mein IPS ist abgestürzt. Es konnte aus mir nicht erklärlichen Gründen den TMEX nicht mehr erreichen. Das Problem hatte ich schonmal. Der TMEX Buffer im IPS hatt dann dan Ram gesprenngt. Nach dem Neustart war alles schön.
Anbei mal das log:
09.06.2006 00:00:00.310 | MESSAGE | Kernel | Log File Rotation after Midnight...
09.06.2006 00:00:00.310 | MESSAGE | Kernel | Backuping Settings after Midnight...
09.06.2006 00:00:00.310 | MESSAGE | Kernel | Cleaning up Settings Folder...
09.06.2006 00:00:00.310 | MESSAGE | Kernel | Cleaning up Logfile Folder...
09.06.2006 15:05:08.402 | WARNING | RRDTool | Error: ERROR: illegal attempt to update using time 1149858300 when last update time is 1149858300 (minimum one second step)
# Command: update "C:/Programme/IP-SYMCON/web_data/rrd/data/06h80320o.rrd" 1149858300:24.06
09.06.2006 15:05:08.418 | WARNING | RRDTool | Error: ERROR: illegal attempt to update using time 1149858300 when last update time is 1149858300 (minimum one second step)
# Command: update "C:/Programme/IP-SYMCON/web_data/rrd/data/b765cvdrp.rrd" 1149858300:23.94
09.06.2006 15:05:08.433 | WARNING | RRDTool | Error: ERROR: illegal attempt to update using time 1149858300 when last update time is 1149858300 (minimum one second step)
# Command: update "C:/Programme/IP-SYMCON/web_data/rrd/data/zdhg3zbyt.rrd" 1149858300:24.06
09.06.2006 15:05:08.449 | WARNING | RRDTool | Error: ERROR: illegal attempt to update using time 1149858300 when last update time is 1149858300 (minimum one second step)
# Command: update "C:/Programme/IP-SYMCON/web_data/rrd/data/4ihyfx65j.rrd" 1149858300:23.31
09.06.2006 15:05:08.465 | WARNING | RRDTool | Error: ERROR: illegal attempt to update using time 1149858300 when last update time is 1149858300 (minimum one second step)
# Command: update "C:/Programme/IP-SYMCON/web_data/rrd/data/j35lwitmu.rrd" 1149858300:23.88
09.06.2006 15:05:08.480 | WARNING | RRDTool | Error: ERROR: illegal attempt to update using time 1149858300 when last update time is 1149858300 (minimum one second step)
# Command: update "C:/Programme/IP-SYMCON/web_data/rrd/data/le3qlr2dx.rrd" 1149858300:23.25
09.06.2006 15:05:08.496 | WARNING | RRDTool | Error: ERROR: illegal attempt to update using time 1149858300 when last update time is 1149858300 (minimum one second step)
# Command: update "C:/Programme/IP-SYMCON/web_data/rrd/data/jzajuma41.rrd" 1149858300:30
09.06.2006 15:05:08.512 | WARNING | RRDTool | Error: ERROR: illegal attempt to update using time 1149858300 when last update time is 1149858300 (minimum one second step)
# Command: update "C:/Programme/IP-SYMCON/web_data/rrd/data/zv5xym5mt.rrd" 1149858300:23.56
09.06.2006 15:05:08.527 | WARNING | RRDTool | Error: ERROR: illegal attempt to update using time 1149858300 when last update time is 1149858300 (minimum one second step)
# Command: update "C:/Programme/IP-SYMCON/web_data/rrd/data/ativg80oc.rrd" 1149858300:0
09.06.2006 16:11:31.75 | WARNING | TMEX #63711 | Request Timeout from 55124
Timeout from 55124
09.06.2006 18:15:51.574 | WARNING | TMEX #63711 | Request Timeout from 11840
09.06.2006 18:16:02.596 | WARNING | TMEX #63711 | Request Timeout from 35361
09.06.2006 18:16:13.617 | WARNING | TMEX #63711 | Request Timeout from 30518
09.06.2006 18:16:24.639 | WARNING | TMEX #63711 | Request Timeout from 55124
09.06.2006 18:16:35.661 | WARNING | TMEX #63711 | Request Timeout from 11840
09.06.2006 18:16:46.683 | WARNING | TMEX #63711 | Request Timeout from 35361
09.06.2006 18:16:57.705 | WARNING | TMEX #63711 | Request Timeout from 30518
09.06.2006 18:17:08.727 | WARNING | TMEX #63711 | Request Timeout from 55124
09.06.2006 18:17:19.748 | WARNING | TMEX #63711 | Request Timeout from 11840
09.06.2006 18:17:30.770 | WARNING | TMEX #63711 | Request Timeout from 35361
09.06.2006 18:17:41.792 | WARNING | TMEX #63711 | Request Timeout from 30518
09.06.2006 18:17:52.814 | WARNING | TMEX #63711 | Request Timeout from 55124
09.06.2006 18:18:03.836 | WARNING | TMEX #63711 | Request Timeout from 11840
09.06.2006 18:18:14.857 | WARNING | TMEX #63711 | Request Timeout from 35361
09.06.2006 18:18:25.879 | WARNING | TMEX #63711 | Request Timeout from 30518
09.06.2006 18:18:36.901 | WARNING | TMEX #63711 | Request Timeout from 55124
09.06.2006 18:18:47.923 | WARNING | TMEX #63711 | Request Timeout from 11840
09.06.2006 18:18:58.945 | WARNING | TMEX #63711 | Request Timeout from 35361
09.06.2006 18:19:09.967 | WARNING | TMEX #63711 | Request Timeout from 30518
09.06.2006 18:19:20.988 | WARNING | TMEX #63711 | Request Timeout from 55124
09.06.2006 18:19:32.10 | WARNING | TMEX #63711 | Request Timeout from 11840
09.06.2006 18:19:43.32 | WARNING | TMEX #63711 | Request Timeout from 35361
09.06.2006 18:19:54.54 | WARNING | TMEX #63711 | Request Timeout from 30518
09.06.2006 18:20:05.76 | WARNING | TMEX #63711 | Request Timeout from 55124
09.06.2006 18:20:16.98 | WARNING | TMEX #63711 | Request Timeout from 11840
09.06.2006 18:20:27.119 | WARNING | TMEX #63711 | Request Timeout from 35361
09.06.2006 18:20:38.141 | WARNING | TMEX #63711 | Request Timeout from 30518
09.06.2006 18:20:49.163 | WARNING | TMEX #63711 | Request Timeout from 55124
09.06.2006 18:21:00.185 | WARNING | TMEX #63711 | Request Timeout from 11840
09.06.2006 18:21:11.207 | WARNING | TMEX #63711 | Request Timeout from 35361
09.06.2006 18:21:22.228 | WARNING | TMEX #63711 | Request Timeout from 30518
09.06.2006 18:21:33.250 | WARNING | TMEX #63711 | Request Timeout from 55124
09.06.2006 18:21:44.272 | WARNING | TMEX #63711 | Request Timeout from 11840
09.06.2006 18:21:55.294 | WARNING | TMEX #63711 | Request Timeout from 35361
09.06.2006 18:22:06.316 | WARNING | TMEX #63711 | Request Timeout from 30518
09.06.2006 18:22:17.338 | WARNING | TMEX #63711 | Request Timeout from 55124
09.06.2006 18:22:28.359 | WARNING | TMEX #63711 | Request Timeout from 11840
09.06.2006 18:22:39.381 | WARNING | TMEX #63711 | Request Timeout from 35361
09.06.2006 18:22:50.403 | WARNING | TMEX #63711 | Request Timeout from 30518
09.06.2006 18:23:01.425 | WARNING | TMEX #63711 | Request Timeout from 55124
09.06.2006 18:23:12.447 | WARNING | TMEX #63711 | Request Timeout from 11840
09.06.2006 18:23:23.469 | WARNING | TMEX #63711 | Request Timeout from 35361
09.06.2006 18:23:34.490 | WARNING | TMEX #63711 | Request Timeout from 30518
09.06.2006 18:23:35.23 | ERROR | Unknown | Out of memory
09.06.2006 18:23:46.984 | ERROR | Unknown | Out of memory
Das Log ist gekürzt !
Oliver
). Aber mit WIIPS war IPS überhaupt nicht mehr zu gebrauchen (kann ja nicht alle 2-4h nach Hause fahren und den Server neu starten :rolleyes: ).
