Hi I have a question ip camera how can I make it connect
have look at RTSP
use Google-translate or just look at the box with the configuration
otherwise use mjpg from the cam
Please read the documentation: Streams — IP-Symcon :: Automation Software
And: Please ask questions where you state what you already tried and what part is exactly not working. We try really hard to help customers, but you make it nearly impossible for us. I don’t know if it is a language barrier, but you tend to give zero information and wonder why we cannot help you.
if your cam supports ONVIF you can try the ONVIF module.
Ralf
and what protocols does ip symcon support
have a look at the documentation: rtsp / mjpeg
you also can embed every html-site directly in the webfront: to save system, my 4 mjpeg-cams (mobile-config) are only in the webfront. so they don’t use computing time
it is for a camera with hd/4k that is a very good quality
