Hallo Stephan,
ich hab mit Pushbullet schon mal ein wenig rumgespielt. Die Implementierung ist aber schon über 1 Jahr alt.
Könnte sein, dass sich an der API etwas verändert hat.
Folgendes Script habe ich im Skripte-Ordner reingelegt mit dem Namen
„__pushBullet.inc.php“.
class PushBulletException extends Exception {
// Exception thrown by PushBullet
class PushBullet {
public function __construct($secret) {
// Check if cURL is loaded
if (!function_exists('curl_init')) {
throw new PushBulletException('cURL library is not loaded.');
$this->_apiKey = $secret;
// Get all devices associated with the API key.
// This is also a more reliable way of API key validation.
$curl = curl_init();
curl_setopt($curl, CURLOPT_URL, self::API_HOST . '/devices');
curl_setopt($curl, CURLOPT_USERPWD, $this->_apiKey);
curl_setopt($curl, CURLOPT_RETURNTRANSFER, true);
$response = curl_exec($curl);
if ($response === false) {
throw new PushBulletException('cURL Error: ' . curl_error($curl));
$httpCode = curl_getinfo($curl, CURLINFO_HTTP_CODE);
curl_close($curl);
if ($httpCode != 200) {
throw new PushBulletException('Unable to authenticate. HTTP Error ' . $this->_pushBulletErrors[$httpCode]);
// Check PHP version to determine whether a JSON big int workaround should be used
if (version_compare(PHP_VERSION, '5.4.0', '>=')) {
$this->_allDevices = json_decode($response, true, 512, JSON_BIGINT_AS_STRING);
} else {
$this->_allDevices = json_decode(preg_replace('/\"([a-zA-Z0-9_]+)\":\s?(\d{14,})/', '"${1}":"${2}"', $response), true);
if ($this->_allDevices) {
$this->_myDevices = $this->_allDevices['devices'];
$this->_sharedDevices = $this->_allDevices['shared_devices'];
} else {
throw new PushBulletException('Unable to decode JSON response.');
public function getDevices() {
return $this->_allDevices;
public function getMyDevices() {
return $this->_myDevices;
public function getSharedDevices() {
return $this->_sharedDevices;
public function pushNote($devices, $title, $body) {
return $this->_push($devices, 'note', $title, $body);
public function pushAddress($devices, $name, $address) {
return $this->_push($devices, 'address', $name, $address);
public function pushList($devices, $title, $items) {
return $this->_push($devices, 'list', $title, $items);
public function pushFile($devices, $fileName) {
return $this->_push($devices, 'file', $fileName, NULL);
public function pushLink($devices, $title, $url)
return $this->_push($devices, 'link', $title, $url);
const API_HOST = 'https://api.pushbullet.com/api';
private $_apiKey;
private $_allDevices;
private $_myDevices;
private $_sharedDevices;
private $_pushBulletErrors = array(
400 => '400 Bad Request. Missing a required parameter.',
401 => '401 Unauthorized. No valid API key provided.',
402 => '402 Request Failed.',
403 => '403 Forbidden. The API key is not valid for that request.',
404 => '404 Not Found. The requested item doesn\'t exist.',
500 => '500 Internal Server Error.',
502 => '502 Bad Gateway.',
503 => '503 Service Unavailable.',
504 => '504 Gateway Timeout.'
private function _buildCurlQuery($deviceId, $type, $primary, $secondary) {
switch ($type) {
case 'note':
if (empty($primary) && !empty($secondary)) {
// PushBullet doesn't set a placeholder title if it's not supplied, so we have to.
$primary = 'Note';
} else if (empty($primary) && empty($secondary)) {
throw new PushBulletException('Note: No title and body supplied.');
$queryData = http_build_query(array(
'device_iden' => $deviceId,
'type' => 'note',
'title' => $primary,
'body' => $secondary
break;
case 'address':
if (!$secondary) {
throw new PushBulletException('Address: No address supplied.');
'type' => 'address',
'name' => $primary,
'address' => $secondary
break;
case 'list':
// PushBullet doesn't set a placeholder title if it's not supplied.
$primary = 'List';
else if (empty($secondary)) {
// PushBullet accepts absolutely empty to-do lists, but there's no point.
throw new PushBulletException('List: No items supplied.');
'type' => 'list',
'items' => $secondary
// Remove array keys in square brackets
$queryData = preg_replace('/%5B[0-9]+%5D/i', '', $queryData);
break;
case 'file':
$fullFilePath = realpath($primary);
if (!is_readable($fullFilePath)) {
throw new PushBulletException('File: File does not exist or is unreadable.');
if (filesize($fullFilePath) > 25*1024*1024) {
throw new PushBulletException('File: File size exceeds 25 MB.');
$queryData = array(
'type' => 'file',
'file' => '@' . $fullFilePath . ';filename=' . basename($fullFilePath)
break;
case 'link':
throw new PushBulletException('Link: No URL supplied.');
'type' => 'link',
'url' => $secondary
curl_setopt($curl, CURLOPT_URL, self::API_HOST . '/pushes');
curl_setopt($curl, CURLOPT_POST, true);
curl_setopt($curl, CURLOPT_POSTFIELDS, $queryData);
curl_close($curl);
if ($httpCode >= 400) {
throw new PushBulletException('Push failed for device ' . $deviceId . '. HTTP Error ' . $this->_pushBulletErrors[$httpCode]);
return true;
private function _push($pushTo, $pushType, $primary, $secondary) {
if (empty($this->_allDevices)) {
throw new PushBulletException('Push: No devices found.');
if (is_string($pushTo) && $pushTo != 'all' && $pushTo != 'my' && $pushTo != 'shared') {
return $this->_buildCurlQuery($pushTo, $pushType, $primary, $secondary);
} else if (is_array($pushTo)) {
// Push to multiple devices in an array.
// Check if the device ID is in the list of devices we have permissions to push to.
$failedDevices = array();
foreach ($pushTo as $device) {
if ($this->_in_array($device, $this->_allDevices)) {
$this->_buildCurlQuery($device, $pushType, $primary, $secondary);
} else {
$failedDevices[] = $device;
if (!empty($failedDevices)) {
throw new PushBulletException('Push failed for devices: ' . implode(', ', $failedDevices));
} else if ($pushTo == 'all' || $pushTo == 'my' || $pushTo == 'shared') {
// Push to my devices, if any.
if (($pushTo == 'all' || $pushTo == 'my') && !empty($this->_myDevices)) {
foreach ($this->_myDevices as $myDevice) {
$this->_buildCurlQuery($myDevice['iden'], $pushType, $primary, $secondary);
} else if ($pushTo == 'my' && empty($this->_myDevices)) {
throw new PushBulletException('Push: No own devices found.');
// Push to shared devices, if any.
if (($pushTo == 'all' || $pushTo == 'shared') && !empty($this->_sharedDevices)) {
foreach ($this->_sharedDevices as $sharedDevice) {
$this->_buildCurlQuery($sharedDevice['iden'], $pushType, $primary, $secondary);
} else if ($pushTo == 'shared' && empty($this->_sharedDevices)) {
throw new PushBulletException('Push: No shared devices found.');
} else {
throw new PushBulletException('Push: Invalid device definition (' . $pushTo . ').');
return true;
// Multidimensional in_array()
private function _in_array($needle, $haystack, $strict = false) {
if (is_array($haystack)) {
foreach ($haystack as $item) {
if (($strict ? $item === $needle : $item == $needle) || (is_array($item) && $this->_in_array($needle, $item, $strict))) {
return true;
return false;
function IPS_PushBullet($type, $device, $d) {
#### AUTHENTICATION ####
// Get your API key here: https://www.pushbullet.com/account
$p = new PushBullet('#################### API-Key ######################## ');
#### LIST OF DEVICES ####
#### These methods return arrays containing device definitions, or NULL if there are no devices.
#### Use them to get 'device_iden' which is a unique ID for every device and is used with push methods below.
// Print an array containing all available devices (including other people's devices shared with you).
//print_r($p->getDevices());
// Print an array with your own devices
print_r($p->getMyDevices());
// Print an array with devices shared with you
//print_r($p->getSharedDevices());
//exit;
// Hier habe ich die Geräte definiert, welche ich ansprechen kann.
Die ### IDen ### kannst du dir ausgeben lassen mit // print_r($p->getMyDevices());
$g["Handy1"] = "### IDen ###";
$g["Handy2"] = "### IDen ###";
// hier reagiert das skript auf den Typ. Habe momentan nur "note" integriert. Ist ja aber beliebig erweiterbar.
switch ( $type ) {
case "note":
$p->pushNote($g[$device], $d["title"], $d["content"]);
break;
//exit;
// $p->pushNote($g["nexus"], 'Title', 'It works!');
// $p->pushAddress($g["arbeit"], 'Google HQ', '1600 Amphitheatre Parkway');
// $p->pushList($g["arbeit"], 'Shopping List', array('Milk', 'Butter'));
// $p->pushFile($g["nexus"], 'image/pic.jpg');
// $p->pushLink($g["arbeit"], 'ivkos at GitHub', 'https://github.com/ivkos');
#### PUSHING TO A SINGLE DEVICE ####
#### Methods return TRUE on success, or throw an exception on failure.
// Push to device s2GBpJqaq9IzY5nx a note with a title 'Hey!' and a body 'It works!'
$p->pushNote('s2GBpJqaq9IzY5nx', 'Hey!', 'It works!');
// Push to device a91kkT2jIICzD4JH a Google Maps address with a title 'Google HQ' and an address '1600 Amphitheatre Parkway'
$p->pushAddress('a91kkT2jIIzCD4JH', 'Google HQ', '1600 Amphitheatre Parkway');
// Push to device qVNRhnXzxZzzJ95zz a to-do list with a title 'Shopping List' and items 'Milk' and 'Butter'
$p->pushList('qVNRhnXxZzJz95zz', 'Shopping List', array('Milk', 'Butter'));
// Push to device 0PpyWzAzRDK0w6et the file '../pic.jpg'.
// Method accepts absolute and relative paths.
$p->pushFile('0PpyWzARzDK0w6et', '../pic.jpg');
// Push to device gXVZDd2hLY6TOB1 a link with a title 'ivkos at GitHub' and a URL 'https://github.com/ivkos'
$p->pushLink('gXVZDd2hLY6TOB1', 'ivkos at GitHub', 'https://github.com/ivkos');
#### PUSHING TO MULTIPLE DEVICES ####
// Push to all available devices
$p->pushNote('all', 'Some title', 'Some text');
// Push to all of your own devices
$p->pushList('my', 'Buy these', array('PHP for Dummies', 'New charger'));
// Push to all devices shared with you
$p->pushAddress('shared', "Let's meet here", 'The Lake, Central Park, NY');
// Push to multiple devices defined by their IDs
// When pushing to multiple device IDs, some of them might fail. If so, an exception saying
// which devices have failed will be thrown. If a device ID isn't in the message, it means push is successful.
$p->pushLink(array('5ZUC8hKOqLU0Jv7', 'SwZLKGn6M0fe7tO', 'tc7JSzKJLGLcKII'), 'Check this out!', 'http://youtu.be/dQw4w9WgXcQ');
In diesem Skript muss man jetzt noch seinen API-Key (#################### API-Key ########################) eintragen
und die Device-Ids (### IDen ###) holen und mappen.
Diese Datei habe ich dann im Skript __autoinclude.inc.php mit hinzugefügt.
if(file_exists(IPS_GetKernelDir()."\\scripts\\__pushBullet.inc.php"))
require_once(IPS_GetKernelDir()."\\scripts\\__pushBullet.inc.php");
Jetzt solltes du in jedem Script diese Funktion nutzen können.
$d["title"] = "Bewegung";
$d["content"] = "vor der Haustuer ". date("Y-m-d H:i:s");
IPS_PushBullet("note", "Handy1", $d );
Christian
