the „Category“ item to some special root category. This way you will have a second WebFront you can link to, where only a special portion of your IP-Symcon is visible. Using Links is another nifty trick
It’s only via Google translate but you should probably get the grasp on where to click
Thanks, that could do the trick. I have only five WebFront Configurations available and all used at the moment. But this is working, thanks ……
It should be great if it is possible to use a link one level down the WebFront Configuration, do you know if that is possible?
Or is it possible to show a Category, Instance or Variable on a PHP or HTML page in de webfront/user directory? Or maybe only a value of a object? That could also be a way, this page can then be inserted in a page on the website.
Albert
Sure. Just throw some customname.php in the webfront/user folder and call it from your website. You can show object values using GetValue.
echo GetValue(12345);
Thanks, I didn’t know that you can call objects from outside IPS.
I will create the output in this way.
Albert
