Where can I find IP-Symcon 5.5. I’m installing ip-symcon again today, and there was no software update tot 6. I need the 5.5 version to get everything working again.
Thanks.
Albert
Thanks.
Albert
Hi Albert,
you need to contact support. We only have 6.0 on our homepage for download.
What did 6.0 broke in your system? Compatibility should be very good with 6.0.
Hi Paresy,
Nothing broke, I’m installing my server again and before I made a back-up from ip-symcon I checked the updates. There was no update, so made a back-up and made a clean install.
Now I need version 5.5. for installing ip-symcon again.
Albert
You can directly install 6.0 and we will migrate everything accordingly.
