Hallo ich become when ich im ein modul etwas wil anderen im config ein error Meldung und Mus dann mein Rechner neu starten. hat jemand ein Idee was das Problem ist?
Danke Ron
Danke Ron
There is a date in a string in your system with 5 digits, sometimes in the future paresy has to fix this problem.
Hello,
where can i find the string?
Ron
See log-file (search for the date), what have you done before this failure? Change a program or a new program, …
I did some time not work with this ip symcom, i did make à update and now i think it is good.
Ron
