Should I worry about the following error in IP-Symcon 6.0 (Testing)?
14-06-2021 13:29:16 | TimerPool | Google Assistant (ReportStateTimer):
Warning: Request limit for Google Assistant State Report is reached (0). in C:\ProgramData\Symcon\modules.store\de.symcon.googleassistant\Assistant\registry.php on line 203
Since today all my Google Assistant scenes aren’t available anymore. The same scenes triggered from IPS directly do work. Google Assistant replies with something in the line of „… aren’t available. You can try to set up these devices again“.
Simple light commands behave normally.
If I use „Activate Scene“ instead of „Scene“ it works. This make me think the problems lies with Google Assistant, which doesn’t respond to custom routines anymore. Is there some log or event I can check to verify this?
24.06.2021
This morning everything is great again.
Will it have been Google !?
Yesterday
Correct, scenes that have an activation and deactivation script work. Nevertheless, the following message appears on the display:
One or more devices are not available, please set them up again.
This message also appears in all other areas - light, generic switches, etc.
They are also no longer displayed correctly in Goolge, whether they are off or on, usually offline immediately after pressing.
